6.4 problems - Diesel Forum - TheDieselStop.com
View Poll Results: problems with 6.4
none 75 73.53%
engine/catastrophic/major 10 9.80%
fuel/hpfp/injectors 10 9.80%
oil leaks 13 12.75%
turbo 3 2.94%
Multiple Choice Poll. Voters: 102. You may not vote on this poll
post #1 of 46 (permalink) Old 06-28-2011, 02:23 PM Thread Starter
tattoocharlie's Avatar
My Photos: (5)
6.4 problems
how many miles and problems on your 6.4
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #2 of 46 (permalink) Old 06-28-2011, 02:31 PM
senix's Avatar
I voted none...I had a bad TCM at 600 miles but that is not engine related. I still have my orginal radiator too.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #3 of 46 (permalink) Old 06-28-2011, 02:35 PM Thread Starter
My Photos: (5)
i knew you would be one of the first to respond...
knock on wood....
4" exhaust no muff
post #4 of 46 (permalink) Old 06-28-2011, 03:18 PM
None 20,000 miles
PWRBYIH is offline
post #5 of 46 (permalink) Old 06-28-2011, 03:30 PM
tfunk88's Avatar
85,000 miles now
EGR cooler failure at 28k miles, which caused engine, EGR, and DPF to be replaced
3 radiators by 25k miles
After 30k miles, no problems other than a couple cooling hoses:
upper coolant hose at 71k miles, y-pipe at 78k miles
Knucklehead Bald Guy
2005 Excursion 6.0
tfunk88 is offline
post #6 of 46 (permalink) Old 06-28-2011, 04:07 PM
smotrs's Avatar
My Photos: (16)
None here as well.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
smotrs is offline
post #7 of 46 (permalink) Old 06-28-2011, 06:56 PM
Almost 16000 with no problems (knock on wood).
2008 Ford F250 6.4l PSD Lariat Super Cab, Long Bed
2006 Jayco Jay Flight 27.5 RLS Fifth Wheel
zedd is offline
post #8 of 46 (permalink) Old 06-28-2011, 08:38 PM
136000 miles Radiator and just recently the serpintine belt tensioner. I had more problems with my 7.3 in that miles, Trans,cam sensor,glo plug relay,belt tensioner.
nailz53 is offline
post #9 of 46 (permalink) Old 06-28-2011, 08:51 PM
novarunner's Avatar
I voted none, Only problem I've had in 120,000 kms is on DPF but was covered under warrenty. Other than that it's been a great truck.
novarunner is offline
post #10 of 46 (permalink) Old 06-28-2011, 09:03 PM
tvandyck7's Avatar
None at 31k miles here. Been running a tuner since 10k and dpf deleted at 29k.
2009 F-250 6.4L PSD CC SB Lariat Ultimate FX4, 3.73LS
Mod List:
-51 gal RDS direct fill auxillary fuel tank
-SEIC High Idle
-H&S Black Maxx Running the Hot Damn +300 Tune
-S&B Dry CAI
-Diamond Eye 5" Turbo Back Race Exhaust
-Custom 10" Sub Box Behind the Center Console
-Coastaltech SYNC-LP1 Lockpick
-Westin Bull Bar
-Westin Taillight Guards
-Recon LED Smoked Dodge Cab Marker/Clearance Lights
-Billet Fender Vent Inserts
-Zone Offroad 4" Lift
-20x10 BMF Novakane 8's
-35x12.50r20 Nitto Trail Grapplers
-'11 Super Duty Rear Seat Cargo Tray w/410W Power Inverter
tvandyck7 is offline
post #11 of 46 (permalink) Old 06-28-2011, 11:24 PM
Brad777's Avatar
My Photos: (22)
I also voted none. However, I did get the radiator replaced long ago.
Just pulled my Toy Hauler 2500 miles to the Oregon Dunes and back...the truck was awesome. I now have about 26,000 miles and am thrilled. Fuel mileage could be better, but I'm good since this isn't my daily driver.
I have recently bought the kit to check the nitrate levels in my coolant. I'm a big believer in preventative maintenance...this check is one that isn't well known.
Thanks for this poll. It will be good to see the results after a few weeks.
2008 Ford F350 Long Bed
White/Pueblo Gold Accent
Lariet, Automatic
Loaded, w/exc. to Navigation
Skyjacker 6" Lift and Steering Stabilizer
Toyo 37"x13.5-20 MTs
Chrome Centerline Grizzly Rims
4.56 Gears
Amp Research Electric Steps
Firestone Ride Rites
Brad777 is offline
post #12 of 46 (permalink) Old 06-29-2011, 07:53 AM
Shinny's Avatar
I voted none, but did have a radiator and egr valve replaced at 30k. It just turned 70k, knock on wood all is good.
'08
F250 FX4 6.4L Super Duty Crew Cab SB Silver Metallic & Dark Shadow Grey Job 1
Extang Trifecta Bed Cover,
High Idle Mod,
Spray in Bed Liner
second radiator
EGR Valve replaced
100% Stock
Shinny is offline
post #13 of 46 (permalink) Old 06-29-2011, 09:04 AM
47K, none
One radiator, one u-joint, used for daily driver plus pulling 10K tag when I move from base to base.
Has 3 moves under its belt loaded to max GCWR
- 2013 Lariat Crew Cab 4x4, Tow Package, 6.7, 3.55s
- 2008 XLT Crew Cab 4x4, Tow Command, Camper Special, Monroe Gas-magnums A GOOD OLD FRIEND OFF TO A NEW OWNER
- 2002 F250 S/C 4x4 PSD, 4 inch turbo back, zoodad, pre-pump and tank mods, QLJ5/PMT1 Tipton Econotune, Sonnax/Tricumulator, ISSPRO under cubby mount gauges, Prodigy controller, 3.5 inch rear blocks, KYB Monomax Shocks...GONE BUT MISSED
- 1971 F100 Ranger XLT shortbed 4x4, 445 FE, hotrod resto
- 1970 Fastback Mustang, SEFI 489 cid FE, TKO-600 5 speed, 4.11 9 inch, ported KC alum heads
My427stang is offline
post #14 of 46 (permalink) Old 06-29-2011, 09:33 AM
line3500's Avatar
I voted major. So far 3 Oil coolers, rear end rebuilt at 1900 miles (factory flaw), DPF replaced at 8000, and with this last oil cooler also a complete tranny overhaul. since day one this truck has always been worked. so far 76k on the clock. I do oil every 5K and fuel filters every 10K. Truck always tows just below GCWR.
Alex Strand
2010 F350 6.4 DRW 4x4 FX4. Lariat ultimate package, homelink, 3.73 limited slip, line-x bedliner. white platinum metallic tri coat with 2 tone adobe and camel leather interior. Born on date: 09/2009 Delivered 5/27/10 with 43 miles
Currently 76K on the clock as of may 11'
Mods:
*Scan Gauge II
*CAT/DPF stock exhaust
*Recon cab, mirror, and fender lights
*High idle Mod
*20K Curt 5th wheel
*100 gallon aluminum flush mount fuel tank with direct fill into factory tank.
*Flush mount tool box
*Tinted windows
*Airlift bags on rear with compressor and 2.5 gal tank
Traded 2006 F350 SRW 6.0 Lariat, Loaded
*15K Reese 5th wheel
*110 gallon fuel tank w/ 18gpm pump
*high idle
*banks 4" dual monster exhaust.
*Ford OEM navigation 6CD audiophile radio.
*Dieselsite coolant filter.
American by birth, Teamster by the grace of God!
Teamsters local 399.
line3500 is offline
post #15 of 46 (permalink) Old 06-29-2011, 01:36 PM
lowerd96's Avatar
My Photos: (37)
I voted none, although I have had the radiator and steering box replaced.
47,450 miles as of my drive into work today...
Silver Metallic 2008 F-350 Lariat, Crew Cab, Long Bed, PSD, 4x4, Auto, MoonRoof, Medium Stone Leather, Heated Captains Chairs, Tow Command, Upfitters, Memory Group, Audiophile, Camper, Tow and Off-Road Package...Banks Monster Exhaust, 3.5" Icon Leveling Kit, Icon 2.0 AlumaSeries Shocks, 35x11.5 Toyo AT II's...
lowerd96 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
