Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 09-29-2006, 11:49 AM   #1 (permalink)
My Photos: (21)
6.4L Has Aluminum Heads!
I just received my copy of Truck Trend in the mail and on page 28 The specs for the 6.4L says alum heads...
After reading the article I really think this engine/Truck is gonna be awesome!
Why did they stay with the 5 speed auto and not upgrade to 6 like GM and Dodge?
Chris
1999 F-250 Power-Stroke
Crew Cab Shortbox Lariat 4X4
Fumoto, Turbo-Master, MBRP 4", Billet Triple Disc TC, HD TransGo Tugger, AIS, Triple Pod, Autometer Phantoms, SPDiesel Overboost Eliminator, SCT Tuned by Tadd @ Elite Diesel Performance 75/100/125 and DP-Tuner 80 Econo PCM, Sirius Radio...
2006 Jeep Liberty Sport CRD 4X4...
MY GALLERY
Tough_Guy is offline
Old 09-29-2006, 11:54 AM   #2 (permalink)
Re: 6.4L Has Aluminum Heads!
This is not true.
rlchv70 is offline
Old 09-29-2006, 11:58 AM   #3 (permalink)
My Photos: (21)
Re: 6.4L Has Aluminum Heads?
Typos are not uncommon in magazines....
Chris
MY GALLERY
Old 09-29-2006, 01:41 PM   #4 (permalink)
Not true. Iron.
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
16' American Hauler tandem axle cargo trailer
NRA Life member
Wobblin-Goblin is offline
Old 09-29-2006, 08:09 PM   #5 (permalink)
Chris
They are not aluminum heads. My god these writers are clueless. [img]/ubbthreads/images/graemlins/confused.gif[/img] This writer probably drives a prius. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] This is why i don't watch the doom and gloom senario that plays out on the evening news on a daily basis.
rc38 is offline
Old 09-30-2006, 09:38 AM   #6 (permalink)
Chris
the torque shift is a 6 speed auto but only uses 5 this is determined by the computer and trans operating temps as well as loads it has been this way since 2003
1996 F350 2WD DRW CC BLACK BEAUTY STG1 160 CC INJECTORS , 3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM , AFE AIR FILTER IN STOCK HOUSING , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
FUTURE MODS ARE D66 TURBO FROM BEANS , SD INTERCOOLER MOD AND WATER METH KIT TO HELP LOWER EGT'S ON HILLS
2002 FORD WINDSTAR SPORT
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 09-30-2006, 12:12 PM   #7 (permalink)
Big K's Avatar
Send a message via ICQ to Big K
Yeap, Heads aren't Aluminum, they are IRON [img]/ubbthreads/images/graemlins/wink.gif[/img]
Big K is offline
Old 10-01-2006, 05:27 PM   #8 (permalink)
Aluminum heads isn't really a bad thing. Everyone thought it would be a problem with the duramax but I'd say that it has been proven with high hp and torque numbers.
1969 Ford F-250 Camper Special 360 V8 4 speed
1998 Ford Explorer XLT 4X4 4.0L V6 124K
Stock. Daily Driver
2001 F-350, Ext Cab, LB, XLT, 4X4, 127k
K&N Filter, Walker BTM, Edge Evo
B99 Biodiesel.
2004 F-250 6.0, CC, SB, Lariat, 66k, BFG 285 A/Ts
Stock.
CWU 2010
01F350PSD4x4 is offline
Old 10-02-2006, 06:36 PM   #9 (permalink)
klhansen's Avatar
My Photos: (92)
I had a Dodge minivan with a 2.5L 4 cyl in it that had an aluminum head. Replaced the head 3 times on it because of problems. According to the mechanics, if you went over 80,000 miles you were due to have problems with the heads. With cast-iron blocks and aluminum heads, the expansion rate is different, and the head tends to "creep" in relationship to the block. Eventually you get a blown head gasket at best. If you overheat them, the head is usually toast.
Like the other poster's said, that magazine writer was putting out bogus info.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 10-02-2006, 06:58 PM   #10 (permalink)
I looked this up on the Motor Trend website out of curiosity and ended up finding something else I found interesting. It was a spy photo of an F350 SRW CC with what was supposed to have a V6 4.5 liter turbo diesel sourced from International with much improved fuel economy. I'm new to this site, has anyone else heard anything about this?
2005 F250 6.0 PSD CC torqueshift,XLT,FX4,white, rubber floors, tow command,spray-in bed liner, Weathergaurd rv tool box, Weathergaurd PakRat tool box, Michelen HD floor mats, Rack-it lumber rack, Fumoto valve, XM, Pop-Up G/N hitch, 62,000 miles already!
1994 KDX 250
2001 TTR 225
2003 Honda Recon
1999 PW 50
1988 KD 80X
jwoops69 is offline
Old 10-02-2006, 07:28 PM   #11 (permalink)
Well the 4R100 was a 4 speed, so 5R110 is a 6 speed? Doesn't make sense since the 4 = 4 speed, R = Rear axle drive, and 100 = 1000 Newton-meters of trq rating = 738 ft-lb to us Americans.
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFGs on 8" rims, 08 AlumDiffCvr, otherwise mostly stock.
24' fifth wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI
1969 Mustang Mach1, 377 clevor, R&P steering, 3.50 posi
69mach1377 is offline
Old 10-03-2006, 09:43 AM   #12 (permalink)
My Photos: (22)
[/ QUOTE ]I assure you there are 6 forward gears. If my memory serves me correctly the actual 4th gear is a 1.08:1 ratio and actual 5th gear is 1.00:1 while the 6th gear is OD. As said before, the computer decides which "4th" gear to use in acceleration while both "4th" gears are not used sequentially.
00 S-10 Xtreme with SBC, ProCharger d-1sc with 3 core I/C at 18 psi.
03 hyundai accent-42 mpg
Red 05 f-350 6.0 4x4 s/c shortbed <font color="blue"> Truck Pic's </font>
ProCharger is offline
Old 10-03-2006, 09:54 AM   #13 (permalink)
procharger you are right thanks for clarifying it CHEERS [img]/ubbthreads/images/graemlins/smokin.gif[/img]
drford is offline
Old 10-03-2006, 10:05 AM   #14 (permalink)
Re: 6.4L DOES NOT Have Aluminum Heads!
Let me see if I can get this erroneous thread title to change in the thread listing...
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
frobozz is offline
Old 10-03-2006, 10:37 AM   #15 (permalink)
5-speed TorqShift automatic overdrive (all)
Gear Ratios
I 3.11:1
II 2.22:1
III1.55:1
IV 1.00:1
V 0.71:1
2001 White Lariat 7.3 Auto CC LB 4X4 -- Mods -- K&N Drop in, JP Chip, 06/6.0 Intercooler, 4" Magnaflow Exhaust, BTS Tranny, 3 gauge A piller pod. Kennesaw Mountain Accessories Rear and Front “Wincher” Bumper, Warn 16.5Ti Winch, Suspension: Tuff Country 2" front and 3" rear, Toyo MTs 305s on 10s, 285,000 miles!!
05 White XL 6.0 Reg Cab 4X4 104,500 miles!!
06 White 6.0 CC Lariat 4X4 Auto LB: Kennesaw Mountain Accessories Front “Wincher” Bumper, Warn 16.5Ti Winch, Fabtech 8" lift, 35 Toyo M/Ts 75,651 miles!!
06 White F150 4.2 Reg Cab LB 2wd 40,500 miles!!
---07 Shelby GT500--- Performance White Vert-- Mods-- JLT Intake, 2.6" upper & 10% IW Lower Pulleys, AFCO Duel Pass Heat Ext., American Racing Long Tube Headders, Full 3" Magnaflow Exhaust, Evolution Stage 4 Tune, BMR Carbon Fiber Drive Shaft, Steeda UCA & LCAs Currie 9" 1:3:75s True-Trac locker, Proglass Cold Air Hood, 17,500 miles---11.984 1/4 mile! 592RWHP
mobeydick is offline
