AC compressor relief valve - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 07-10-2012, 09:50 AM Thread Starter
My boss's truck, '09 F-250... he's having problems with some kind of relief valve relieving freon from the system. Changed the relief valve with no results... seems as if it's doing what it's supposed to do and relieving excess pressure. Any ideas why?
2014 F-350 Platinum SRW LB Ruby Red Metallic
2000 F-250 Lariat PSD 4X4 Auto CC SB 350,xxx miles, 4" Super-Lift/Fierce Attitude M/T LT31575R16's
Tymar intake, 4" turbo back MBRP exhaust, AIH delete, AC mod, ISSPRO gauges, PHP HYDRA, FFD Single Shot Stage 1's, FrX, Hutch/Harpoon Mods, Monsterbox Tranny, Tru-Cool Max
AE in Lafayette, La vicinity...
bmcnabb02 is offline
post #2 of 16 (permalink) Old 07-10-2012, 10:12 AM
chuckster57's Avatar
There is no "pressure relief valve" on an Auto A/C system. There is a low side switch and maybe a high side switch. Both of these are screwed onto threaded ports on the refrigerant lines. There should be an O ring that seals them so refrigerant doesn't vent to the air ( Leak). I would be looking for a missing O ring first, and then possibly a bad switch.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 16 (permalink) Old 07-10-2012, 10:27 AM Thread Starter
Then what's this?
2009 FORD F-250 SUPER DUTY Parts - Tousley Ford Parts Depot
post #4 of 16 (permalink) Old 07-10-2012, 10:38 AM
fireguywtc's Avatar
it maybe a pressure relief valve of some sort, but it is NOT venting into the atmosphere. There must be a leak somewhere else.
2012 F350 Lariat ultimate 6.7 PSD LB CC SRW Fx4,
67 F-250 Project truck, currently in a billion pieces
70 F-250 4x4 (highboy)
Past trucks: 07 F-350 xlt 6.0 PSD LB CC SRW 4x4, black on tan, A/T, 5" exhaust w/4" downpipe, SCT livewire
Traded in 04 F-250 xlt 6.0 PSD SB extcab 4x4, 6spd, all stock and 97 F-250HD xlt 7.3 PSD extcab LB 4x4, 5spd, Superchips tuner, 4" turbo back exaust, K&N CAI, 02 intercooler installed, Sold
fireguywtc is offline
post #5 of 16 (permalink) Old 07-10-2012, 10:54 AM
RT
RT's Avatar
There are pressure relief valves - always on the high pressure side - some models have them on the low pressure side as well. Here's a glossary site for those interested - A/C MOBILE
The two reasons most people wouldn't be aware of these is that there is a high pressure switch that should shut the compressor off before pressures reach the point where the valve would blow. The second reason (my opinion) that people wouldn't want to believe these things exist is why would you vent the freon after everything people do to prevent venting freon. Its a safety device - nothing more.
Now the question becomes - why would this thing be leaking? Especially a second one. It would have to be either a defective valve, a defective installation (or something wrong with the mount), or something causing these uber-high pressures to be realized. Before the OP's boss goes and just throws another one on, someone needs to do some real diagnostics to find out why the pressures are getting that high (if that is indeed why it is leaking). I would suggest starting with some dye and getting some good pressure readings. Make sure the valve is leaking from the relief port and not from the o-ring.
RT is offline
post #6 of 16 (permalink) Old 07-10-2012, 11:32 AM
I guess I learned that today
Train Horns:
post #7 of 16 (permalink) Old 07-10-2012, 02:08 PM
fireguywtc's Avatar
and if the relief valve is indeed working as inteneded my statement above is incorrect according to the AC site you listed above. It appears that the relief valve DOES vent into the atmosphere. However, it also seems to be a last resort safety in a defective system. I would be interested to know what pressure that relief valve operates at.
I learned something today also!
post #8 of 16 (permalink) Old 07-10-2012, 03:30 PM
The high side pressure needs to be checked. Usually these relief valves, when equipped, has opening around or a bit above 400psi. The fan clutch needs to be checked and check the air path through the cooling stack for bugs and debris.
The programming runs fan a bit when stopped and when road speed is low. If the high pressure switch on high side line closes fan operating duty cycle is increased for more fan speed. The fan operation should have a code if codes are read out if that is the problem. If the condenser is blocked then fan could work fine and still have a/c high press go too high and relief do a dump.
The engine would be running hotter than normal but you'd not know due to the "we're scare to tell the truth" gauge system Ford has used for a coupe of decades (not that you might be able to tell that I have an issue with gauges that are not much more good than a warning light...).
2015 F350 Platinum Max Tow What a beast with the 4.30 gears! 2006
F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 141K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
2002 F350 CC DRW flatbed (originally pickup bedded) rebuilt & upgraded 4R100 208K miles
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 164K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 247K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #9 of 16 (permalink) Old 07-10-2012, 05:08 PM Thread Starter
Good info, I just found out he had it in the shop for this today and they replaced the switches, and then the fan clutch. Thought they had it fixed, but it started doing it again. I'll advise him to check for air flow restrictions.
Thanks.
post #10 of 16 (permalink) Old 07-10-2012, 06:30 PM
ford_doctor's Avatar
An A/C pressure relief valve is incorporated in the A/C compressor to prevent damage to the A/C compressor and other system components by relieving unusually high system discharge pressure buildups. On this particular system the valve opens at 550-600 psi.
Obviously the refrigerant system is building too much pressure which is why it is venting. The system contains two pressure switches. A compressor clutch cycling switch and a high-pressure cutoff switch. This switch is used to interrupt A/C compressor operation in the event of excessively high discharge pressure in the high-pressure side of the refrigerant system. The PCM monitors the contacts in the high-pressure cutoff switch. When the high-pressure cutoff switch is open, the PCM will disengage the A/C compressor clutch.
You need to understand that the PCM is actually in control of supplying power to the clutch by controlling the clutch relay. The high pressure cut off switch is monitored by the PCM. With that said, you have an electrical concern. Checking the PCM for codes is actually a good place to start as your concern could be the high pressure switch, the wiring or a faulty clutch relay... least likely but still possible... the PCM.
There is also the chance that the compressor clutch is locked as well. With the engine off and the FEAD belt removed the compressor pulley should spin freely and smoothly.
Good Luck!
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #11 of 16 (permalink) Old 07-11-2012, 09:12 AM Thread Starter
Thank you!
post #12 of 16 (permalink) Old 07-21-2012, 09:37 AM Thread Starter
Update,
Still an ongoing issue, but the same shop that replaced the switches and changed the fan clutch has completely tore the system apart and found the in-line filter (wherever that is) full of aluminum shavings. So now they are replacing the compressor & the accumulator.
I guess if they change enough parts they'll eventually fix it. lol
post #13 of 16 (permalink) Old 07-21-2012, 09:49 AM
RT
RT's Avatar
One would hope so - unfortunately, if they don't change enough of them at once - you'll be back where you started. Aluminum shavings would almost have to be from the compressor. From there, refrigerant gets pushed into the condenser where the gas liquefies. From there through the "filter" which is built into the orifice tube - from there to the the accumulator / drier.
So - if they don't flush the condenser adequately - which is almost impossible to do - you'll get a fresh spray of aluminum shavings heading for the orifice tube the first time you turn the a/c on.
RT is offline
post #14 of 16 (permalink) Old 07-21-2012, 12:59 PM
fireguywtc's Avatar
agreed. ask them to replace the condenser. Its in the neighborhood of $250 and is well worth the piece of mind in this scenario.
post #15 of 16 (permalink) Old 07-21-2012, 01:24 PM
That is not a filter, it is the fixed orifice tube which has a screen on both ends. it is cleanable depending on the type of debris it collects. If the compressor has in fact failed then the advice to replace the condenser core is wise. The lines can be flushed. The receiver dryer, evaporator and low pressure line are for the most part protected by the screen on the orifice tube and can be reused.
I still think that you have an electrical concern because the high pressure cut off switch is supposed to prevent the system from reaching the pressure required to open the relief valve in the first place. That is why the switch is sometimes referred to as a "refrigerant Containment Switch.".
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
