Acceleration Problems - Diesel Forum - TheDieselStop.com
post #1 of 26 (permalink) Old 01-03-2009, 12:29 PM Thread Starter
westin06's Avatar
Send a message via AIM to westin06
I apologize if this topic has already been discussed but I got a problem with my 08' F350 Diesel. I am new to diesel trucks and don't know to much about it all.
A little bit of background information. Its a catering truck, on the road 7 days a week most weeks, 5 of those days is on from 6am -1pm. Anyways, we had a factory defective radiator replaced a few months ago, and now this new problem has arrived. Last week, I had no power on acceleration at all. I had the pedal floored and couldn't get above 40. Hour of letting it sit, it was back to normal. Still took it to the dealer to have them check it out, and do standard oil change etc. They couldn't find anything wrong or duplicate the results. Well today, the problem came back. The engine light is on, as well the "wrench" symbol. I talked to several ford dealers who offered no help, including the one where we have it serviced. I called a local truck stop mechanic and he said it sounds like the fuel filter is bad, and that I should replace it and add a diesel treatment/fuel additive.
This is my business. I can't afford to be down a week while they mess around and tell me nothing is wrong with it?
Anyone able to help? The mechanic I talked to, told me the fuel filter is an easy fix and told me what to do.
westin06 is offline
post #2 of 26 (permalink) Old 01-03-2009, 01:20 PM
The fuel filter fix is easy to do, but I'm not certain it would cause your wrench icon to light. If you have a problem with your fuel filters, I think it might cause other problems (e.g., hard starting or maybe surging?) I believe your problem is elsewhere although I am new to diesel trucks myself, so my knowledge is extremely limited.
BTW, there are two fuel filters in our trucks, and they're usually replaced in pairs. Dieselfiltersonline.com has them for a reasonable price.
timid1 is offline
post #3 of 26 (permalink) Old 01-03-2009, 01:38 PM
Stymie's Avatar
when changing your fuel filters, if the engine is not primed properly then it will turn the wrench on. However if the poster is getting engine lights, the truck is storing codes. And a dealer should be able to pull them. Dont take the dealers bs about they cant fix it.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
post #4 of 26 (permalink) Old 01-03-2009, 02:13 PM
Thanks Stymie. If that's the case, then priming can be done via the instructions in the owner's guide (purging air, correct?) Thing is, if he's never touched the fuel filters, then he shouldn't need to perform that procedure?
Anywho, take it to another dealer! :-)
timid1 is offline
post #5 of 26 (permalink) Old 01-03-2009, 07:02 PM Thread Starter
westin06's Avatar
Thank you guys for your comments. I went outside to start it up just to check on it. Engine light is still on, no "wrench", however is now saying "drive to clean exhaust system"? Will driving the truck as recommended in the owners manual of above 40 mphs fix the problem? My worry is I cannot get the truck up to speed to properly clean the exhaust system.
westin06 is offline
post #6 of 26 (permalink) Old 01-03-2009, 07:15 PM Thread Starter
westin06's Avatar
I have not touched anything yet...
2008 Ford 6.4L Diesel F350 Dually
2005 Ford 6.0L Diesel F250 Lariat
2003 Ford F350 V10 Dually
westin06 is offline
post #7 of 26 (permalink) Old 01-03-2009, 10:40 PM
Stymie's Avatar
my point was that fuel system issues and fuel starvation can cause a light.
a plugged Filter can cause sluggish driving, just get it out on the highway, for about 15-20 miles.
17x9 Pro Comp 7189
Stymie is offline
post #8 of 26 (permalink) Old 01-04-2009, 01:41 AM Thread Starter
westin06's Avatar
Alright, I took it out for a drive and I think I finally found out whats wrong with it. It drives normal at first, however, when it goes into "cleaning exhaust mode", thats when I lose all power. I cannot get the truck to go above 40, I lose all power. I stalled out going up a steep upgrade. Just to confirm this, I let the truck sit for a few hours. Came back out and drove her home, and again, ran normal and then the "cleaning exhaust mode" came on and the same affects came on. I am 100% convinced this is the problem.
Now the question is, What caused this? I am going to take it to the dealer monday, but chances are again, they will not be able to duplicate the results, just as it wouldn't a week ago when I had it serviced.
westin06 is offline
post #9 of 26 (permalink) Old 01-04-2009, 07:16 AM
I had exactly the same thing happened on my job 2 350 , bought it to the dealer about 3 times before they can find the trouble, it was something related to the trottle plate (drive by wire ) so they replace it and since then no problem at all with my truck. hope this could help.
M.B.
renegade600sdi is offline
post #10 of 26 (permalink) Old 01-04-2009, 01:53 PM
Fuel starvation as Stymie said, but now I'm curious if it's just a "side effect" of a cracked/plugged (i.e., damaged) DPF. I don't really believe it has anything to do with your fuel system to begin with, but we are all just here to help, so that's ok.
Nice truck, BTW. Beautiful color! Same as mine! :-)
timid1 is offline
post #11 of 26 (permalink) Old 01-04-2009, 02:43 PM Thread Starter
westin06's Avatar
When I took it out, I did not have one single engine light, or wrench light come on. I got an appt. in the morning with the dealer. I will keep you guys updated on what they say.
I love the color. Every single truck of mine has had a dark blue color. Added the grill guard to it about a month ago. Westin grills are excellent and have on every vehicle I own. I have an extra grill guard for a 08 f350 that westin sent me defected and never took it back. One of the bars that go over the headlight assembly was bent in during shipping. Might be a good deal if you are interested and can slowly un-bend the bars.
westin06 is offline
post #12 of 26 (permalink) Old 01-04-2009, 08:25 PM
1970Cyclone's Avatar
There is a TSB concerning loss of power (skipping) in the 6.4.. Something to do with several bad wiring connections. My truck had the same issue as yours (intermittant loss of power) I got it back on Saturday, so far so good.
1970 Cyclone Spoiler 429CJ,
1970 Cyclone GT 429CJ,
1979 E150 Van (Daily Driver)
Jayco Designer Fiver, 36'
GOT IT!
F350 4x4 (FX4) Lariet, Diesel, 3:31 E-Locker, Lariet ultimate package, Oxford White / Adobe, Hitch Prep, 18's.
SOLD!! 2008 F350 Superduty Lariat 4x4, Built 4/23/07. Let someone else have that piece of crap.
Traded: 2005 F350 SuperDuty Lariat 4x4 Crewcab LWB.
1970Cyclone is offline
post #13 of 26 (permalink) Old 01-04-2009, 09:51 PM Thread Starter
westin06's Avatar
What exactly is a TSB? I want to be sure to tell the dealer tomorrow morning everything mentioned on this forum.
westin06 is offline
post #14 of 26 (permalink) Old 01-05-2009, 12:10 AM
Technical Service Bulletin. They put one out for various things that need to be fixed (e.g., venturi tee, software flashes, etc.)
timid1 is offline
post #15 of 26 (permalink) Old 01-05-2009, 12:26 AM
Stymie's Avatar
you should experience a decrease in power during a regen(cleaning exhaust) but not to the degree you are talking about. your dealer should be able to hook up to the truck and force it into regen to attempt to duplicate the issue. press the fact that this happened in traffic, and is a huge safety concern, as your truck stalling causes a loss of control functions(steering, brakes) if they dont budge, call ford customer service.
17x9 Pro Comp 7189
Stymie is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
