I have a 2008 F450 CC/LB with 4.30 gears. I use it as a daily driver. Also tow once a month to once every other month. I was thinking about changing it to 3.73 gears. Would this be worth doing? It would drop my RPMs around 400 I think. I have a F350 with 3.55 gears and I'm running about 500 RPMs lower.
Thanks! Matt
2wd or 4wd? Lots of diff in cost. As yan7gin said, have you considered 245 x 19.5 tires. 265s may fit also.
And if I did the math right, that is a 13% dif in gear ratio. If you were to achieve a 13% increase in mpg, at $2.50/gal diesel, you would use 9.7gal less on a 1000 mile trip, for a $24.25 savings on fuel. How many miles do you drive in a year and what would be the cost of a change out?
But, a complete changeout of tires could easily be $1800 or more with a good tire, and not sure you should run 265s on the stock rims.
Thanks for the replys! I have thought about tires. I currently have 245×70 R19.5s. It is a 4WD but I can get a set of 3.73 for the front from a buddy for almost nothing. I would say anywhere from 40,000 to 60,000 miles a year. Depending where I'm working and how much I haul. I'm not sure if 265s would work on stock wheels either. I have seen a guy running 285s on stock wheels though. I don't know how good of a idea that is.
I drive my 450 about 40000/year--getting about 14 on highway, 12 in town solo.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
