ABS TCS Problems - Diesel Forum - TheDieselStop.com
Old 11-16-2009, 09:40 PM   #1 (permalink)
ABS TCS Problems
I have been experiencing a sudden shudder or perhaps what may be a slipping that results in my TCS going off. If not, I turn it off and problem usually stays away. Sometimes when this happen I get an ABS light and a slippery vehicle icon on the message display. I turn off the tcs and that usually but not always stops the problem from recurring. After a few minutes, perhaps as long as 10 to 15 minutes the ABS light goes out and all is fair until the next incident.
When I turn on the key I get a "check brakes" message for an instant which goes out. I took it in and they said no error codes and tried as much as they could to replicate the problem but could not. I took it home went on another trip pulling my fifth wheel, but the problem continues to recur sporadically.
Any thoughts?
7.3 99.5 550 Lariat Fontaine conversion, auto leveling airbags, auxillary transferflow midship tank, fiberglass bed,liner, 25K pullrite hitch, Diesel Innovations six way chip,pillar gauges, 4 inch exhaust. SOLD
08 f-450 4X4 LARIAT 4.88 Dark Shadow Gray to match my Mobile Suites fiver. Line-x, 0503 Pullrite 25.5k superfifth hitch, Retrax rollcover, 50 gal transferflow under cover aux tank, aftermarket pioneer avicz2 nav to come,
larryhutto is offline
Old 05-17-2011, 05:09 PM   #2 (permalink)
1badf250's Avatar
Any thoughts?
Been having the same problem.... the vehicle icon comes on. sometimes the truck shakes/vibrate. iam not getting any codes or anything. tcs light blinks too. 2008/F350 Stick shift. 6.4 . it has a 6 inch lift & 37 inch tires on it.. it was fine before i lifted. no tire pressure sensor on the new wheels. but i do have a Edge performance + monitor.
any 1. ?
2004 F250 Crew Cab 4x4 6.0
160k still going strong
05-07 Face lift
4" Lift on 20x12x35's
-Autometer boost gauge
-autometer Pyrometer gauge
-Banks 6 gun + speed loader
-k&N intake
-Runs on B-100
1badf250 is offline
Old 05-17-2011, 09:43 PM   #3 (permalink)
senix's Avatar
Check the batteries, see if they are going to lunch. Maybe the cause for the lights.
As for the shakes with the 6" lift..did you re-angle your driveline after the lift?
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is offline
Old 05-18-2011, 01:13 AM   #4 (permalink)
1badf250's Avatar
Unless the shop I got the truck lifted at (4wheelparts) knew to do that . No I did not .
My edge juice is acting up too. It's freezing. It's like all the sensors go dead . It freezes for a min. Or sometimes until I turn off Tue truck . I'll try to check the batteries . My alternator just went out last week n the shop that fixed it didn't mention anything.. aNd it only shakes when the hazard light goes on Tue tcs blinks
05-07 Face lift
-k&N intake
-Runs on B-100
1badf250 is offline
Old 05-18-2011, 06:06 AM   #5 (permalink)
senix's Avatar
Look at the carrier bearing. They should have used a spacer or something to help to bring the driveshaft back to a proper angle.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
