Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-25-2007, 05:12 PM   #1 (permalink)
F450 Rear Axle Failure
All the bolts in rear end have sheared off and my dealer says it will not be covered under warranty because of larger tires.
2008 Chevy Silverado 2500 HD LTZ 4x4
Sold 2008 F-450 Red 4x4 High capacity tow 4:88s, Off Road,Sirius Sat,Navigation,Sunroof,Upfitter switches,DVD entertainment,DVD thru Nav, Tailgate step,Traction control,Audiophile 6-disc,Rear sensors,Rear camera,Tailgate step,Roll-n-lock,Air bags,50 gal auxillary tank,4.5 DR Lift,22.5 Alcoas,37" Michelin XD2's, Gear vendors over/underdrive,Pullrite 25.5 fiver,Train horn
http://good-times.webshots.com/photo...02243944PKdsNq
http://good-times.webshots.com/photo...02243944vexapR
Sold 2008 Weekend Warrior 40FLT Billet Edition
2008 Infinity QX56 4x4
2003 Chevtolet Corvette Convertible 50th Anniversary Edition
2007 Harley Davidson Ultra Classic
2006 Harley Davidson Fatboy(custom)
2008 Roadmaster Low Hauler
2004 MAstercraft X-9 Wakeboard Edition
2007 Honda Foreman Rubicon
2007 Honda TRX 250 EX
2007 Honda Recon
2006 Polaris 90
BigRedF450 is offline
Old 10-25-2007, 05:36 PM   #2 (permalink)
Re: F450 Rear Axle Failure
Which bolt's? If you are talking about the lug bolts, I can see many reasons that they would ot cover them. I have seen in your sig that you have 22.5 inch wheels. This can happen if they are not hub centric wheels or the wheels where not torqued properly. It is possible that they did not mount to the hubs properly.you may need to look at the seller of the wheels.
first_ford is offline
Old 10-25-2007, 05:37 PM   #3 (permalink)
bogg's Avatar
My Photos: (5)
What caused the shearing can you tell?
07(built 06/06) 6.0 Lariat/Moonroof/Camper Pkg/ FX4/DRW/5spd TS/13K GVWR/4.10LS/CC/LB/F350: Accufab Elbow/Mag-Hytec/AutoMeter Tripod(EGT/Trans/Diff)/PIE-Sirius-IPOD/Infinity Speakers/Zoodad/Fumoto/IH-HFCM/Precision Grill/Special Edition UT Weatherguard Crossbox/Coolant flush@25k/Coolant in-line Filter/MBRP 4" Duals/ My Truck Pics:
http://good-times.webshots.com/album...ost=good-times
bogg is offline
Old 10-25-2007, 09:54 PM   #4 (permalink)
It's the bolts that actually hold the chunk in. There are 4 bolts and the 2 lower ones are broken off at the heads and also bent the ABS Ring. Dealer is quoting $7,000 to repair. Don't know why they sheared but Ford will not warranty because of larger tires. I would hate to think larger tires would cause this and if so I am leary of this rear axle. Still fighting with Ford and the dealer.
2007 Honda Recon
2006 Polaris 90
Old 10-25-2007, 10:53 PM   #5 (permalink)
Are those your larger tires in your pics? Got any new pics of the larger tires?
2008 F450 4wd crew, forest green over pueblo gold, 4.30 rear, several options, Lord help me keep my truck stock.
Deeregreen is offline
Old 10-25-2007, 11:16 PM   #6 (permalink)
No the ones in the picture are 35" Toyos on the factory 19.5" rims. Now I have 255/70/22.5 Michelin XD2s on Alcoas. I havn't been able to take pics since the new tires and wheels were added. I will post new pics when truck is fixed.
2007 Honda Recon
2006 Polaris 90
Old 10-25-2007, 11:24 PM   #7 (permalink)
guardrail22's Avatar
the F450 with 488 is rated for 24000# trailer wieght and 33000# GCWR. What larger wheeels and tires do is effectively lower the rear axle to an equivalent of something like 440 or 430, which lowers the GCWR according, possibly back to the 20000# rating of the 430 truck. You could have been overloaded.
Having said that are you saying the center chunk is only held into the axle housing with four bolts? 10-12 would be more typical.
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
New Truck
http://www.f150online.com/galleries/....cfm?num=15052
Traded In Nov 07: 2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch, Adv Security Group, Clearance Lights, Adj Pedals, Privacy Glass, Sliding RW
Delivered 11/27/2002
7100# with full fuel and no occupants
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
http://www.f150online.com/galleries/...w.cfm?num=3016
guardrail22 is offline
Old 10-25-2007, 11:25 PM   #8 (permalink)
Good luck, sounds like they aren't being very lenient. That is a very good looking rig. How do you like your Gear Vendors?
Old 10-26-2007, 10:07 AM   #9 (permalink)
Exactly what did the dealer do when they were "in" the rear axle fixing the tone ring one week ago?
toalpi is offline
Old 10-26-2007, 11:30 AM   #10 (permalink)
The gear vendors unit is great. Fuel economy unloaded at 70
MPH is 15+ and when it is turned off 10.5
2007 Honda Recon
2006 Polaris 90
Old 10-26-2007, 11:31 AM   #11 (permalink)
I am not sure what they did a week ago.
2007 Honda Recon
2006 Polaris 90
Old 10-26-2007, 01:13 PM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 1BigRedF450</div><div class="ubbcode-body">I am not sure what they did a week ago. </div></div> In the other thread you mentioned a problem with the ABS ring (tone ring). That problem and/or fix is clearly relevant/related to these bolts. Did they open the differential up? Did they remove the differential? Did they replace the tone ring? Get the paper work. IF, and that is a big IF, they removed these bolts during that repair AND then these same bolts broke a few days later, then they have a problem. If these bolts were loose and that is what caused the ABS light to come on but they didn't find this, then????? How many miles were driven with the ABS light on? How many after the repair? Lot of variables here. The tires AND the GV unit combined do not help your case if they did not touch those bolts.
toalpi is offline
Old 10-26-2007, 04:48 PM   #13 (permalink)
They diagnosed it as ABS Ring and ordered the parts under warranty, once they opened the diff found the two lower bolts were sheared off. Tech classified it as neutral shock. Ford regional rep is looking at it today and will decide warranty status. This dealer has always been modification friendly as all my trucks are heavily modded. I have had in the last 9 years 110,000 in warranty repairs on powerstroke vehicles per the service manager at Alexander Ford in Franklin TN.
2007 Honda Recon
2006 Polaris 90
Old 10-26-2007, 07:00 PM   #14 (permalink)
Was that $110,000 in repairs in 9 years? Man that is a lot, like $12,000 per year, and you still have a ford. That's Loyalty with a capital L. Don't think I've had that much warranty work done in my life time. Oh, GM did replace two engines in my 90, 6.2.
JD
08, 6.4, F-350, torqshift, SRW, lariat, 4X4, LB, CC, Pueblo gold (Built the week of 04/09/07)Arrived 4/24/07 brought home 4/26/07
http://rides.webshots.com/photo/2919...01044415MSbgrF
jhughd is offline
Old 10-26-2007, 07:28 PM   #15 (permalink)
Yes I thought it was high as well, but I did go through 3 2003 6.0 all with major problems befor I got a good 2004. The loyalty part is because the other trucks feel too small inside.
2007 Honda Recon
2006 Polaris 90
