Code P0087 - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 01-24-2011, 11:13 AM Thread Starter
Code P0087
Today here in North Jersey temps got to -5, Fuel jelled up restarted with Diesel Power 911, Code p0087 came up low fuel rail pressure reset all seems fine could this have been caused by the fuel jelling up.
nailz53 is offline
post #2 of 14 (permalink) Old 01-24-2011, 11:19 AM
I felt like I could chime in on this one. Not that I have the answer to your question but I too have only had one code thrown on my truck and it was the P0087. My truck is in the shop right now been there for about a week now and from what it looks like it's the HPFP Gasket that they are going to have to replace, something about the wires that run in that gasket they get crossed or short out or something like that. Which is why there telling me I received the code. Hope this helps, I'll let ya know what they actually ended up doing when I get it back with the work receipt.
2010 F350 SRW 6.4L FX4 LARIAT
2011 28' Toy Hauler Attitude 5th Wheel 11,900lbs
BigDaddyF350 is offline
post #3 of 14 (permalink) Old 01-24-2011, 11:26 AM Thread Starter
Thanks I hope Thats not it .got to drive to Florida tomorrow.
nailz53 is offline
post #4 of 14 (permalink) Old 01-24-2011, 11:32 AM
To the OP: It does not get that cold where I'm at but what you're saying does make sense. Drive the vehicle and see how it does.
Big Daddy: Was your truck a crank, no start? When the HP fuel pump harness chafes on the pump it causes a BJB fuse to blow. If the harness shows no signs of chafes I end up replacing the HP fuel pump (if all other pin point tests pass).
Gofaster23 is offline
post #5 of 14 (permalink) Old 01-24-2011, 12:34 PM
No my truck runs fine 90% of the time it was throwing the code from time to time here is the weird part. It would throw the code initially it was the P0087 and I would get a loss of power they couldln't figure it out so they gave me the truck back and said inconclusive it will have to do it again and then hopefully it will throw more codes. (I know) So anyway I get it back a few weeks go by and check engine light comes on n loss of power take it in this time it throws same code in addition to both Low Pressure Fuel Valve code and High Pressure Fuel Valve code yes both codes at the same time threw them through a real loop. So how ever you look at it they still have my truck but initally when I droped it off they told me it looks like the gasket and it is possible that it could be the entire HPFP.
post #6 of 14 (permalink) Old 01-27-2011, 03:30 PM
canadian brickie's Avatar
When mine threw that code it was a cab off HPFP replacement and new wiring harness replacement at the same time, truck was down for a week.
08 F450 King Ranch DRW 4X4 Edge Evolution Factory Nav/DVD all the bells and whistles Love My Truck
07E350 XLT
06E350 XLT
03E350 XLT
04F350 Lariat
99F350 Lariat
99F150 XLT
95F150XLT
90F150 XLT
canadian brickie is offline
post #7 of 14 (permalink) Old 01-27-2011, 04:29 PM
luke0204's Avatar
Mine threw the P0087 the other day when it gelled at ~ -15. Quit on me three times on the way to work, got to a place to get 911 after the second stop. Cleared the code with my Insight and has been fine ever since...except it's ready for a set of fuel filters.
Got the same code when my old Duramax gelled on me a couple years ago.
2011 F350 CCSB, 4x4, 6.7L, 3.31 E-Locker, MBRP 5" DPF Back, Innovative Torq 2
Past Toys:
2012 Ram 3500 CCSB, 4x4 6.7 Cummins, G56 6 spd
2011 F-250 CCSB, 4x4, 6.7L, 3.31 E-Locker
2009 F-250 CCSB, 4x4, 6.4L,Torqshift, Spartan
2009 Dodge 2500 QCSB, 4x4, 6.7L Cummins, 6 spd,
2007 Chevy 2500HD Classic, CCSB, 4x4, Duramax LBZ, Allison 1000, 4" MBRP Cat Back, Diablosport Predator, Edge Insight
2005 F-250 CCSB, 4x4, Torqshift, 4" Cat Back
2004 F-250 CCSB Fx4, 6spd, Bully Dog Intake, Banks 4" turbo back, Edge Juice
2002 F-250 SCSB, 6spd, AFE Intake, ATS Turbo Back Duals, B&D 60hp chip
luke0204 is offline
post #8 of 14 (permalink) Old 01-27-2011, 04:51 PM
Yes looks like that's what there going to do to mine and it's been a little over a week!
post #9 of 14 (permalink) Old 01-27-2011, 09:46 PM
yes, p0087 will set when fuel is gelled.
djshum is offline
post #10 of 14 (permalink) Old 01-30-2011, 05:47 PM Thread Starter
Pulled into Florida this afternoon, Truck ran fine no code
nailz53 is offline
post #11 of 14 (permalink) Old 02-01-2011, 01:10 PM
Alright fella's after two weeks I just got my truck back. Looks like they replaced the following items:
1 8C3Z-9A543-B PUMP ASY-FUE
1 8C3Z-9G805-B COVER- FUEL P
1 8C3Z-6N640-B GASKET
2 8C3Z-6N640-A GASKET
1 7C3Z-6L612-B GASKET
1 8C3Z-9T514-C KIT HARDWARE
-1 8C3Z-9A543-B CORE RETURN
Does anyone know why it says a minus or (-1) in front of that last item?
They guy wasen't there when I picked it up but the paragraph on my paperwork basically reads that they were still unable to re create the problem I was saying I was haveing and they called Ford for permission to do the above parts replacements and so they got approval and took care of it. I've only had it a half a day and so far no issues. I did notice the huge mess they left under the hood. I mean seriously there is fuel everywhere. I need to take it to the car wash and get it all washed off so that it dosen't do any more damage potentially or just become an issue later because I can't tell if maybe there was a leak or something because of the darn mess that it looks like now.
I'll post more after I've hooked up the 5th wheel for the first time and hopefully no hiccups
post #12 of 14 (permalink) Old 02-01-2011, 08:18 PM
-1 is indicating that there is a core on the pump, and that the old pump has been turned in for core credit. It is subtracting the core allowance from the repair bill.
djshum is offline
post #13 of 14 (permalink) Old 09-01-2015, 10:03 PM
I have an 08 f350 with a 6.4 and the truck was running fine then went into limp mode we pulled over shut it off for 2 minutes restarted it then it ran fine for about 25 miles then same thing codes are P0087 and P0088 any help
olyellow is offline
post #14 of 14 (permalink) Old 09-01-2015, 10:27 PM
Uh oh... Pull your filters and look for shards..
drewactual is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
