6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Just curious if anyone has binding from the rear axle when starting off and making a tight turn left or right (seems worse to the right). Truck is in 2WD, just had LR caliper replaced as it was seizing up and had ruined the pads and rotor (rusty orange) on the LR side.
RH side rotor and pads look OK, but I'm going to have them changed at next service, in a couple of weeks.
Thoughts?
Not sure if the truck has posi or limited-slip, if that's what I am feeling or not. 104k highway miles on it.
It's done it since I bought the truck with 99k on it, I figured it was the caliper binding on the LR side, but after replacing the caliper, it didn't go away...
Did the PO put a locker in it? Sounds like the Detroit that's in my Jeep
'94 F250 IDI 4X4 5 speed. New to me in '03. . "A" pillar gauges ATS Turbo upgrade 3" down pipe & exhaust, Baby Moose IP, "BB" injectors, coolant filter and PS intercooler.
1975 CJ5 AMC 360 Boxed frame, shackle reverse and sprung over, YJ springs, Twin stick D20 with D18 low range gears, NP435 Waggy axles 538 gears, on board air, welder and shower, GM throttle body injection
If you think its your posi unit i would go and buy two little bottles of Ford limited slip additive and pour those two bottles into your rear diff. The stuff is green and smells nasty but it's the best stuff out there for a loud rear end. I've used it on all my rear ends in my cars and trucks and it works great and it only cost about 5 bucks a bottle from ford.
RIP 2008 CC LB 6.4...Rolled 3.5 times and walked away with only 4 scratches....Brand new 2010 F-350 CC LB 6.4 Lariat SRW, Camper package, Snow plow, dual alternators, cab lights, Back up camera and tail gate step, Rhino lined box, 6 inch pro comp lift kit, 35"x 12.5 toyo Mt tires, Buckstop outback bumper, 12000 warn winch, 4 lightforce driving lights on bumper, Spartan tuner and dpf delete with 4 inch mbrp exhaust, Winter studded cooper tires...stock size.
FYI, most people add TOO much of the friction modifyer, when you do use it, add just enough so as to quiet any chatter, but its a good thing that you can feel it SLIGHTLY when going around corners. Add just a bit at a time, test drive and add some more if necessary.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
