Without the Speed Brake, the only thing the Tow Haul mode does is eliminate the OD gear. If your coming down a hill and take your foot off the accelerator, the truck and trailer will actually increase speed rather then slow it down. So to maintain your speed, you would need to constantly apply or tap the brake as your descending. If the road is relatively level or a slight grade, then it will actually slow you down and walk through the gears. Otherwise, hang on tight.
There was a great article in the 4WheelParts magazine a few months back. You can read it in the following post,
Exhaust Brake for 6.4L
Scroll down to "TECH - Testing the Banks Speedbrake" and the first part describes testing without the speed brake and how the truck and trailer behaved.
Long story short, truck and trailer weighed approximately 18500 lbs, 6% grade with truck at 55 Mph at the top of the descent. Truck approached 70 Mph twice and required operator to apply brakes to maintain speed.
Now a bit about the Speed Brake itself. If you have the Speed Brake from Banks, there are 3 settings you can use to slow your truck down.
- Brake On
- Speed Control
- Interactive
The Brake On mode will start to slow you down the moment you lift your foot from the accelerator and will continue to slow you down all the way to first gear.
The Speed Control mode will require you to have a preset speed entered into the system before hand, default is about 50. Like before, it will begin to slow you down the moment you lift your foot from the accelerator and will continue to slow you down until it arrives at the set speed. At this point, it will maintain this speed +/- 2 MPH until you activate the accelerator again.
The Interactive mode will do both the above so long as your foot has activated the brake pedal. In other words, it will only activate if you are touching the brake pedal.
For an unladen truck, the third option is by far the best. It allows you to use the speed brake for everyday driving as well as use the cruise control.
For a loaded truck, I like the Speed Control method the best. Think of it as cruise control for your trailer.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
