Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-29-2007, 08:10 AM   #1 (permalink)
6.4 "missing" question
I was hoping someone could give some insight on a potential problem I am having with my 6.4. It now has 4500 miles on it and about 4 times in the past 2000 miles it felt as though it has a miss to it. If I take and really get on it the miss clears up and the truck seems to run better than it did before the miss. I am calling it a miss because with this being my first diesel it is the only thing I have to compare it to. It is like a gas engine that is missing, kind of a stutter. I thought about calling the dealership but without it doing it all the time or without the check engine light being on I do not think they could offer much assistance. Any ideas of what may be happening.
08 F-350, FX4, 3.73 gears, SRW, 6.4 Diesel
Bluefan is offline
Old 10-29-2007, 08:12 AM   #2 (permalink)
Banned
Re: 6.4 "missing" question
Mine is in dealer now for same problem.Turned out to be injector #8 misfire.They are changing it Monday,once the injector comes in
sicaj is offline
Old 10-29-2007, 01:08 PM   #3 (permalink)
Was it raining out when you noticed this?
2008 F-350 Crew Cab Lariat 6.4 4x4
2006 Jeep Grand Cherokee SRT-8 425 hp 425 lb/ft torque
2008 Jeep Grand Cherokee Overland
2006 Triumph daytona 675 (track use)
2006 Yamaha R6 (track use)
2005 Triumph Speed Triple 1050
2004 Aprilia RSV Factory
2008 Triumph Daytona 675
shawnl is offline
Old 10-29-2007, 01:52 PM   #4 (permalink)
It was maybe damp out but raining no. 4613 how did your dealer diagnose the problem? Mine will probably tell me to bring it in when the problem happens more regularly or when the check engine light comes on.
Bluefan is offline
Old 10-29-2007, 02:13 PM   #5 (permalink)
Banned
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bluefan</div><div class="ubbcode-body">It was maybe damp out but raining no. 4613 how did your dealer diagnose the problem? Mine will probably tell me to bring it in when the problem happens more regularly or when the check engine light comes on. </div></div>The dealer pulled the codes.#8 MISSFIRE.It was missing real bad on the way to the dealer,hard to make it do 60mph.When I got to the dealer,I shut the truck off,when I restarted it,it was fine.This wasn't the first time it done this.I just couldn't bring it in sooner.
sicaj is offline
Old 10-29-2007, 04:41 PM   #6 (permalink)
4613, your problem must have been a lot worse than mine. Mine will still accelerate but just not as quick. Maybe it will get worse??
Bluefan is offline
Old 10-29-2007, 05:09 PM   #7 (permalink)
MT765's Avatar
It's not totally related but it sounds like a similar problem we had with one of our Caterpillar tractors. The problem was it would miss just like your pickup is doing, kinda of a stutter. If you shut it off, it would sometimes fix it for a day or even a week. The problem ended up being a loose/corroded electrical connection on the injector. We tried cleaning it but ended up putting a new injector in, all because of a loose connection. It sounds very similar to this problem.
01' F-350 Powerstroke CC SB, 4X4, auto. MODS: 4" Exhaust with muffler delete, ATS E-Power Tuner, Autometer Phantom pyro, and boost guages, Rapid Flow intake.
MT765 is offline
Old 10-29-2007, 06:23 PM   #8 (permalink)
Sounds as if the injector is clogged up, bad fuel, or you got some watered down fuel.
Dreen the filters and run some fuel injector cleaner threw it. I bet it will clear it up unless you got really messed injector that need to be taken off to clean.
Y2K excursion XLT 2wd, ordered july '99, built august '99, delivered september 9 '99, 4R100 fried & replaced at 900 miles still running like a champ
exoval is offline
Old 10-29-2007, 08:27 PM   #9 (permalink)
Banned
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bluefan</div><div class="ubbcode-body">4613, your problem must have been a lot worse than mine. Mine will still accelerate but just not as quick. Maybe it will get worse?? </div></div>I don't know,I can tell that as soon as you start it ,you can tell at idle.I hope changing the injector helps.I have close to 26,000 miles.
sicaj is offline
Old 10-29-2007, 09:28 PM   #10 (permalink)
mine does the same thing. it seems to be between 2000-3000 rpm at 20psi of boost. it feels kinda like a dead spot. as if it had a carb on it and it was cold.
cjchevy is offline
Old 10-30-2007, 09:45 AM   #11 (permalink)
Any chance you guys are seeing white smoke out the tail pipe when your trucks are missing?
08 F350 6.4L Lariat 4x4 CC Off-Road Stock
95 Dodge Ram V10 4x4 Supercab
87 GMC 3500 V8 2x4 DRW CC
97 Lexus LX 450 4x4
gmk9dr is offline
Old 10-30-2007, 01:27 PM   #12 (permalink)
I did not notice any white smoke. So if it was smoking it must have not been much. This has only happened once in the day light.
Bluefan is offline
Old 10-30-2007, 11:25 PM   #13 (permalink)
Not sure when your truck was built, but I had mine in for a similar problem shortly after I bought it earlier this summer. There was a batch of trucks built in the April-May time frame that had 3 bad injectors in them from a reversed polarity test at the factory. Mine would feel like it was missing until I really got on it and then it would smooth out. Your dealer should be able to tell you if yours falls into the same boat as mine did.
Since having that repair done, mine runs like a champ! Actually got just over 19 mpg on a trip across US 6 through the canyons. Best I've done yet. I love this truck!
2008 F250 CC SB 4x4 6.4L
2003 F250 CC SB 4x4 6.8L - SOLD
1994 F150 SC SB 4x4 5.0L - SOLD
ragnouomo is offline
Old 10-31-2007, 11:03 AM   #14 (permalink)
cannondale275's Avatar
Mine did the same thing the other day and yes it was raining. I thought it was just going through a regen. Since I have a rattle in the overhead I guess I might just drop it off and let them tell me what they find on both... I have 9000 miles on it so far.
Experience is something you get... right after you need it.
2008 F350 long bed Lariat 4x4 crew cab 6.4 oil burner. 8" Fabtech and 37" Toyo MTs.
cannondale275 is offline
Old 10-31-2007, 07:40 PM   #15 (permalink)
no smoke from mine. my truck was built 5/21/07. it has 12,000 miles on it.
cjchevy is offline
Locate Ford Dealerships to f
