Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-03-2006, 11:07 AM   #16 (permalink)
My Photos: (22)
Re: 6.4L Has Aluminum Heads!
The TorqShift is really two transmissions in one case. The front transmission has the OD gearset. It has two ratios, 1:1 and 0.71:1. The rear transmission has three ratios, 3.09:1, 1.538:1, and 1:1.
First gear is 1 x 3.09 = 3.09:1
Second gear is .71 x 3.09 = 2.20:1
Third gear is 1 x 1.538 = 1.538:1
Fourth is the one that isn't used much, it is .71 x 1.538 = 1.09:1
Fifth is 1 x 1 = 1:1
Sixth is .71 x 1 = .71:1
Basically it is a 3 speed tranny with a high and a low side to each gear. Each of the 3 gears uses both the low and the high side to achieve it's final ratio.
Just do a search on here going back a year or so and you will find some info. on it. Search something like "6 forward gears" in paranthesis.
00 S-10 Xtreme with SBC, ProCharger d-1sc with 3 core I/C at 18 psi.
03 hyundai accent-42 mpg
Red 05 f-350 6.0 4x4 s/c shortbed <font color="blue"> Truck Pic's </font>
ProCharger is offline
Old 10-03-2006, 12:17 PM   #17 (permalink)
Back on topic, the 6.4 may have the same aluminum piece that they bolt to the heads on the 6.0s. They have been doing that to reduce NVH emissions.
04/04 F350, FX4, 6.0, 3.73, 6sp.
1995 F150, 300 I-6, 3.31, 5sp
1991 L9000, N14 Cummins, 9sp (My Ford has a Cummins)
1978 Bronco, 6" lift, 460, 4.10, 4sp
1979 Ford TW 20, 1967 John Deere 3020, 1953 John Deere 60
OILBURNER350 is offline
Old 10-03-2006, 12:42 PM   #18 (permalink)
cut7's Avatar
Procharger is correct. It is a three speed with an overdrive used as a ratio splitter. What I don't understand is why Ford didn't spread out the ratios to make 4th (2nd * overdrive) more useful; at 60 mph the difference between 4th &amp; 5th is only 9%. That means that if your were going 2600 rpm in 4th, a shift to 5th would only drop you to 2385 rpm, not enough to be useful. What Ford should have done is made the 1st &amp; 2nd gearsets lower, then the ratios would be more spread out. An example follows:
1st = 3.94:1
2nd = 2.79:1 (3.94*.71)
3rd = 1.98:1
4th = 1.41:1 (1.98*.71)
5th = 1:1
6th = .71:1
This would give us 6 equally spaced forward gears. An added benefit is that 1st would be 27% lower (more grunt for pulling boats out of the water or a toy hauler up a steep incline) whilst maintaining the good highway mileage of a 3.73 rear end. It would be lower — by 15% — than the current first gear with 4.11 gears in the rear end (see chart below).
3.09*3.73 = 11.53
3.09*4.11 = 12.70
3.94*3.73 = 14.70
2006 F-250 CC 4WD King Ranch
2005 Excursion 4WD
cut7 is offline
Old 10-03-2006, 02:42 PM   #19 (permalink)
5-speed TorqShift automatic overdrive (all)
Gear Ratios
I 3.11:1
II 2.22:1
III1.55:1
IV 1.00:1
V 0.71:1
THIS IS WRONG . THE FOLLOWING IS RIGHT OUT OF THE FORD SERVICE MANUAL
FIRST 3.09 TO 1
SECOND 2.2 TO 1
THIRD 1.583 TO 1
FOURTH 1.096 TO 1 **
FIFTH 1 TO 1 **
SIXTH 0.712 TO 1 **
REVERSE 2.88 TO 1
** = SPECIAL OPERATING CONDITIOND DETERMINED BY PCM/ TCM IN TOW HAUL OR NORMAL MODE TRANS WILL SHIFT AS FOLLOWS BELOW 15 DEG C IT WILL SHIFT 1,2,3,5,6 IF ABOVE 15 DEG C IT WILL SHIFT 1,2,3,4,6 .THE TORQUE SHIFT DOES HAVE 6 GEARS BUT DOES ONLY USE 5 DETERMIEND BY TRANS OPERATING TEMP AND DEMAND OF THE TRANS SO FOR THOSE WHO SAY IT IS A FIVE SPEED THEY ARE PARTIALLY CORRECT . ALSO THE 6SPD ALLISON BEHIND THE DURAMAX ALSO SHIFTS THE SAME WAY
HOPE THIS CLEARS THINGS UP SORRY FOR THE CAPS JUST GETTING THE CORRECT FACTS ACCROSS
CHEERS GUYS [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1996 F350 2WD DRW CC BLACK BEAUTY STG1 160 CC INJECTORS , 3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM , AFE AIR FILTER IN STOCK HOUSING , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
FUTURE MODS ARE D66 TURBO FROM BEANS , SD INTERCOOLER MOD AND WATER METH KIT TO HELP LOWER EGT'S ON HILLS
2002 FORD WINDSTAR SPORT
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 10-03-2006, 02:57 PM   #20 (permalink)
Gear Ratios
I 3.11:1
II 2.22:1
III1.55:1
IV 1.00:1
V 0.71:1
These are correct for '05-'07.
Edit: copied these from my 2007 service manual:
1st: 3.114 to 1
2nd: 2.218 to 1
3rd: 1.545 to 1
4th: 1.096 to 1
5th: 1 to 1
6th: 0.712 to 1
Rev: 2.88 to 1
FIRST 3.09 TO 1
SECOND 2.2 TO 1
THIRD 1.583 TO 1
FIFTH 1 TO 1 **
SIXTH 0.712 TO 1 **
REVERSE 2.88 TO 1
These are correct for '03-04.
There was a ratio change for '05, and either the manual wasn't updated or you have an older one.
Casey_1 is offline
Old 10-03-2006, 02:59 PM   #21 (permalink)
Big K's Avatar
Send a message via ICQ to Big K
Ok, I think this whole thread is probably done.
It is WAY off topic now!
Big K is offline
Old 10-03-2006, 08:45 PM   #22 (permalink)
Probably my fault, but 1.09 vs. 1.00? Come on...who are we kidding. It's a five speed for all intents and purposes.
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFGs on 8" rims, 08 AlumDiffCvr, otherwise mostly stock.
24' fifth wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI
1969 Mustang Mach1, 377 clevor, R&P steering, 3.50 posi
69mach1377 is offline
Old 10-03-2006, 08:59 PM   #23 (permalink)
That's why Ford doesn't advertise that it's a six speed. It really has six ratios, but there are only five usable.
Casey_1 is offline
Old 10-07-2006, 09:46 PM   #24 (permalink)
The idea of changing the 3 ratios to make a useable 6 speed sounds good. I would not go as low as 3.94, more like 3.4, 1.7 and .85. That would space the gears evenly and end up with a .85 OD and a .60 OD. Would allow 4.30 gears for lower first and a reasonable 6th and 2000 rpm high speed cruising in 6th for 3.73 trucks.
To stay on topic, I've owned a few aluminum head engines and they all don't have guaranteed failure any more often than cast iron.
94 K1500 6.5
04 Honda CRF250
06 Suzuki DRZ 400SM
toyboxrv is offline
Old 10-12-2006, 12:46 AM   #25 (permalink)
They would have been better off spacing the gears or making 6th a second overdrive.
mtomac is offline
Old 10-13-2006, 12:21 PM   #26 (permalink)
klhansen's Avatar
My Photos: (92)
I agree. It has morphed into a tranny thread.
Time to start over.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
