6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Talked with Ford at a trade show and asked about the DPF, can you clean it or replace it. Well Ford chose to replace it, the mileage will vary and the EPA is still setting guide lines. The fact is it will have to be replaced at 120K miles or so and right now they cost 2 grand.
IH cleans theirs and only 2 hours labor.
I'm sure someone will start cutting them open and cleaning them out.
I'd be real careful about adding fuel to the system and plugging it up too quick.
2000 F-350 Lariat SC PSD SRW 4X4, Six speed, Dark toreador red, Ball Bearing Turbo, Coolmist Stage 2, Banks Big Hoss 5 chip, Big Head Actuator and 3.5 down pipe with Dynomax exhaust, PacBrake Exhaust brake, AIS Air Filter, Jordan brake control, 20K Reese fifthwheel Hitch, Reese folding gooseneck hitch, Rhino lining born 5/00
1998 35' Challenger fifthwheel double slide with 3600 Onan MicroQuite Generator,Washer/Dryer.
Wife drives a Black 2003 Excursion 4x4 Limited, 6.0 PSD
Its not going to stop people from cranking it up.UNTIL they blow it up and go crying to Ford [img]/ubbthreads/images/graemlins/grin.gif[/img]Which they will quickly learn that It will come out of thier own pocket [img]/ubbthreads/images/graemlins/eek.gif[/img]Tampering or Re-writing this engine's operating software with The emissions system intact is playing with a Loaded gun in more ways than one.
Okay, who knows for sure. I was told the DPF can be cleaned once at about 120 k and then needs to be replaced at about 240k miles. This from a Ford rep as well
2008 F350 6.4 CC SB King Ranch, Quad Captains Chairs, DK Copper over Gold, 20" Wheels, Dual Alt, Aux. Heat, TG Step, MoonRoof, Tow Command, Upfitters, B&W Turnover Gooseneck, Linex Color Matched, Alpine IVA W200 DVD&Nav, Sirius, iPod, Bluetooth, Camera Feed from inside Horse Trailer, Viper 2Way Remote Start. My office on the road so to speak!
On the Class 8 trucks the shops all have to buy a machine affectionately known as "the battling Hoovers." Easily attached to either side of the DPF they suck and blow and clean out the ash where it is removed from said DPF and is disposed of rendering the DPF good as new.
It won't be long before someone figures out that they can cut out their Ford DPF, take it to the local big rig shop, have it cleaned, and just reinstall it.
I see stupid people. They're everywhere. They walk around like everyone else. They don't even know that they're stupid. AND THEY POST ON THIS SITE!
Early '99 7.3 Superduty. Built 3-98
Chassis: Supercab SB, Lifted w/ 20's.
Tranny: Suncoast parts built by the local guy.
Engine mods: Diesel Innovations all the way (tuning, injectors, & turbo), Homemade "Big Oil", GT42R Big frame turbo. Rods and junk to keep it all together.
I dunno know about for ford, i've seen pricing on the DPF for internationals...class 5 up to class 8...it ain't like buying a muffler. Its not something you can just 'gut'. If setups for pickup trucks are anything close to bigger trucks, fuel is injected into the exhaust, and burned in the DPF to 'regenerate' it. Temps reach 1000-1200 degrees during a burn. Also has a platinum lining in it, and carries a 4 digit price.
If you ever get a chance to have a peek at a class 8 engine, check out the ISX cummins, it has an injector directly behind the turbo to start the burn. Detroit has an injector in the exhaust too...havent seen an 07 cat, so not sure on that one.
Cleaning is part of a routine maintenance at milegae intervals, unless a code is set or an engine failure that requires cleaning/and or replacement.
---Don't run your fingers over my truck and I won't run my truck over your fingers---
97 Reg Cab Long Bed 5 spd, testing out some diy injectors, tymar, 3-4 DP, Cobalt Gauges, South Bend clutch, my own custom electric fuel system (pics soon), 305/70 ProComp A/T's on 16" MT Classics with Air Lift Bags and B+W Turnover out back...driven daily about to click over 200k...working at international gives me access to some fun goodies
05 Arctic Cat 400
95 Honda 750 Magna
97 Toyota 4runner
04 Kubota BX22 with a front loader, backhoe and mower deck - looks mean cutting grass with all the attachments!
Ford's DPF can be cleaned at least once before the catalyst wears down. They are releasing the machine to do it and the plan on how many and where the cleaning locations are needed. This came from a dealer on their national council.
I hear the same from mine that a cleaning process was in the works, and possibly a removable plug or system to do it on the truck in the future. This came out of one of the tech round tables. Other issues is servicing as it is very tight to get at things.This is normal for Ford after release to review with their folks on how to fix them easier than what the engineers came up with.
[img]/ubbthreads/images/graemlins/laugh.gif[/img] 2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY [img]/ubbthreads/images/graemlins/laugh.gif[/img], long bed, auto, 4:10LS
Goodies added.
Retrax bed cover [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
I deal with cleaning out the DPF's on the new Cat engines. I'm sure that the possibility of cleaning instead of replacing will be a option in the near future because of the cost of replacement. On the heavy duty side of things, Cat requires cleaning every 300,000 miles, but that is about equal to about 75,000 in light duty miles. The machine that is used to clean them is like a big air pump. It sends huge volumes of air in the reverse flow of the exhaust to break loose the ash and blow it out the other way. A trap then collects the ash and then you are good to go. The problem is that these machines are very expensive, around $7,000-10,000, so the will be few and hard to find. The time takes about two hours and on the heavy duty side it can be done on the truck, don't know much about the light duty side. Hope this info helps.
Matt Cearnal
2007 F-350 Lariat, Longbed, Crewcab, Stock right now but the fun is just begininng.
Do you know what's done with the ash that's cleaned out? Seems like it should be no different than any other ash - maybe toss it in the landfill or mix it in some farmland dirt or something - but I could also see it being considered HAZARDOUS MATERIAL OMG!!! and would require a disposal protocol with fees, etc. (If it's the latter then it won't matter how cheap the backflush machines get, you'll not likely see them anywhere but the dealers.)
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
I know that Nav tosses the ash in the dumpster. The EPA doesn't seem to care.
The ash is actually going to be considered hazardous. But there won't be any extra fees that come with getting rid of it. It will be in the same class as waste oil. Don't you love all the fun emissions makes for everyone.
Matt Cearnal
No, the EPA has determined that the ash is inert & non-hazardous. The individual states, however, may require certain disposal methods. Nothing Federal, though.
