6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
i just bought and 08 6.4 and was just wondering where the block heater cord would be, and if i dont have one wheres it connect to the block at? thank you
2008 f350 diesel cc lb 4x4 lariat, every option, 5% tint, leveling kit, harley 20s, hideaway strobes, western 7.5 pro plus
1999 f250 reg cab xlt 4x4 v10
sold- 06 F350 6.0 , auto, cc lb xlt, 4x4, sunroof, leveling kit, turbo back dual exhaust no mufler, sct livewire, accufab inlet elbow, Harley Davidson 20's w/ Nitto terra grapplers
You don't have the cord. You will have to install it yourself. You can get the cord off ebay or from any local heavy truck, dodge dealer or tractor/farmstore. The cord is the same one used on the cummins, cat, detroit diesel and so on. It is the most commonly used plug. If you have a local heavy truck shop they will have it. This is what it looks like Dodge 89-09 Cummins Diesel Block Heater Cord 5.9l 6.7l:eBay Motors (item 160366180240 end time Oct-29-09 18:55:07 PDT) Get two bags of 3/8 loom from walmart and a roll of electrical tape. Put the cord in the loom and tape the entire length. Under the truck above the starter you will see the head of the heater. The plug plugs in and the collar screws down, you can do this by hand and a hand wrench. The cord should be zip tied to the bottom of the starter/battery cable. The underside of the wire to protect it from the exhaust manifold. Just zip tie it every 6inches along the way to the battery cable. Once you get to the front of the truck zip tie it to the trans cooler lines and at the front of the truck tuck it above the frame rail and out the opening for the tow hook. I put a little grease on the copper plug (to stop corrosion) contacts. Done. Plug it in and listen for a little hissing sound from behind the passenger tire. You should be golden. Most run it for 3 hrs before they leave in the morning. You can do this with an normal appliance timer from walmart. It took me less then 15min on my 6.4... If this is your daily driver get yourself a winter grill cover. The truck will run better and warm up faster with it. It will cost you about $80 online (pt# 8C3Z-19A414-A). You won't need it until mid Nov till early March. I will not put mine on until late Nov. Don't bother trying to get it from your local dealer they will try to charge you list price. Good luck
...as i think about it, it may have been an ordered option by the original owner. You can take a look and see if it is there. They usually have the plug around the passenger tow hook but it is faster to see if the orange block heater end exists. Climb under the truck and look above the starter. You will see the steel plug for the block heater sticking out of the block. If there is an orange end plugged into it then you have the cord. If not then you don't have it. You may also take a look at this link Diesel Technician Society
Good for you. I guess the previous owner thought ahead a little.
Is the oil leak in the same location that the 6.0 was famous for? Most of these engines have that "hanging drip" on the center bottom section of the transmission bell housing.
