6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Question. I have several bottles of Cetane booster left over from my 02 Diesel. Can I use it in the new 08. Thanks.
2008 F350 SRW CC Lariat,6.4,20 inch wheels, Spray in Boxliner,Retrax Roll top cover, Bluetooth, Warn Transformer with M12000 winch and SST Cover,HID Lights, Dual 150 watt Daylighters.5 inch Magnaflow exhaust. etc.
Because it does make a difference here especially in the winter.
It should say on the back of the bottle, whether it's certified for use with ULSD,I know all bottles of Power swevice Diesel Kleen I have bought for the last 8 months or so say it's compatible.
__________________ 2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
How much of the cetane do you use per fill up or per gallon of fuel? I am getting my truck back after EGR cleaning, turbo replacement, EGR cooler replacement, new head gaskets. The EGR valve was all gummed up. After doing some research on fuel additives found that Cetane was very important for engines that had EGR'S. Have you used cetane since day one ?
2003 F550 XLT
6.0 Diesel built May 7,2003
4:88 rear end
Leather interior
chariot tow body
air ride
74 gallon diesel transfer flow
Oct 5,2005 Flash 347A-12A650-FVF 28k miles
trailer saver air hitch
35' New Horizon 5th wheel
prodigy brake control
The bottles I get from Ford say they treat 125 gallons. Don't have the bottle in from of me, but believe it is 6 oz per 25 gallons. There are hash marks on the bottle though.
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Here's what the Cetane Booster & Performance Improver lables say on my bottle which I use in our 99.5 7.3 and have since the new ULSD came out earlier this year:
"Stock Number PM-17-A * FIR No. 174524"
"4 oz of Cetane Booster treats 25 US Gallons of diesel fuel." (20 oz bottle treats 125 gallons as mentioned by Sequoia)
"This diesel fuel additive does not comply with federal untra-low sulfur content requirements for use in model year 2007 and newer diesel motor vehicles or model year 2011 and newer diesel non-road equipment engines"
Everything else are cautions to not use it in mixed drinks along with emergency numbers and First Aid Treatment in case you do. [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img]
That rating is ok. I was just asking if the additive helped. Next time I fuel up I am going to look at the specs on the pump.
2003 F550 XLT
4:88 rear end
Leather interior
chariot tow body
air ride
I also bought two bottles of Cetane booster from Ford.That's what I'm using right now. The service Dept suggested it will help because of the ULSD. The shop foreman says it has an additive in it that helps.
I don't know where everyone is getting their info, but ULSD has a natural Cetane index number of about 3 to 5 higher than LSD. I don't know why it would be as low as 40, but the refinery I worked at put out 46. If it is below 45, I would use Cetane improver.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 231,000 miles. Uses no oil between changes.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mountie</div><div class="ubbcode-body">I also bought two bottles of Cetane booster from Ford.That's what I'm using right now. The service Dept suggested it will help because of the ULSD. The shop foreman says it has an additive in it that helps. </div></div>
Here's a little tidbit of info for you about Motorcraft diesel additives....
There are 3 flavors: (used to be only 2, Red or Blue caps) PM-17-A (<span style="color: #CC0000">(Red cap)</span> Cetane booster and performance improver for 6.9 7.3 & 6.0 engines PM-22-A <span style="color: #CC0000">(Red cap)</span> ULSD compliant Cetane booster and performance improver for 6.4L PSD (backward compatible as well, and will replace the 17-A in the near future) PM-18-A <span style="color: #000099">(Blue cap)</span> <u>Anti Gel</u> and Performance Improver (cold weather additive) ULSD compliant and compatible with all Ford diesels 6.9 - 6.4
Forgot to mention that I have used the 17-A in my 6.0 for over 50,000 miles. The stuff works great, less cleaning of the EGR and actually a slight improvement in MPG (almost 2MPG). I put about 6oz of the stuff in at fillups from empty.
A lesson learned: this stuff really stinks, is hard to pour the first half without spilling some and is hard to wash the smell away. I portion out 6oz into little containers we use at work for oil samples, and carry those in the door pouch.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jhughd</div><div class="ubbcode-body">What cetane rating are you trying to achieve in the fuel. The pumps where I fuel say it contains a cetane rating of 40. What does Ford suggest?
JD </div></div>
Ford recommends a minimum cetane rating of 45 for the PSD's.
__________________ '04 F-250 Harley-Davidson 6.0L CC SB
