Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 02-24-2008, 08:21 PM   #1 (permalink)
Does your engine rev up in park?
When my truck is parked idling for longer than 1 to 2 minutes, it revs up to around 800 - 1000 rpms. Is it supposed to do this? Thanks
2008 F250, Black w/ Stone. 6" lift w/ 37" tires, 20" KMC Wheels.
jaredther6er is offline
Old 02-24-2008, 08:25 PM   #2 (permalink)
yes this is your truck trying to keep the oil pressure up to keep oil to your turbo and it is also warming your truck up but completely normal
1999 f350 build date 2/99, red, ts 6 position, banks compressor turbo wheel, banks big head wastegate, mbrp 5" with 6" grand rock stacks, diy tymar, Zoodad mod, AIH plug UPCOMING MODS: , stage 2 injectors,Stage 2 water meth injection, 95 gph fass fuel, 6.0 intercooler, ballbearing turbo, 6.0 trans cooler, and arp head studs.
fast99f350 is offline
Old 02-25-2008, 12:20 AM   #3 (permalink)
When the temperature is cooler, the motor will assume a higher idle to warm faster.
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Sequoia is offline
Old 02-25-2008, 04:43 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Yes. In cold weather.
Part of the computer program that controls your engine is a subroutine called the cold ambient pkg (CAP). When the oil temp and the intake air temp (IAT) are cold enough, the engine will automagically idle up to a faster RPM when in park or neutral for more than a minute or so. Another part of the CAP is control of the exhaust back pressure valve (EBPV). When the oil temp and IAT are cold, the EBPV will close to put a tiny bit of load on the engine.
Even after the oil gets warm, if the IAT is cold enough the CAP will kick in.
SmokeyWren is offline
Old 02-25-2008, 06:48 AM   #5 (permalink)
I may be wrong but it seems to idle up more than my 02 7.3. I can't tell between idle up and regen mode as well..I wish the message center told when in RGen mode..I'm curious if it's doing it or not.
Despite what I've been reading here with some of the posts at DStop this truck is very smooth all around. I mean no problems or gliches.
08 F350 Lariet DK.Blue/Silver CC Short Box SRW. Auto transmission, Manual 4x4,Supplemental Cab Heater,3.73 Limited Slip.Gator Guard Bedliner, 6.5 x 12 Sno-Pro,8ft. Fisher.
04 Lance 820.
Light Trucks I've Owned Before
02 SuperDuty Super Cab Lariet Auto 7.3 4x4
01 SuperDuty Super Cab Lariet Auto 5.4 4x4
99 Dodge Ram Extended Cab Larime Auto 5.9 4x4
93 Dodge Ram Regular Cab Larime Auto 5.9 4x4
88 Chev Blazer 5.7 4 Speed 4x4
85 GMC 2500 Regular Cab 5.7 4 speed 4x4
70 Chev 1500 Regular Cab 292 Straight 6 4 speed 4x4
74 Blazer 5.7 4 speed 4x4
Captcaper is offline
Old 02-25-2008, 07:06 AM   #6 (permalink)
skidmarks's Avatar
If you kick the gas (fuel) pedal and it idles down, it was only in high idle mode, if it continues to high idle it is regening.
If The only way to stop the high idle is to step on the brake pedal then it is regening.
2008 F-350 Loaded Lariat 4x4 CC DRW 4:10's Auto 6.4 Pearl Blue and silver
skidmarks is offline
Old 02-25-2008, 08:26 AM   #7 (permalink)
My regen rpm is about 1300 where high idle is a little over 1000.
JD
08, 6.4, F-350, torqshift, SRW, lariat, 4X4, LB, CC, Pueblo gold (Built the week of 04/09/07)Arrived 4/24/07 brought home 4/26/07
http://rides.webshots.com/photo/2919...01044415MSbgrF
jhughd is offline
Old 02-25-2008, 04:11 PM   #8 (permalink)
skidmarks's Avatar
JD
Mine also.
Old 02-26-2008, 07:50 AM   #9 (permalink)
Seapig53's Avatar
JD
Great thread guys. I was wondering what that sucker was doing...until now
~Mike~
2008 F-450 CC Lariat...Plus moon roof
Seapig53 is offline
Old 02-26-2008, 08:39 AM   #10 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Here are some of the words from the Ford 2008 powertrain control/electronic diag (PC/ED) manual:
Engine Oil Temperature (EOT) Sensor
The EOT signal is used by the PCM to calculate fuel quantity and injection timing.
At low ambient air temperatures and an oil temperature of less than 70°C (158°F), low idle is increased to maintain stable idle quality. Fuel quantity and timing is controlled throughout the total operating range to provide adequate torque and power.
xxxxxxxxxxxxxxxxxxxxxxx
Intake Air Temperature 2 (IAT2) Sensor
The IAT2 sensor is located in the intake manifold. The sensor provides a manifold air temperature signal to the PCM. The PCM uses the IAT2 signal to control timing and fuel rate during cold starts and provide an input to the cold idle kicker.
(Note: There are two different IAT sensors on a 2008 PSD. This is one of them.)
Old 02-26-2008, 10:01 AM   #11 (permalink)
Thanks for all the info guys
Old 09-15-2008, 11:11 PM   #12 (permalink)
Kicking Idle Down
Can also tap brake pedal to bring idle back down to normal operating RPM.
fivebarfiesta is offline
Old 09-16-2008, 10:06 PM   #13 (permalink)
Ok...My truck does this even on hot days, and when you press brake pedal it does go down but once you release brake pedal it goes right back up.
If you rev truck or put into gear then back to park it goes right back up.
I thought maybe this was a Regen. If not my truck (which has 11K miles) has never regened...Is this bad?
UDLOSE is offline
