EGR Replacement - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 01-23-2010, 07:54 AM Thread Starter
EGR Replacement
Any idea what the cost is to replace the EGR. I have an 08 Job1 and would like to have it replaced prior to it leaving me stranded on the highway somewhere. It's too cold to be stuck in a truck.
2008 F-250 CC SB Lariat
go200mph is offline
post #2 of 16 (permalink) Old 01-23-2010, 09:12 AM
Shinny's Avatar
Are you having any problems that would lead you to think the EGR is not working properly?
'08
F250 FX4 6.4L Super Duty Crew Cab SB Silver Metallic & Dark Shadow Grey Job 1
Extang Trifecta Bed Cover,
High Idle Mod,
Spray in Bed Liner
second radiator
EGR Valve replaced
100% Stock
Shinny is offline
post #3 of 16 (permalink) Old 01-23-2010, 04:36 PM Thread Starter
During the holidays I had a power loss under relatively heavy acceleration that lasted until I shut the truck off and re started it. Nothing since then, but there seems to be a lot of failures with the Job 1 EGR's.
go200mph is offline
post #4 of 16 (permalink) Old 01-23-2010, 09:01 PM
senix's Avatar
i am running the same EGR. My truck is a job 3. No issues. I run mine hard though.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #5 of 16 (permalink) Old 01-24-2010, 02:10 AM
I have a Job3 and on Friday Jan 22, I had a new EGR Valve and housing installed (I was told it was a newer version). It was ordered on Jan 4th and came in on Jan 15th. There were three trucks waiting for them. My truck lost power and cruise control wouldn’t work. When I shut off my truck and started it later, it had power again and I drove it to the dealership. There were no warning lights but the dealer said that it had error codes and ordered the parts. The other trucks were towed there and didn’t regain their power. A Vender posted on this forum that they were having delays in getting these parts, since mine was covered under warranty, I didn’t ask him the price.
- 2013
F350 CC 4X4 Lariat SRW, Black.
Ordered Dec 2012 - Built Jan 11th 2013 - Picked up Jan 31, 2013.
- 2013
Ford Edge
Built Nov 26 2013 - Picked up Dec 06 2012
-2008
F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29.
-1972
First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson).
-First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards.
-1982 - My Sister married a GM Sales Manager (He Retired, "Hello" Ford Super Duty, enough said, LOL).
-2003 - ZRX1200 (Some say "Mid Life", LOL).
-2008 - Jayco 313RKS 5th Wheel.
MPD56 is offline
post #6 of 16 (permalink) Old 01-25-2010, 08:23 PM
FLATBED ED's Avatar
$750 parts and labor.
FLATBED ED,99 F-450(May she rest in peace)
2008 F-550 w/16-ft. Flatbed(buried on top of my 1999)
FLATBED ED is offline
post #7 of 16 (permalink) Old 01-25-2010, 09:15 PM
TousleyParts's Avatar
I can get you a better deal if you want a spare; the only bad thing is that most of them are not coming out of the housings, and the housings must then be replaced as well
While we have been replacing them at our dealership, its not been nearly as often as the 6.0s or 6.4 radiators. We seem to have the most trouble when it gets cold.
TousleyParts is offline
post #8 of 16 (permalink) Old 01-26-2010, 12:57 AM
I replaced mine a couple of days ago. The truck threw a check engine code. Ford wanted $ 125.00 to tell me what the code was. I took it to Auto Zone and they told me what the code was for free. They said it was the ERG valve but that the truck was to new for them to have replacement parts. I got one from Dickerson Ford in York,SC for $304.75. I would have ordered one on line for $176.19 plus shipping at Your Premiere Source for Ford Truck Parts and Accessories but I needed the truck up and running.
I used a copper pry bar and hammer to work it out.
I broke the EGR valve into but I was lucky that the housing was not damaged. I probaly should have used pentrating spray and let it sit for an hour or two.
My truck is Job 1 and the EGR valve had cooliant running through it. The newer style EGR valve has been redisigned and DOES NOT have the cooliant running through it. It took me about 30 minutes to replace it. The only hard part will be getting the ERG valve out of the housing. If you break the housing you can order another one at the above listed website fairly reasonable.
2008 Red F250 6.4,Extend Cab,SB,Fx4,tow command,Fumoto oil drain,backup sensors,6 disk in-dash changer,heated leather,20" polished forged wheels,limo tints,FS-2500 oil filter,--yea I like my ride!
turfmaster90 is offline
post #9 of 16 (permalink) Old 01-26-2010, 09:08 PM
Thats good to hear its that cheap. It sounds like it should be replaced every so often as preventative maintenance. Twice after the new Edge programmer mine stuck open and threw codes. It throws a huge plumm of smoke when the EGR is partialy open. It has worked the past few thousand miles but I feel like it will return. But if it is that easy than I am thinking just replace it once in a while?????????
2008
F350 6.4L XLT SRW 4X4
Edge "Race" tuner with Flo-Pro straight pipe kit
1983 M1009 CUCV 6.2L Detroit Diesel
08AZF350SD is offline
post #10 of 16 (permalink) Old 01-27-2010, 09:51 AM
Stranded by EGR failure
I just had to replace EGR and Housing. The truck died when I tried to crank it at my hunting lease. Check engine light came on and the truck would only run on 2 or 3 cylinders. Called Ford Roadside assistance to tow it. I had to wait two days before I could take the wrecker to the truck due to high water in the creeks it had to cross. Wrecker operator and roadside assistance person were great. Dealer was out of EGR's and had to wait for one to come in. Truck is fixed now and best of all, it cost me nothing because the warranty covered everything (parts, labor, tow). The new EGR is a different design than the old one. Maybe we need to carry one in the glovebox like we used to carry the CPS.
2008 F350, 6.4, XLT, Forest Green, SRW, CC, 4x4, Longbed, 6-speed, Manual 4x4, Camper Package, Plow Option, SIRIUS Sat Radio, Lance 835 Slide-In Camper.
SOLD: Early 99, F250, 7.3, XLT, White, CC, 4x4, Short Bed, 285x75x16 BFG AT, Manual 4x4, Ford AIS air filter, Warn Transformer Grill Guard, BTS Transmission by Brian T. 216,017 miles and still going.
1abnengr2 is offline
post #11 of 16 (permalink) Old 01-28-2010, 02:17 PM
Shinny's Avatar
Which warranty covered it, bumper to bumper or motor? Just wondering because I've got 39k on mine now.
'08
High Idle Mod,
Spray in Bed Liner
second radiator
EGR Valve replaced
100% Stock
Shinny is offline
post #12 of 16 (permalink) Old 01-28-2010, 03:24 PM
The 5yr/100k engine warranty should cover that
Some people say the emmissions warranty might cover it as well
post #13 of 16 (permalink) Old 01-29-2010, 09:44 AM
When I called Ford Roadside Assistance, the lady looked at all of the warranties and told me how much coverage I had left on each one (bumper to bumper/engine/emissions, etc). She couldn't tell me if the EGR was covered under engine warranty or not because we didn't know for sure what was wrong at the time. I just told her what had happened and that the check engine light was on and that I had 27,000miles on the odometer. She had all the other information from the VIN. When I picked it up at the dealer, the truck service manager just gave me back my keys and said it's all taken care of. Have a nice day. I love it when things work like they're supposed to. I'm happy with the service even though I was without the truck for 6 days.
post #14 of 16 (permalink) Old 01-31-2010, 04:14 PM
I just had my 2008 EGR replaced, was covered under warranty (5/100). Initially, the part (EGR housing) was estimated with a 3 week delivery time! The dealer found one sooner, but still I was out of truck for a week and a half.
Had my radiator replaced within the last two months as well.
nilesrob is offline
post #15 of 16 (permalink) Old 11-14-2015, 11:41 AM
I took had to replace the EGR vale and I also replaced EGR Sensor A location by the EGR I had a code of P040D. I now have no acceleration after warm up any one have any ideas on a fix. I have a 2008 F450 6.4
RayRice Va beach is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
