6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
My Dad was on his was back home from a long trip back east and his temps started going up. He pulled over and checked the coolant and it was low. He thought it was coming from the radiator so he topped it off and got back on the road.
He checked it 100 miles later and it was only a little low so he decided to keep it topped off and head on home. When he got to Flag it started running rough and he lost all boost.
He call for a tow truck and we had to run another truck up to Flag to get the trailer. The dealership had the engine torn down and confirmed it blew a Head Gasket and all the cylinders are scored and the turbos are shot.
They have a new engine on the way and the truck should be ready for pick up in a week. My Dad has another move back east and is going to use old faithful (his 95 with over 600K miles on it).
He new truck has about 80K miles on it although this truck has been worked hard it has never been abused and is maintained very well. Looks like some of the 6.0 issues are still around
If you live in AZ come join us at Arizona Powerstroke Group... Click here http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 BTS Trans / Termys / Swamps 200/30 AA Injectors / Swamps IDM / GT38R BB Turbo / AFE Stage 2 / DP/ Evans Coolant, ART Rotors / Dynatrac Spin Free HD Front Hubs, 4 inch Stainless Exhaust, Auto Meter Cobalt Gauges.
not what i wanted to hear bc mine just puked some coolant out to and was just going to start a thread about it. $hit.
1991 YJ
Dad has a 2004 6.0L all stock.
1960 CJ5 all stock
1987 F-250 XLT lariet 6.9L [img]/ubbthreads/images/graemlins/cool.gif[/img] 3.55 limited slip, 4 speed, auto meter pyro, Napa water temp and oil pressure, 344,460KM on her. Injector pump rebiult at 255,000 KM Here are some pics of her
I'm a little skeptical that it blew a head gasket. More likely it had a bad radiator, which lead to an EGR cooler failure. The tech could have misdiagnosed it as a head gasket.
The radiator that is in the truck was just replaced less then a month ago with the new and improved one.
From what I've heard, a new radiator doesn't mean much. One can blow in a month. I hope he didn't run it hot and fry the head gaskets that way. With cast heads, that would be difficult unless you were oblivious- and I'm sure your Dad is not.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
I would bet it is related to a radiator failure. And I don't think there is any new and improved radiator, only a little vent or something you can install in one of the lines that is supposed to fix the problem.
If his truck went into a regen without a good supply of coolant I could see how something devasting like this could happen.
Cannot speak for the one above but, I can speak for my buddies.
My buddy has an 08 F-350 that just blew the head gasket. He was pulling his enclosed with the racer in it. He was loaded down pretty good but, nothing extreme. After about 2 hours in the mountains, poof, head gasket gave in. I sure hope Ford got smart after the 6.0 issues with the bolts.
Guns don't kill people, people kill people. Take our guns away and then the law biding folks are screwed. All the criminals will be armed.
2004 F250 with an 2003 6.0 in her, Dick Cepek Black DC1 Wheels, 315 75R BFG's, SCT X3, 4" DP, 4" exhaust w/ kitty, 5" tailpipe, 6" Fab Tech Lift, MX 6 Shocks, K&N CAI, Awesome Tunes by Eric at Innovative, DVD,135K (Nov 11)
1967 Chevy C-10 step side, 383 stroker, Holley 750, TH400 w/stall, 6/4 lowered, body shaved, gas tank relocated... and many more.
We haven't seen any head gasket failures with the 6.4 - I will temper that with a "yet" though I will admit that this has been Fords best ever diesel launch....
As for the radiator conumdrum.... Ford now has us installing a venturi tube at the time of radiator replacement - I am led to understand that pressure spikes in the cooling system are to blame for radiator failures. Sorry, I don't have the TSB handy so you'll have to take my word for it....
As for the radiator conumdrum.... Ford now has us installing a venturi tube at the time of radiator replacement...Sorry, I don't have the TSB handy so you'll have to take my word for it....
It's not a TSB, its a Special Service Instruction (SSI) 08T01, and Special Service Message 20339.
2008 F250-550 6.4L DIESEL RADIATOR REPLACEMENT VENTURI TEE INSTALLATION
SOME 2008 F-SUPER DUTY 250-550 VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE MAY REQUIRE A RADIATOR REPLACEMENT. AFTER FOLLOWING WORKSHOP MANUAL (WSM), 303-03 AND THE RADIATOR HAS BEEN IDENTIFIED AS THE CAUSE OF THE COOLANT LEAK AND IS TO BE REPLACED, IT IS NECESSARY TO ALSO INSTALL THE RADIATOR/VENTURI TEE SERVICE KIT 8C3Z-8B379-B. USE THE INSTRUCTION SHEET PROVIDED WITH THE KIT FOR PROPER INSTALLATION OF THE KIT.
EFFECTIVE DATE: 07/14/2008
Since you have decided that we shall not mince words...
08T01 is a Field Service Action..... This is Ford-speak for a recall.... The term "special service instruction" isn't something that get's used a bunch - even though TSBs (technical service bulletin), SSMs (special service message), Broadcast Messages and Field Service Actions could ALL be considered as special service instructions....
One might have to pardon my oversight.... I try to make sure we run OASIS on everything that comes through the shop... Unlike some, I do not have the spare time to spend trying to embarass or emphasize the shortcomings of other participants....
It is when we run OASIS that we can discover any "open" recalls on a particular unit.... These will show no matter what we input as "concern codes". To see any particular TSBs or SSMs we need to input "concern codes"... this could be as simple as any DTCs retrieved during testing... or it could be more general (there are several drop down lists for rather generic concerns).
Broadcast messages are rather tenuous.... akin to an "interoffice memo" they will sometimes turn into a TSB, SSM, a change in service manual(s) or something similar.... Occasionally a broadcast message will include the instruction " engineering is aware of the concern - do not attempt repair at this time". Obviously, engineering is scrambling to find a cure that works without costing megabux.
Gooch... if you would spend half as much time being productive as you do trying to embarass me. TDS might have something... Give it a rest before you "have the big one".
Relax Grampy and take the information I posted for what it is. If I wanted to "embarrass" you, I would've done a much better job. You "embarrassed" yourself by trying to explain yourself with all that rambling.
I'm simply helping owners out here...if they take your advice and look for a "TSB" for this, they're going to be disappointed.
SSI-08T01 is a SSI - Special Service Instruction, not a TSB.
SSM 20339 is a SSM - Special Service Message, not a TSB.
FSA (Field Service Actions), Recalls, TSB (Technical Service Bulletins), BCM (Broad Cast Messages), SSI (Special Service Instructions), SSM (Special Service Messages), and whatever else you want to discuss are not one in the same...they all have their special purpose at Ford. You, the master of sarcastically criticizing others here, should know that. As for OASIS, SSI-08T01 clearly states, "you must use OASIS to determine if a vehicle is eligible for this Special Service Instruction."
Give it a rest Grampy. You should've taken the information in my post for what it was. TDS could do without your babbling.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
Grampy- you have been the most useful source of info on this site. There are some other good sources (Ford Doc), but you seem to be present more often. This site would suffer greatly if you got upset and left. Please feel free to ramble on as much as you want- I'll read every word.
HighwayPrisoner and torino73, did you find Grampy's TSB?
