Days to replace radiator? - Diesel Forum - TheDieselStop.com
Old 11-14-2009, 12:31 PM   #1 (permalink)
compman72's Avatar
My Photos: (9)
I thought Job 3 trucks were safe from this problem, but I guess not.... One thing to note I had the venturi T from the factory not a recall fix.
For those of you that had the radiator replaced, how long does it take? I am at 33,000 miles and mine has started leaking. So I am going to make the appointment to get it fixed.
Where mine is leaking is on the lower drivers side at the seam where the aluminum is crimped to the plastic end. I just noticed it on Friday when I was getting ready to leave as I just loaded the truck with parts to go on a job.
Other notes on the leak is after I noticed it I wiped it clean and then drove it home and after 6 hours of the truck sitting - everything still dry. This morning go out to look at it and crap a drip on the frame horn. My thinking is when the radaitor is hot it's not leaking cause it is hot and expanded. When it cools the leak opens up.
Have any of you gotten a loaner vehicle at no charge for this warranty repair?
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
compman72 is offline
Old 11-14-2009, 01:18 PM   #2 (permalink)
My truck would do the same thing. When i brought it in for the leak they did a presure check and it did not leak they said it was ok, when i picked it up ther was a puddle of coolant under truck ,got the tech to come out and look at it and oh the radiator has a leak (no s--t thats why i brought it here). Had to order a radiator once they got it in it they only needed on day to do it, Good Luck
nailz53 is offline
Old 11-14-2009, 01:21 PM   #3 (permalink)
compman72's Avatar
My Photos: (9)
I guess I should take a picture with the camera as evidence and proof.
One thing to note - when they pressured it up and it did not leak - was the engine hot?
08B07 Flash 1-16-09
Old 11-14-2009, 01:52 PM   #4 (permalink)
I just had my radiator replaced right at 36,000 miles, ford had it for 5 days, it took so long because they had a 6.0 radiator in stock but thought it was for a 6.4 so they had to order me one in
2008 f350 diesel cc lb 4x4 lariat, every option, 5% tint, leveling kit, harley 20s, hideaway strobes, western 7.5 pro plus
1999 f250 reg cab xlt 4x4 v10
sold- 06 F350 6.0 , auto, cc lb xlt, 4x4, sunroof, leveling kit, turbo back dual exhaust no mufler, sct livewire, accufab inlet elbow, Harley Davidson 20's w/ Nitto terra grapplers
<a href="link" target="_blank"> title </a> http://community.webshots.com/user/salnazzaro
salnazzaro is offline
Old 11-14-2009, 04:21 PM   #5 (permalink)
sameolething's Avatar
Mine started leaking at 28k.
Took 5 days also. They had to order the radiator.
sameolething is offline
Old 11-14-2009, 07:53 PM   #6 (permalink)
dieselmankane's Avatar
What job trucks do you guys have?? I have a job 3 and am really hoping to avoid the radiator problems.
2003 F250 Super duty 6.0 PSD, was great in the beginning, but started to have major issues:
Traded, Oct 2 2008 for...
New truck: 2008 F250 Superduty Lariat 6.4 PSD Job 3, black, with ALL the goodies, very impressed so far...
[SIGPIC][/SIGPIC]
dieselmankane is offline
Old 11-14-2009, 08:00 PM   #7 (permalink)
One day if they have it in stock.
2008 F-250 Lariat 4x4, 6.4L, 4 tires, brakes, windshield, windshield wipers, tailgate, bumpers, blinkers, headlights, spare tire, rear bumper, hood, antenna, driver AND passenger seats, speedometer, radio, steering wheel, & spare set of keys!
Hydro is offline
Old 11-14-2009, 08:15 PM   #8 (permalink)
HARLEYF2502005's Avatar
had mine replaced at 12300 miles rite after the venturi tee tsb was done ..then at 12311 when i got home and noticed it leaking from where the tech put a hole in it during instalation... mine also a job 3 have 17500 on it now
2008 F-350 DRW BLACK LONG BED
2005 f250 harley package(sold)
2008 keystone montana 3400rl
2001 ktm 50 lc pro( SOLD)
2005 custom rigid chopper
HARLEYF2502005 is offline
Old 11-14-2009, 09:55 PM   #9 (permalink)
I am a mechanic in pipeline construction and we have several 6.4s. Takes about 2 hours drive up to drive off, unless youre in a hurry. We can't have our trucks at the dealership for even a day so we replace a lot of parts covered by warranty. Gas fuel pumps, power steering pumps, radiators and such. Our engines are running about 3,000 hours run time in 25,000 miles. That's an average speed of 8.3 mph. Compared to my personal 6.0 that has 100k at 3,000 hours. If you do you,re own, pull the intercooler, the upper core support, intercooler pipes, peel the other coolers to the side, remaining 2 bolts out of the bottom half of the shroud, upper and lower radiator hoses. Other then the lower shroud bolts all this is done standing in front of the pickup.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0
'06 40' prairie schooner 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'88 F350 Crew SRW (now parts)
'85 F7000 mechanic service, 3208na CAT
'97 Aerostar 4X4 Extended 4.0
'93 Sable 3.8
'92 Taures 3.0 sold
'84 Bronco II 2.8 4 speed 4X4
'84 Ranger 2.8 2X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
Old 11-14-2009, 10:21 PM   #10 (permalink)
I was really hoping Job 3 trucks avoided the rad problems. I haven't heard of as many rad problems with the job 3 trucks though.
[SIGPIC][/SIGPIC]
Old 11-14-2009, 11:29 PM   #11 (permalink)
Mine is a job 3. 28k radiator replacement. Going on 37k now and dry as a bone so far.
Old 11-14-2009, 11:31 PM   #12 (permalink)
compman72's Avatar
My Photos: (9)
Mine is proof that they (Job 3) are not immune to the leak free radiator.
08B07 Flash 1-16-09
Old 11-17-2009, 04:11 PM   #13 (permalink)
changing the radiator takes a total of 45 minutes its super simple. in fact i think the job only calls for like an hour and a half
SVTwannabe is offline
Old 11-17-2009, 04:50 PM   #14 (permalink)
compman72's Avatar
My Photos: (9)
Thats good news. I will be taking mine in after I get back home. I spoke with the parts department at the dealer and they have one in stock and two on order.
08B07 Flash 1-16-09
Old 11-17-2009, 08:04 PM   #15 (permalink)
45 minutes? I don't know about that. The service writer told me when they did my radiator it was half day tear down and half day reassemble.
I'm not a mechanic, but looking at the radiator and all the stuff that needs to come off just to get to it, seems like a longer job than 45 minutes.
Don't get me wrong, you may be right. Like I said, I'm no mechanic.
