6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
According to the DrawTite webpage, the custom mounting brackets part number is the same for the 2005-2007 as well as the 2008. These are for a 250/350 pickup, NOT A CHASSIS CAB. Part Number 50049. Check the link below.
Reese show the same information.... same bracket for the 05-07 & 08. I'm excited that they offer this option now. The didn't when I installed my last hitch...... I'm going for the Reese 18K signature series this this time with the underbed rail system!
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
I mayv be wrong, but it is my understanding that the frame from the rear of the cab is the same for the F-350 and F-450. That way, no changes are needed for the hitch.
The frame is wider from the cab forward for the F-450.
For those that have installed the Reese Underbed rails on a Ford, how difficult did you find it to be? Did you loosen the bed or bend the metal work to get the rails underneath? By the installation directions I see you can do either. If you had to do it all over again, would you get them and install the same way?
I will be installing on my 2008 F350 and bet I will be pretty nervous when I have to drill those 4 holes.
Thanks,
Getrdun
Getrdun (aka Chad)
U.S. Navy, Stationed in CA but still call South Dakota home
Retire 2008
2008 F-350 King Ranch DRW, Tow Boss, 4x4, Navigation, DVD, Oxford White, (i.e. everything but sunroof) (mine on Mar 6)
I haven't installed one yet... but I plan on removing the bed from the truck and installing the rails.... while the bed is off I'm going to "harpoon mod" it. Then they have a pointed bolt that you run up from the mount to mark the bed for drilling..... should be pretty straight forward.
