EGR Valve Issues - Diesel Forum - TheDieselStop.com
Old 12-15-2009, 09:36 AM   #1 (permalink)
EGR Valve Issues
I just had to have my truck towed to the dealer after the EGR valve went bad. It went without an warning and the truck was not able to be driven safely. Does anyone know how to deal with this issue on the side of the road? I hear that there is a way to un-stick the valve.
midnight7733 is offline
Old 12-15-2009, 06:30 PM   #2 (permalink)
Eric326's Avatar
I'm not sure about a way to unstick them, it would be nice if there was. But....I am going to assume you had the original 6.4L EGR valve design, so assuming that your dealership replaces it (not just cleans it) then you will have the updated EGR Valve for the 6.4. Easiest way to confirm is that there will no longer be a coolant line going into the EGR Valve housing.
2008 F-350 SRW 4x4 Package Lariat
Eric326 is offline
Old 12-16-2009, 03:05 PM   #3 (permalink)
Did I miss a TSB or something on this new EGR valve? Where is there more info on this? Good to know its not an isolated EGR valve problem that I saw myself.
Thanks!
cyclenut is offline
Old 12-16-2009, 03:48 PM   #4 (permalink)
senix's Avatar
mine is the old style valve and i have had no issues.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is offline
Old 12-16-2009, 06:44 PM   #5 (permalink)
I had mine replaced at 27000 miles hopefully the new design will last a little longer.
stewie2 is offline
Old 12-17-2009, 12:04 AM   #6 (permalink)
Eric326's Avatar
I have no idea why the new valve hasn't been discussed much, especially with a fair amount of people losing coolant slowly. But on the other plus, with my new valve my coolant hasn't budged an inch in the Degas Bottle.
Eric326 is offline
Old 12-17-2009, 08:08 AM   #7 (permalink)
Just wondering if someone can post a picture of the new valve. I have a job3
and was wondering if it was already on there.
2008 F350 Lariat Oxford White Crew Cab 4x4 6'box
inki is offline
Old 12-17-2009, 10:20 PM   #8 (permalink)
Eric326's Avatar
Here is a picture of the old style, the only difference is that if your EGR Valve does not have a coolant line going to it then it is the new style. Also almost all 2008 models had the old style unless you have a really late build date, they didn't start installing them out of the factory until 2009 model year. And they weren't available in most dealerships until February or March.
Eric326 is offline
Old 12-18-2009, 10:16 AM   #9 (permalink)
dieselmankane's Avatar
So why is it improved? Was the coolant line creating a problem?
2003 F250 Super duty 6.0 PSD, was great in the beginning, but started to have major issues:
Traded, Oct 2 2008 for...
New truck: 2008 F250 Superduty Lariat 6.4 PSD Job 3, black, with ALL the goodies, very impressed so far...
[SIGPIC][/SIGPIC]
dieselmankane is online now
Old 12-18-2009, 12:18 PM   #10 (permalink)
The first style egr valve was nothing but problems. They would just stick open all the sudden and it would take very little carbon build up to make it stick. They would also sieze in the bore of the intake and the valve had to be destroyed to get it out. And rarely coolant would leak through the valve making you think you had a bad egr cooler. So the just did away with the coolant lines, They didnt need them anyway, the new design is much metter and lasts alot longer.
FENDER772 is offline
Old 12-18-2009, 01:23 PM   #11 (permalink)
jays2003's Avatar
Do you happen to have a pic of the new EGR ?
Tow Vehicle: 2008 F250 4x4 Crew Cab Manual 4x4 (No Auto 4x4 Here) Lariat Loaded, Leather, DVD player, Audiophile sound system, Memory seats, power extend mirrors, tow command system, tailgate step, bed extender, Rancho 4" lift with BFG 37/12.50 Rancho XL 9000 Shocks.
Towed Vehicle: 2005 28' Sprinter Copper Canyon 5th wheel with slideout
66' CJ5 Rock Ready..
Pics Coming soon!
jays2003 is offline
Old 12-18-2009, 10:21 PM   #12 (permalink)
Eric326's Avatar
Exactly, often times when I had my old style EGR Valve pulled out, there would be a very light coating of carbon that caused it to have issues. I'm not here to advertise for them but I will say that once I switched my additive to Opti-Lube XPD that the EGR Valve remained very clean, but regardless I am now switched over to the new design anyways.
Eric326 is offline
Old 12-19-2009, 02:34 AM   #13 (permalink)
Your guys experiences are good to know.
I called the dealer today and inquired about getting a replacement valve for a 2008 model (part number 8C3Z-9D475-B). The parts guy said the last letter has changed was changed from a B to a C, and recently changed from a C to a D. He had no means to determine what the changes are, but I'll assume that reflects the hardware change.
However he said there is no TSB on this. What are you supposed to do with the "leftover" cooling lines. I suppose you could plug them somehow, but what's the factory fix?
cyclenut is offline
Old 12-19-2009, 05:59 PM   #14 (permalink)
Martin #6's Avatar
How hard is it to replace the egr valve? I'd like to replace it myself instead of having to deal with Ford and returning my truck to stock. Could someone take a pic of the newer style valve so we can see what to do with the "leftover" coolant line?
Early 99 F-250 4X4, built 9/98, 3:73LS, ATO trans with Chevron 30wt Drive Train Fluid, Garrett 38R BB ceramic coated 1.0 turbo, High Flow ceramic coated outlet, Non-ebv pedestal, BHA, Beans billet intakes, Teminator HPOS w/ R-IPR, Spearco 7.3 IC, 6.0 trans cooler, BWD ceramic coated bellowed up-pipes, DI regulated fuel return, AirDog, SWAMPS Stage II singles, BD Torq-loc, BD 4" in-line exhaust brake, 4" exhaust with ceramic coated downpipe, Live tuned by DP Tuner, Tymar, Racor CCV4500, Coolant filter, 203 T-stat, Pre and post pyro's, OilGuard by-pass filter.
SOLD
2008 F-250 4X4 Lariat CC. Job 3
No longer stock.
Martin #6 is offline
Old 12-19-2009, 07:24 PM   #15 (permalink)
Eric326's Avatar
I used to have the paperwork a long time ago that had the Ford install intructions for the mechanic. I will continue searching to see if I can locate it, but if my memory is correct the coolant line is rerouted and tied in to the EGR Coolers. And I don't know if I quite believe there is no TSB on it, well at the very least Ford had to release a notice to all dealers with the new install method for it. Considering Ford recalled all of the old style EGR Valves from every single dealership parts department, if you go in for service they have the put the new one on.
Eric326 is offline
