Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 03-26-2007, 11:12 PM   #1 (permalink)
Diesel fuel additive required for 2008 Super Duty?
Is a diesel fuel additive/treatment neededed for the new 2008 Super Duty engine?
timskitoo is offline
Old 03-26-2007, 11:58 PM   #2 (permalink)
Re: Diesel fuel additive required for 2008 Super Duty?
No. The emissions strategy on it is not the one using urea solution added to a tank periodically.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.88 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 feet on the floor Elite/Outlaw LQ horse trailer. Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
Old 03-27-2007, 09:52 AM   #3 (permalink)
I know this. I have had a few mechanics tell me, and read in more then one (non-advertisement) article in a few trucking publications, to use a lubricating additive.
There is so little lubricant left in this new ULSD fuel, that premature wear has already been reported. Injectors and seals, so I have been told, are taking the brunt of this new fuel.
Now don't flame me, I am just repaeating what I have been told by more then a few mechanics, in different regions of the country. And I know my 2007 Volvo, with a non emmision 2006 530hp Cummins, runs better with a gallon of Howes additive. Which I seem to use allot of now. Never used to, even in the winter. I have never been a fan of additives other then water seperators in the coldest northern weather.
And this new ULSD also starts to gell at 34 degrees. I know this first hand. In 17 years, I have never had a truck gell up on me until this winter. I was down for 4 days, that is how long it took to get it towed into my local shop to thaw her out. My mechanic said he had never in his life seen so many frozen trucks.
Thanks EPA!
localnet is offline
Old 03-27-2007, 10:08 AM   #4 (permalink)
OneTonHillBilly's Avatar
I was told exactly opposite as far as additive. The new motor is supposedly designed to use ULSD. My 6.0 is supposed to use additive. Mine is not specified as ULSD.
We have has ULSD here in OHIO and New York where I travel weekly all winter. My truck has sat out in -10F not plugged in. Needs warmed up but fuel never gelled.
*2007 F-350 CC*
HG's
EGR Cooler
3 Degas Bottles
Driver & Passenger Seat Leather
Trailer Brake Control System
Steering Wheel & Controls
Driver and Passenger Window Assemblies
Steering Column and Gear Shift
All Emblems Twice!
Shocks
OneTonHillBilly is offline
Old 03-27-2007, 10:41 AM   #5 (permalink)
No additive needed.
rlchv70 is offline
Old 03-27-2007, 10:51 AM   #6 (permalink)
The 6.0 does not require additives..but can be used...nowhere have I read that it "requires" it..I used Power Service often in all my diesels....it does help..runs smoother and seems to have a little more pep....can't find stanadine in the local area....my.02
'04 F-250 Lariat CC LWB 2wd 6.0 Torqshift Dark Satin Green/Arizona Beige TRADED
07 F-250 Lariat CC LWB 4x4 6.0..Dark Stone/Arizona Biege Built 11/27 here on 12/06/06 picked up on 12/07/06...love the truck.....pictures soon...
http://community.webshots.com/user/khitch710
khitch710 is offline
Old 03-27-2007, 11:10 AM   #7 (permalink)
Dae
The process to remove sulfur from diesel removes lubricity from the fuel. So it's not the sulfur that lubes.
As for needing additives, It's up to you. Although lubricate is suppose to be added to ULSD to make up for the loss during the desulfuring process, can we trust it's enough??
BTW, this applies to all diesel motors not just the 6.4 since fuel pumps, injectors and most everything else needs the lube until the fuel is burned.
- Dae
Dae is offline
Old 03-27-2007, 01:07 PM   #8 (permalink)
I'm pretty sure that my 6.0L manual specifically stated NOT to use any fuel additives.
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 03-27-2007, 01:12 PM   #9 (permalink)
I don't use additive. That is just what I have been told. Diesel is $2.85 here and I fill up every 2 days so I am not spending more than needed.
*2007 F-350 CC*
HG's
EGR Cooler
3 Degas Bottles
All Emblems Twice!
Shocks
Old 03-27-2007, 02:08 PM   #10 (permalink)
Never used any additive in my 6.0 and at 75K, it's still running strong. I don't think it will hurt the engine either. I just never felt the need in any of my PSD's. My 01, 7.3 I used to own has over 300K and never had any additives.
JD
08, 6.4, F-350, torqshift, SRW, lariat, 4X4, LB, CC, Pueblo gold (Built the week of 04/09/07)Arrived 4/24/07 brought home 4/26/07
http://rides.webshots.com/photo/2919...01044415MSbgrF
jhughd is offline
Old 03-27-2007, 03:05 PM   #11 (permalink)
Dae
JD
How much of that 75K was on ULSD?
- Dae
Dae is offline
Old 03-27-2007, 03:57 PM   #12 (permalink)
Not much. But people have been "needing" additives ever since there were diesels. Maybe now there is a real need for them, don't know. I know a lot of people said the 6.0 would do better with additives and maybe they were right, I just never had any problems with not using it.
JD
jhughd is offline
Old 03-27-2007, 05:04 PM   #13 (permalink)
The Ford maintenance video on this site, a while back stated Ford recommends using fuel with a cetane rating of 45 in the 6.4. The vidoe then went on to tell you that Ford just so happens to sell a perfromance enhancer/cetane booster for use in the 6.4.
What does the manual for a 6.4 state?
Navy Mustang, (E1-E7/01-O5) Still kickin.
2004 F-250,CC,SB,FX4,LARIAT,FIRESTONE AIR SUSPENSION AFT, TRIPLE PILAR MOUNT GAGES, LOW PROFILE COMBINED TOOL/FUEL BOX, SUPERGLIDE UNDER BODY MOUNT AUTO SLIDE 16k HITCH
Truck GONE, red oak used it as a bed!!!
IF IT WAS EASY...ANYONE COULD DO IT!
CV67Cheng is offline
Old 03-27-2007, 05:28 PM   #14 (permalink)
Thanks EPA!
I've already had my truck in below freezing weather (upper teens overnight) with no gelling issues. The temperature was below 30 degrees for 10-12 hours with the vehicle cold. And no this was not winterized diesel.
PHXDiesel is offline
Old 03-27-2007, 08:03 PM   #15 (permalink)
It is true that the new ULSD has caused more "gelling" than what we all used to burn. However, we have learned here in our Northern Nebraska farm and ranch market, that what appears to be a gelling issue with ULSD is actually an icing problem. something about the process of taking the sulfur out of the fuel causes it to have more water in it at the pipeline and therefore at the storage facility, in your truck, or your barrel at the shop. We have over 40 medium duty diesel trucks on the road all winter delivering fuel and propane and we saw more problems with ice in the filters and fuel lines than we ever have before this new fuel came along. As for lubricity additives, Ford's own liturature ( at least on my 7.3) lists Stanadyne as the only approved additive. Mine started last Feb at -11 with no plug in and straight ULSD #2 with Stanadyne in the tank. With #2 puching the $3 mark here, the additive is cheap if it even gives a small improvement in effeciency.
'99 crewcab, shortbox, 6 speed, 4" exhaust, custom AFE air intake,PPIII, pre pump and tank mod, HX mod, 2002 Jayco Talon 30 ft. sport utility travel trailer.
99beast is offline
