Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 02-29-2008, 05:49 PM   #1 (permalink)
F-350 axle ratio
Hello everyone,
I ordered a new 350 psd cc 4x4 lariat on 12-29-07.February my dealer calls me up
says i can't get the 3.73 gears, I have to get 3.55 gears or cancel the order. He says the computer kicks it out.The truck is due to be built 3-5-08 around there.
I look on blue oval forum I see trucks with 3.73 gears ordered after mine.
Does any one know whats going on? I called ford customer service they don't
know
Thanks Pete
frusteri4 is offline
Old 02-29-2008, 06:34 PM   #2 (permalink)
Hopefully someone knowledgable will chime in quick. All I can tell you is that I would NOT buy a F-350 with 3.55 gears. Nice boulevard cruiser but IMHO not an ideal towing vehicle. Something does sound fishy. Do you have complete trust in your salesman? Could he be trying to get you to cancel the order and buy off the lot from what he's got? Maybe you should have the dealer do a search from other dealers for an available truck that has your trim and options on it from existing stock. I had heard that 3.55 was going to be the standard gear set but that 3.73 and 4.10 and 4.30 in the Tow Boss was still going to be an option.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 02-29-2008, 07:09 PM   #3 (permalink)
Harley350's Avatar
Ford has announced that its 2008 F-250 and F-350 heavy duty trucks will come with new fuel saving measures. The revised trucks will come equipped with 3.55 rear axle ratio — instead of the current truck's 3.73 setup — as well as a 3.93 inch (100 mm) chin spoiler.
Despite the numerically lower ratio, Ford claims the trucks will keep their current tow ratings. However, acceleration times will likely suffer.
The improvements should net about a 1.5 mpg improvement over current fuel economy. Three-quarter and one-ton trucks are not required to carry an EPA fuel economy rating so an exact measurement of the improvements is hard to discern, but likely in the 10 to 15-percent range.
"We are making the 3.55 standard and when that's combined with new front-end aerodynamic improvements, there will be about a 1.5 mpg improvement," said Ford trucks spokesperson Wes Sherwood. He continued: "Ford is constantly looking to innovate with its trucks. Fuel economy is on people's minds right now and we're not going to wait until the next model year to make a change. We're going to implement changes like this as soon as we can."
Harley350 is offline
Old 02-29-2008, 07:37 PM   #4 (permalink)
I wouldn't lose a lot of sleep over the axle change...3.73 to 3.55 is almost not noticible...probably about the same as a tire size increase. Also doubt that it will affect mileage much either
2008 F350 Crew Cab 6.4 PSD 4X4
Excel 33RSO 5th Wheel M/C Lift on the back
jayhirsch is offline
Old 02-29-2008, 07:47 PM   #5 (permalink)
My 7.3 pulls a trailer just fine with even more radical gearing. I'd hate to think the 6.4 was such a weenie engine it couldn't match the towing capacity of an old 7.3.
'00 F-350, 4x2, 6 Speed AIC 210,000 miles
3.08:1 Gears
Fuel tank mods: MaroonHarpoon, Pre-Pump,
Evans, 203 degree thermostat, Poor Man's Tymar, 4" Single SS Exhaust, Rugged Air Dam
225-75x16E tires in front 235-85x16Es in back, tires aired up to 100 psi, Lowered 4" in front and 6" in back, "Fastback" bed fairing
21.3 MPG before mods
27.0 MPG tested with mods
Dave Whitmer is offline
Old 02-29-2008, 11:22 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Originally Posted by frusteri4 View Post
Hello everyone,
Something doesn't make sense.
Assuming a PSD in an SRW with automagic tranny:
The current order guide says 3.55 ratio is standard with 17" or 18" wheels/tires, and that 3.73 LS is standard with 20" wheels/tires. 3.73 LS is optional with 17" and 18" wheels/tires.
Perhaps you tried to order 3.73 open axle? That one is no longer available. Tell the dealerperson to code the axle "XEL" and the computer should take it according to the Order Guide - but it will cost you extra for the LS.
SmokeyWren is offline
Old 02-29-2008, 11:40 PM   #7 (permalink)
Engine31's Avatar
My Photos: (9)
Don't settle!!!!,,,I would want a 4.10, but thats just me.
F450 Lariat 4X4, red, 4.88's, everything but the moonroof, S & B Intake, Banks exhaust, Amsoil.
Engine31 is offline
Old 03-01-2008, 05:04 AM   #8 (permalink)
350 gears
I think my dealer messed up ,3.73 LS were ordered on the order sheet!
I called Bobby Williams he said he could order the 3.73 LS gears. So I think
I will reorder with him. Its just ashame I wasted 8 weeks time and i might miss
0 finance?
Pete
Old 03-01-2008, 05:41 AM   #9 (permalink)
I just looked at fords build your own truck, it wont let you order 3.73 gears with 18' wheels
you have to get 20" wheels this is nonsence
Old 03-01-2008, 09:13 AM   #10 (permalink)
SmokeyWren's Avatar
My Photos: (33)
you have to get 20" wheels ...
Yep, Ford's build and price website is messed up when it comes to axle ratio. Or else the Order Guide is messed up. I suspect it's the geeks that do the website that can't read an order guide.
Old 03-01-2008, 09:24 AM   #11 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Its just ashame I wasted 8 weeks time and i might miss 0 finance?
I love Bobby, and hate to cost him a sale, but before I'd waste 8 weeks I'd go to the dealership and stand on somebody's desk demanding they fix the order so you can get 3.73LS ratio, or else show you in the printed order guide where it's not available.
Of course, the computer ordering system overrides the order guide, but they usually keep them in gee. If your dealerperson does a "change order" and codes X3L axle, what is the result? Make them show you.
Of course I'm assuming you ordered the diesel engine, else all bets are off.
Old 03-01-2008, 11:10 AM   #12 (permalink)
Thumbs down 350- gears
The truck is a auto,apparently with a manual trans you get 3.73, auto you get 3.55 non or LS ,f/x package you get 3.55 LS . With 20" wheels 3.73 is standard.
This info is for SRW trucks. This is from the paper ordering guide dated 2-1-08
Old 03-01-2008, 12:35 PM   #13 (permalink)
Unhappy 350-gears
I would like 4.10 too but ford never offered that in a SRW. My 96 350 has 4.10 .
Old 03-01-2008, 01:59 PM   #14 (permalink)
SmokeyWren's Avatar
My Photos: (33)
That sounds like you have a later ordering guide than is available from Bobby's website. The "axle availability" page is dated 12/01/07 in the latest version available on Bobby's website. And it definitely says 3.73 LS is an option for both F-250 PSD and F-350 SRW PSD with automagic tranny.
Old 03-01-2008, 01:59 PM   #15 (permalink)
piomice's Avatar
Don't know if this applies, but on 2.20.2008 I ordered a F-250 CC 4x4 Lariat 6.4L with 3.73 LS. It came standard with the 3.55 gears, but I opted for the 3.73 LS. 3.73 LS gears is definitely what is on the order form I have in my hand.
piomice is offline
