Drain plug leaking - Diesel Forum - TheDieselStop.com
Old 07-15-2008, 11:58 PM   #1 (permalink)
Send a message via MSN to Stewy
Drain plug leaking
Hey all...has anyone else had problems with their drain plug leaking on the new 08's? I've replaced the copper ring numerous times and the leak constantly comes back. The truck has roughly 35,xxx miles on it. Thanks guys.
_______________________
2008 Ford F-350 Super Duty
2007 Audi A4 S-Line
2003 Suzuki GSXR-750
Stewy is offline
Old 07-16-2008, 05:34 PM   #2 (permalink)
Leaking drain plug
I had the same problem. The dealer changed the drain plug under warranty and the leak stopped. Try changing the drain valve to a Fumoto valve, I have one on my Excursion and it works great.
2008 F450 Lariat 4X4, Line-X, Pace Edwards bed cover, B&W Gooseneck, B&W Companion hitch, Firststone Air Bags. Everything else stock.
2002 Excursion Limited 4X4, 7.3 with Banks Stinger Plus, AFE, Rear sway bars, Bilstien Shocks
PSDCool is offline
Old 07-17-2008, 03:23 AM   #3 (permalink)
I was down at Ford today. They replaced the drain plug and copper gasket. Turns out the drain plug was cracked. Not sure how that happened. I'll be checking the garage floor in the morning.
2007 Audi A4 S-Line
Stewy is offline
Old 07-17-2008, 07:41 AM   #4 (permalink)
ddduallyfan's Avatar
The drain plug was cracked?
ddduallyfan is offline
Old 07-17-2008, 10:09 AM   #5 (permalink)
Ha ha ha
Cracked drain plug??????????
Anyways if the drip comes back get the Fumoto.
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
reba is offline
Old 07-17-2008, 12:08 PM   #6 (permalink)
I believe it. Is the plug aluminum by any chance? I was going to guess the oil pan threads might be cracked, but i think we have steel pans and not aluminum. The same thing happened to my 1991 T-bird. A Jiffy lube type place was changing the oil and I saw the worker cranking on the bolt like he was assembling steel I beams. I was always taught to get it snug then add a little oomph, not too much. Well later that day fresh oil was running down the driveway and took it back. The oil pans threads had a crack and oozing oil. They blamed it on me hitting something in the road and denied any wrong doing. Needless to say, the pan was aluminum and didn't take kindly to overkill.
Hope your problem is now fixed.
2008 F-250 Lariat 4x4, 6.4L, 4 tires, brakes, windshield, windshield wipers, tailgate, bumpers, blinkers, headlights, spare tire, rear bumper, hood, antenna, driver AND passenger seats, speedometer, radio, steering wheel, & spare set of keys!
Hydro is offline
