Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 02-25-2008, 09:30 PM   #1 (permalink)
Clatter at 3000 rpms or so when shifting
My 08 F-350 has 10,300 miles and other than a new radiator and squeeling belt when cold it's been great.
I have an unusual noise when the engine is at around 3k rpms and shifting, almost sounds like a metal flap fluttering of some sorts. It sounds like two pieces of metal lighweight in nature flapping really quickly. Took it to the delaership a few months ago and they said they can hear it, but can't find it. They put some sound deadening material around the firewall or so I'm told, but it's certainly still there. Almost sounds as if it's coming from the rear of the engine near the firewall. Only makes the noise when accelarating rapidly and at higher r's generally while shifting or right before.
jarepackard is offline
Old 02-26-2008, 01:48 AM   #2 (permalink)
Stymie's Avatar
its the truck dropping fuel pressure, to pull power between shifts, or that is the way my diesel tech father explained it.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains
Try the SEARCH Button
Stymie is offline
Old 02-26-2008, 05:00 AM   #3 (permalink)
U joint?
Have them check the u joint at the steady bearing. My last ford I had to change them a couple of times and the noise would come and go at certain RPM's under certain loads. Get them to put the Chasis Ears on it and check that.
Rob
08 6.4 F350 SC LB DRW
dirtyharry is offline
Old 02-26-2008, 01:14 PM   #4 (permalink)
Stymie's Avatar
i doubt the clatter is a ujoint, if its only at a certain rpm, in every gear.
the ujoint is going to spin faster in every gear than i did in the previous. If you roll your windows down, you'll hear the clatter.
17x9 Pro Comp 7189
Stymie is offline
Old 02-26-2008, 05:38 PM   #5 (permalink)
Does it happen all the time? I was told by a Ford Diesel mechanic today that when they go into the REGEN mode they will make a "clattering" noise.
stewie2 is offline
Old 02-26-2008, 08:12 PM   #6 (permalink)
Stymie's Avatar
mine gets worse during regen, that is how the wife knows its doing one
17x9 Pro Comp 7189
Stymie is offline
Old 02-27-2008, 05:18 AM   #7 (permalink)
Normal stuff.. Mine get's that as well when accelerating sometimes..And others have reported this as well.
I can't explain what's causing it but someone mentioned fuel rails or oil pressure related..
08 F350 Lariet DK.Blue/Silver CC Short Box SRW. Auto transmission, Manual 4x4,Supplemental Cab Heater,3.73 Limited Slip.Gator Guard Bedliner, 6.5 x 12 Sno-Pro,8ft. Fisher.
04 Lance 820.
Light Trucks I've Owned Before
02 SuperDuty Super Cab Lariet Auto 7.3 4x4
01 SuperDuty Super Cab Lariet Auto 5.4 4x4
99 Dodge Ram Extended Cab Larime Auto 5.9 4x4
93 Dodge Ram Regular Cab Larime Auto 5.9 4x4
88 Chev Blazer 5.7 4 Speed 4x4
85 GMC 2500 Regular Cab 5.7 4 speed 4x4
70 Chev 1500 Regular Cab 292 Straight 6 4 speed 4x4
74 Blazer 5.7 4 speed 4x4
Captcaper is offline
Old 03-03-2008, 08:12 PM   #8 (permalink)
I listened for it today and all I can tell you is that is the sound of "making horsepower" I did hear it when on the throttle.
stewie2 is offline
Old 03-03-2008, 08:52 PM   #9 (permalink)
Not normal, unless in regen. During regen, the intake throttle may make that type of noise.
Keep pressing your dealer to fix. It may be the HP pump due to a restrictive return line. If it is, then you will eventually fail the pump.
rlchv70 is offline
Old 03-06-2008, 03:12 AM   #10 (permalink)
what do you guys think about the Wastegate opening and closing under peak boost.....you did say under full throttle i think....IMO........
***Shipping sucks @$$ when you Live in Hawaii!***
kona_built is offline
