Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 09-24-2008, 11:43 AM   #1 (permalink)
External Tranny Filter
Has anyone changed it and if you have where did you get the release tool for the quick coupler end. Standard sizes the fit fuel lines DO NOT work. Be prepared not to be able to sit for quite some time after buying the filter....I get a discount and it still cost $ 76.00...ridiculous for something the size of a small oil filter.
2008 F350...Lariet Super Cab , 6.4, 3:73 with all the goodies, 29,000 miles, 35 foot 11K Fiver
New Radiator
12-13 MPG HWY if I drive like a p-ssy
"Passes everything except the fuel pumps"
TIM K is offline
Old 09-28-2008, 11:46 PM   #2 (permalink)
SRB
Tim,
Do you mean this one? If so, then you don't need to disconnect the oil lines. Just spin the housing off, and swap out the filter. Only $17.50 plus shipping.
Motorcraft TorqShift transmission filter (external) FT-145
2005 F250 Lariat CC SB 6.0L
2006 Crownline 230LS
SRB is offline
Old 09-30-2008, 10:05 PM   #3 (permalink)
2x6 Bulldog's Avatar
That's not it. It has 4 fittings on a ss metal can. Looks like you replace the whole thing. Funky plastic looking fittings. You need a special tool.
2008 F450 DRW CC LWB 4x4 Off Road, Lariat, Oxford White, 4.30 LS rear end, Navigation, audiophile stereo, Memory package seats, heated seats, heated mirrors, warmup heat option power back window, traction control system, backup alarm, rear DVD with wireless headphones.
2x6 Bulldog is online now
Old 10-01-2008, 04:37 PM   #4 (permalink)
On an '05, how does one keep the o-ring in the filter housing from leaking after replacing the filter? Nothing in the shop manual about how much (or how little) to tighten. Thanks.
2005 F-350, King Ranch, White/Tan, Crew Cab, 6.0, Fx4, TorqShift, 6-disc CD, Adj. pedals, short bed, SRW, 3.73, trailer and camper pkgs, Tow Command, upfitter switches, spray-in bed liner. No performance options (yet). Pull 11,500# TT.
Hethershaw is offline
Old 10-01-2008, 07:04 PM   #5 (permalink)
where is it located? If it is up front by the radiator on the passenger side frame rail, that is the element for it. To unscrew the bottom that has a hex fitting on the bottom, use an air gun to break it free. If not, you will twist it off the bracket.
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 10-02-2008, 05:35 PM   #6 (permalink)
Scottb NY: Yep, that's the one.
After six tries -- it's not leaking. But I'm not very comfortable with it. It's only hand-tightened plus about an eighth of a turn. Any more tightening seems to push the o-ring off the seat. Not a good design.
Thanks for the reply.
Ron
Old 10-02-2008, 06:58 PM   #7 (permalink)
Talking 2008 6.4
This is the 2008 forum
I have the same issue with the fittings. I guess it is a Ford part. I took mine in to the dealer and they just changed the fluid. I guess they didn't have the fitting tool either.
Old 10-02-2008, 07:33 PM   #8 (permalink)
you dont need a tool, you need a socket and an air gun and the replacement element.
2005
Med. Wedgewood Blue
Old 10-02-2008, 10:29 PM   #9 (permalink)
The release tool is available from many sources.... I got mine from the MAC tool vendor in our area....
A few requirements.... if you aren't sure... shut up, sit back and learn.... If your dealer isn't sure.... run away.... run away very fast....
Tim is NOT speaking of the old frame mounted "toilet paper" looking filter.... Tim is talking about a filter that many of you haven't looked for or at.... and it is on early build 08s only.... and it takes a special tool to remove the lines... and the tool is available (if your dealer doesn't have it - he should become your ex-dealer)....
GrampyJim is online now
Old 10-03-2008, 01:02 PM   #10 (permalink)
OT
My Photos: (6)
Been following due to curiousity..certainly has been confusing..even got 05 mixed in. Now...
GJ says..Early 08 has one type external a/t filter..later models apparently have different type? Seem's like more confusion..so what's the diff.?
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23'
OT is offline
Old 10-04-2008, 12:54 AM   #11 (permalink)
titaniumfan's Avatar
see Replacement of Job1 Tranny filter
2008 F-450 Lariat Job 1 w/ 4.88, 98 gal. Transfer Flow tank in bed, Tekonsha P3 brake controller, TrailerSaver TS3 air hitch, all for a 2007 Glendale Titanium 36E41MPRV toyhauler (fulltiming about half the year, lots of driving in the Rocky Mountains)
SOLD 2006 Silverado 2500HD LT3 (LBZ Duramax)
titaniumfan is offline
Old 10-04-2008, 01:34 AM   #12 (permalink)
Stymie's Avatar
stop posting, please. this filter is specific to 08's with the automatic built before Aug 1, 2008.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains
Try the SEARCH Button
Stymie is offline
Old 10-04-2008, 09:48 AM   #13 (permalink)
8/01/08 build date? I thought I saw "early build"? so should I find this on my job 3 built on 3/4 08? Sorry for the query; I'm just seeking clarification...Thanks and regards...joe
yukondiesel is offline
Old 10-04-2008, 11:12 AM   #14 (permalink)
Instructions (give it a few seconds to load, the page loads slowly and appears to hang for about 5 seconds, sometimes);
https://www.motorcraftservice.com/pu...9/S8O71035.HTM
ZeroOne is offline
Old 10-04-2008, 12:47 PM   #15 (permalink)
OK, here's what he's talking about. I have an early job 1 built in January of 2007.
Here's a close-up of the filter, sorry these are from one side only, but I was taking pictures for the dealer to see where I found an oil leak, turns out it was the oil return tube from the turbo, but that's a different story!
2008 6.4L F350 King Ranch, Crew Cab, Long Box, 4X4, Dual Rear Wheels, 4.10 rear-end
mattebury is offline
