belt chirp when cold?? - Page 2 - Diesel Forum - TheDieselStop.com
Old 01-02-2008, 09:22 PM   #16 (permalink)
Re: belt chirp when cold??
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jarhead98</div><div class="ubbcode-body">amazingly...i have noticed the last couple of mornings, the belt chirp is almost gone. i can barely hear it now? maybe it's getting worn in or something. </div></div>
Hey Marine,
Did you ever spray silicone on the belt and/or pulley?
Or, have your local weather conditions changed, as in gotten warmer?
I remember you indicated pouring water on the pulley or belt to make the noise go away. Have you done this only once, or have you repeated the process over and over to eliminate the chirp?
2008 F250 Lariat CC 4X4 Off-Road 6.4 PSD / Job2 - (Took Delivery On December 20th, 2007)
2005 F250 Lariat CC FX4 Off-Road 6.0 PSD - (Stolen From My Driveway On 11/6/2007)
2003 Aquasport 201 Osprey w/ Yamaha150
2005 Haulmark 16' V-Nose Tandem Axle Work Trailer
DieselJambalaya is offline
Old 01-03-2008, 11:06 AM   #17 (permalink)
bdmcd15's Avatar
no silicone...the temps here around dallas are very erratic!! it has been as cold as 19F in the mornings and into the 70's in the afternoon. i poured water on it several mornings in a row, but got sick of it and stopped doing it. it still has a very slight chirp if you listen real close, but not near as bad as it was.
08 F250 4X4 CC LARIAT, RANCH HAND FRONT BUMPER REPLACEMENT W/PIAA DRIVING LIGHTS, 70 GAL AUXILLARY FUEL TANK.
07 KEYSTONE LAREDO 5er
"Real men don't LOL"
bdmcd15 is offline
Old 01-03-2008, 01:00 PM   #18 (permalink)
I brought my truck to the service dept. yesterday, and they could hear it chirping and squeaking; hell, everyone could. A couple of people came up to me and said, "That Looks Like A New Truck." I said, "Why, It Is!" "Sounds Great, Doesn't It?" "It Has Just Over 500 Miles On The Odometer." Although, I did tell these folks, other than the annoying chirp and squeak, I really do like the truck.
Fortunately, I will only have to wait until this Tuesday, which is when the appointment is scheduled to get it in there to hopefully eliminate the problem.
Old 02-07-2008, 10:28 PM   #19 (permalink)
OTP
I have a chirp and am told it is a pulley and they are waiting on parts. Turned it in on Tuesday and called today for an update to be told that the tech was waiting for a bay. I have a small leak on the drivers side that felt oily and I thought maybe a tranny cooler line, but they say radiator and between the two I can expect to get it back on Monday.
Very disappointing to say the least. I also have the whine in the rear end and the Drive Shaft was replcaed per the TB and it has not helped any. Advisor says they are waiting on tools to inspect the diff.
If I get it back with the diff problem still there, I will take it to a dealer with a commercial dept, as this dealer is clueless. I would just pull it now, but my luck the radiator would fail 100% if that is what the leak truly is.
I understand new things have bugs, but the way the dealer explains things, makes it worse. I sometimes wish I would have kept my 01 250, as it never caused me an issue.
OTP is offline
Old 02-11-2008, 02:57 PM   #20 (permalink)
Mine just started doing it after 13000 miles. Reminds me exactly of my 04 F150 5.4 3V. It started squealing on cold startup. After replacing the belt, a time or two, they discovered that they needed to shim the water pump if I am recalling correctly. In any event, whatever they shimmed fixed the problem which wasn't a belt or pulley.
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Sequoia is offline
Old 02-12-2008, 10:32 AM   #21 (permalink)
bdmcd15's Avatar
well...mines back at it again. annoying squeak at cold start up....guess i'll be taking it in.
bdmcd15 is offline
Old 02-18-2008, 10:16 AM   #22 (permalink)
ive got almost 18000miles now and mine is still squeaking on startup. im in southwest houston and its not that cold. maybe was 45 this morning. i dont mind that it squeaks, but my last ford never did it once in 12 years. its one thing for an older well used vehicle to do that but a NEW $40-50K truck shouldnt have that issue with no sollutions (or this is what dealer says)
bdmcd15, let us know what they say about it at the dealer.
2008 F250, 6.4L PowerStroke XLT, Crewcab, 2wheel drive.
txmike is offline
Old 02-18-2008, 07:08 PM   #23 (permalink)
About 7k on mine since the belt and idler pulley were replaced...still no squeak (knock on wood).
Jason
2008 F250 Lariat, 4X4 Off Road, Snowplow Package, Nav System, Tow Command
1995 F150 5spd 4x4
jss304 is offline
Old 02-09-2010, 03:22 AM   #24 (permalink)
Banned
Thumbs up Belt Chirp when cold
Its not Ford...its the Ford Mechanics and Fix-it System...Hee, Hee
Hey Men of the new Diesel World...
My Late 08 F250 KR...began Chirping in the cold morn about 5K miles ago. Finally stop by a Ford Dealer(The last place you wanna go...Hee, Hee) and pulled the TSB. Got lined up to change one of the idler pulley's right?...Well, to get to this pulley you have to remove all the 7 or so heat exchangers and take out the Fan while your at it. About a 3 hour job to change the pulley and belt. I looked on while Arron did the work. Let me see now? 300 dollars labor to change a 50 dollars worth of parts. Yea! no that is a good deal...for Ford shops all over Ford Nation. I wonder what Ford Engineers were doing when Navistar was designing the gu-dee-grah? The even worst thing to imagin is that there is no wher else to go to buy a good Diesel.
Well...to make a long story short, my chip fix did not work...its chirping worst than ever. This is only a sign that i, super diagnostic m;an will have to fix it myself(This is what i get for being retired). Yep the service mgr...says, well? bring it in and we'll look at it. Yea! like I like my truck disasymbled twice a weak by incompident messchanics. They already had their chance...and like there is no gig to rig up on the engine to test it...its just 3 hours of labor every time you get a earg to take a crap...
Good luck on yours folks...i am fixing my own next week and i will pass it on, on what i find.
DieselBudlite is offline
Old 02-09-2010, 09:14 AM   #25 (permalink)
Shinny's Avatar
I had my idler pulley replaced under the TSB 15,000 miles ago and not a chirp since. It took them a few hours to pull the coolers, replace the pulley/belt and put it all back together again.
'08 F250 FX4 6.4L Super Duty Crew Cab SB Silver Metallic & Dark Shadow Grey Job 1
Extang Trifecta Bed Cover,
High Idle Mod,
Spray in Bed Liner
second radiator
EGR Valve replaced
100% Stock
Shinny is offline
