6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
That dual thing is suppose to help something during the Regen process.
all I can figure by looking at it, is that helps dissipate the heat and those little cut outs allow a bit more air flow into the tip to help cool it off.
This, I figure, is so that the exposed tip temperatures stay down a bit lower, to help keep you from burning the sheet out of your leg.
Other than that, I really dont see much point to the double tip thing.
IMO, cut it off, put whatever you want on there. its your truck. I really cant imagine something that minor haveing any ill effects for your truck.
2000 F350, 2wd, SWB, CC, 7.3, Lariat, Chip, 250,000 miles in Jan'07
1. Immediate denial of warranty claims by Ford.
2. Violation of Federal law.
3. Possible malfunction of DPF and fire hazard.
4. Possible engine malfunction.
Just sit back and relax, aftermarket part guys will not lose this much market potential. IMO They will have and improved design chrome plated with "new and improved turbine holes" [img]/ubbthreads/images/graemlins/smile.gif[/img] available in no time. You cannot just remove the tips but they said nothing about enhancing them. To me, I really don't give a #(@$. I didn't buy the truck for the exhaust tips, they serve their purpose.
I think there are still new 07s to be had.
Ohhk, 1 & 2 I can see being possible,
but 3 & 4?? from the exhaust TIP???
if this stuff is really that sensitive, I am not sure I ever want to take this truck off road. Sheet, I have been known to crush exhaust pipes, bent one gas tank, and even sheer'd off a U-bolt off my rear leaf spring one time.
I can only imagine where I will get stranded if I put a ding in an exhaust pipe on this super sensitive truck. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
So spend 50,000 of your hard earned dollars on a truck that you cannot even change the exhaust on...
I think I'll buy mine with a v10 and supercharge it.
Kev, you need some tires? [img]/ubbthreads/images/graemlins/wink.gif[/img]
'99.5PrairieTan/XLT/4x4/CC/SWB/7.3 <u>PARTS FROM DI:</u>6 pos Chip, MM inj., Custom DIIC, AFE2, Fass 150/180, Garrett GTP38r, Full fuel system w/ Billet sump and reg. return, HX mod, Built tranny w/ PI TQ. Conv., 4 pod w/ Autometers, Centric slotted rotors/pads
I saw that schematic the other day and wondered what they ment by "cooling diffuser must be utilized"?
and how many aftermarket systems will utilize the factory one vs. including their own
they'll probably use their own diffuser. ford's tip isn't critical, just so long as a diffuser is used that achieves similar results. i'm speculating....
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
Man, these trucks sound like no fun at all. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Thats what I was thinking Colin. I'm gonna stick with my 6.0 [img]/ubbthreads/images/graemlins/cool.gif[/img]
[/ QUOTE ]I hear if you mod your floor mats Ford will void your warrenty LOL. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
__________________ 2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
