EGR failure - tape covering deaeration port the cause?? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 02-22-2011, 03:47 AM Thread Starter
So about 10,000k ago I had my 6.4 replaced with a 20,000mi used engine. The egr valve just failed (waiting to be diagnosed, but classic signs would indicate that's the issue). So I notice there is some tape covering the deaeration port on the egr valve. Could this have anything to do with premature failure of the egr??
Also, would I be better of getting the egr delete done now. I already have a dpf delete installed. I was thinking of going with dirty diesel customs egr delete kit. I don't run very powerful tunes so I don't think I need a wastegate kit from what I've read.
Thanks for any and all info on the topic.
rugatika is offline
post #2 of 14 (permalink) Old 02-22-2011, 05:52 AM
senix's Avatar
newer style EGR valves deleted the coolant line to them. Maybe that was the though process.
How do you drive the truck? That is also of EGR problems..I have had none.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #3 of 14 (permalink) Old 02-22-2011, 08:00 AM Thread Starter
We had a week of -40 and -30 C weather and I was using the truck all day with idling...the egt temps never got very hot so I'm thinking that may have a lot to do with it. With my job the truck idles a fair bit, so that's why I'm thinking I might be further ahead to get rid of the whole egr cooler system altogether.
I already have an edge evolution for my dpf but I'm not sure if that will cover the egr delete or not. I'll know in a bit when shops open and I start making some phone calls.
rugatika is offline
post #4 of 14 (permalink) Old 02-22-2011, 08:03 AM
senix's Avatar
Do the high idle mod as well. Extending idle in lower rpms is not good, egr problems as you know or suspect.
In addition, you are washing the cylinders with excessive unburnt fuel during idle. So a high idle is highly recommended.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #5 of 14 (permalink) Old 02-22-2011, 08:19 AM Thread Starter
yup...good idea, when I get back to civilization I will get that done as well. I had forgotten about the high idle mod altogether until you mentioned it.
rugatika is offline
post #6 of 14 (permalink) Old 02-22-2011, 11:45 AM Thread Starter
unplug the egr
So I was reading a thread on the 6.0L that said you can just unplug the EGR to get home. Can I do the same on the 6.4L?? Just unplug the harness to the EGR valve and drive away? I'm guessing it can;'t be that simple. I have about a 900km drive to get home from where I am. If I could get the truck running without doing any damage to it so I can get back home and get a EGR cooler delete done rather than spending money getting it fixed here AND doing the cooler delete later.
Thanks again
rugatika is offline
post #7 of 14 (permalink) Old 02-22-2011, 12:38 PM
Iím guessing but I donít think you can just unplug the EGR harness on the 6.4L. It is monitored by the PCM and might put the truck into ďLimp Home ModeĒ, worst case Iíve seen is that some trucks shut down completely and were towed into the dealer to replace the EGR valve with the second version that came out.
I would think that this would be covered under the Engine Warranty but you must know reasons why not. In any case, if an expert doesnít answer you, you could always call a Ford Dealer and ask them or Ford Roadside Assistance?
- 2013
F350 CC 4X4 Lariat SRW, Black.
Ordered Dec 2012 - Built Jan 11th 2013 - Picked up Jan 31, 2013.
- 2013
Ford Edge
Built Nov 26 2013 - Picked up Dec 06 2012
-2008
F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29.
-1972
First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson).
-First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards.
-1982 - My Sister married a GM Sales Manager (He Retired, "Hello" Ford Super Duty, enough said, LOL).
-2003 - ZRX1200 (Some say "Mid Life", LOL).
-2008 - Jayco 313RKS 5th Wheel.
MPD56 is offline
post #8 of 14 (permalink) Old 02-22-2011, 01:01 PM
senix's Avatar
I agree, would not do that on the 6.4. EGR can shut it down completely.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #9 of 14 (permalink) Old 02-23-2011, 12:08 AM Thread Starter
results
My egr valve was indeed crapped out and they replaced it. It still wouldn't run and a leakdown test was done showing the high pressure fuel pump was shot.
It sounds like NADP (who installed and suppliedthe slightly used 20,000mi engine for me) is going to cover the fuel pump, much to their credit, as I did not expect them to. After the engine install they just gave me a verbal that they would make things right if anything major happened. Guess my trust was not misplaced. That is the mark of a pretty good business if you ask me and they will be getting as much business directed to them as I can. Pretty rare these days to find a business like that.
I will be getting the EGR delete done as soon as finances allow.
rugatika is offline
post #10 of 14 (permalink) Old 02-23-2011, 04:58 AM
senix's Avatar
Be sure to start off with new OEM fuel filters. Sounds like some great people.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #11 of 14 (permalink) Old 02-28-2011, 04:11 PM Thread Starter
Still here. Dealership is unable to get supply/return lines on high pressure fuel pump to quit leaking. They have had the cab off twice now and will have to take it off a third time. Seems there is a problem with the new nylon washers or something that Ford is recommending. Does anyone have any ideas or similar experiences?? I am getting kinda frustrated.
rugatika is offline
post #12 of 14 (permalink) Old 02-28-2011, 04:13 PM
senix's Avatar
Lines and washers are not re-useable.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #13 of 14 (permalink) Old 02-28-2011, 04:51 PM Thread Starter
they said they used all new lines and washers the second time...still leaking. This guy is a Ford certified diesel mechanic...***? Is it that complicated to get a fuel line not to leak? These are the new nylon washers...should they be using the old copper washers that Ford does not recommend?
rugatika is offline
post #14 of 14 (permalink) Old 02-28-2011, 06:28 PM
guardrail22's Avatar
also keep in mind that the EGR system is the over pressure protection (waste gate sort of) so once its shut off if you hammer the throttle or are towing a bog load you could over pressure a cylinder or two and be replacing the 20,000 mile engine with a 30,000 mile engine.
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2013
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
