6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SDdriver</div><div class="ubbcode-body">Has anyone ordered and towed with 3.55 gears?
Does it improve the MPGs with the 6.4?
Does the 6.4 lug too much with the 3.55 towing a load?
Thanks. </div></div>
I ordered the 3.73 rears for my crew cab drw swb truck and it's the same gearing my 2001 4x4 crew cab srw swb truck has and it seem fine when I tow around town with the newer truck. It should do the same thing other that the drw.
John
2008 Job 2 F-350 4x4 Crew Cab SWB dually
Lariat with the chrome package.
LOL, don't tell that to 1/2 of the 94-97 PSD's either, the only options we had were 4.10 or 3.55. I've seen plenty of CCLB 350's with 3.55's and regular cabs with 4.10's, both regularly pulling trailers, go figure.....
The '08's are not available with 3.55's, BTW.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: smokyred</div><div class="ubbcode-body">The '08's are not available with 3.55's, BTW.</div></div>
JOB3 '08 SRW trucks are going to offer 3.55's as a option.
__________________ '04 F-250 Harley-Davidson 6.0L CC SB
I think it is a great option providing your tires are not to tall. These trucks could use the milegae hike, it's not like the 6.4 doesn't make great power. I have a 250 with 3.55 gears, I could go for that ratio, as long as I could tow up to 13,500 with it. My under powered 250 gasser won't tow that much, but I bet a nice 6.4l crew cab could.
I like 3.55 gears. OD puts you at about 1700 rpm which is great for light loads or empty and straight gear has you turning about 2300 which is great for heavy towing.
Pulling on flats is one thing.Starting off with a big load and any kind of mountain grades is something else.If you buy one of these trucks to pull and work 3.55 is about as useless as boobs on a boar.I've pulled with 3.55s. Most miserable experiance driving cross counrty with 8k that I've ever had.Couldn't imagine a real load to pull with 3.55s. Plus its hard on a auto trans heat wise.With these 6 speed autos I would think 4.10s would be the way to go.
My normal "big" load runs 13-14K (picture here) and I used to pull it with 3.55's and it was fine.
Starting was no problem with granny low.
Granted, I'd sometimes not be able to make an upshift on a steep mountain pass, but that is a very small fraction of my normal driving. On the rolling hills of Texas, the 3.55's were fine running in straight gear. With my '01 having a 6spd instead of the old 5spd, I'd be even happier with the 3.55s.
A standard transmission will run cooler, not hotter in straight gear compared to OD.
i say it would just fine the truck i had befour my new 08 was a 03 150 supercrew 2wd with the 5.4and had 3:55 and i towed the same weight i do now around 7000 and that is over the grapvine hear in cali and that is a heack of a hill and it did it at 47 mph on the staeapest part the rest was at speed and not working to hard and that had 1/2 the power the 6.4 has now from truck to truck theo theey are not even close 08 250 crew cab fx4 with 20' But yes i would rather the 3:73 that is in my truck over thE 3:55
08 250FX4 SB CC
6.4 silver
job 1
picked up 4-1
I've had 6 Ford/Diesel P/U's All have had 3.55 until my '03 and now my' 05... As you can see I still have my First one with 3.55's Pulls like a champ.. It will walk all over a 4.10 equipped truck, with no OD they stretch out too fast and dont pull well much over 55 m.p.h.
I pull the same trailers with both Trucks GCW, from 15,000 to 30,000+ My '05 does it with less stress but my ol' 6.9 uses alot less fuel doing it..
I Feel that 4.10's with stock tires should be banned by the E.P.A.
Black Clearcoat 2005 F-350 SC Lariat DRW 6.0 TS 4x4 3.73's....AIRAID, SCT From Innovative
85 F-250 XLT 4x4 6.9 T-19 Plenty of fuel
1998 379 Ext. 3406E 18 speed turning 3.36's
5.5 M.P.G. @86,000
2005 Escape Limited Black on Black
I've pulled alot of miles at 30k and over with 3.54 gears in my truck. Around town towing would be better with 4.10s but most towing isn't in town. I think with the power of new diesels a 3.73 gear is perfect.
1999 Dodge Cummins 2500 4x4 Quad Cab TST Power Max 3 w/remote, South Bend Clutch Con OFE, Auto meter Ultralite pyro,boost and fuel pressure gauges. Pacbrake
F & A.M. Lodge 266
GeorgeC
"I will own a fleet of Dodges first."
