Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 09-04-2007, 10:59 AM   #1 (permalink)
First Oil Analysis results
Like others reported I did notice about a two mpg increase after changing the oil which I associated to normal viscosity increase as the additive package wears in the old oil. I was getting 17-18 mpg, which later dripped to 15 ish. Changing the oil, and the mileage went up????
So here it is, Hot off the press:
Unit Number: F-350-2008
Phone Number:
Received Date: 08/30/07
Equipment: IH 6.4L
Sender:
Sample From: ENGINE
Product: Factory Fill
SAE:
Sample Date: 08/27/07
Maintenance Recommendations (Current Sample Only)*
NOTE VISCOSITY VARIATION. FUEL DILUTION IS >4% (FLASHPOINT 290 F). CHECK INJECTORS, LINES OR FUEL PUMP. CHANGE OIL AND/OR FILTER IF NOT ALREADY DONE. RESAMPLE 1/2 NORMAL INTERVAL TO MONITOR SYSTEM. EMERGENCY NOTIFICATION MADE OR ATTEMPTED. 08-31-07. ALUMINUM AND SILICA ARE HIGH.
Lab No. SK6167
Date 08/30/07
DRAIN HOURS 239
Oil Added 0
Physical Tests
Viscosity cSt 100C 9.7
SAE Grade 100C 30
Fuel Soot %WT 0.2
Water, Fuel Dilution or Antifreeze N P N
Wear Metal, PPM
Chromium 2
Copper 25
Iron 78
Lead 9
Tin 5
Aluminum (23)
Silicon (Dirt) (49)
Additives and Other Metals, PPM
Antimony 0
Barium 6
Boron 17
Cadmium 0
Calcium 1945
Magnesium 9
Molybdenum 5
Nickel 1
Phosphorus 806
Silver 0
Sodium 12
Titanium 0
Zinc 941
* Accuracy of recommendations is dependent on representative oil sample and complete, correct data on both unit and oil. This report is not an endorsement or recommendation of any product or system.
—END Titan Fluid Analysis E-Solutions Report—
50% of all engine failures are directly related to cooling system problems
With the recent appearance of long life coolants, silicate related cooling system failures, environmental concerns, and increased operating costs the condition of your cooling system has become an increasingly important maintenance consideration.
Designed like Titan’s Oil and Fuel Analysis programs, our Coolant Analysis was developed to help you assess the condition of your equipment and reduce maintenance costs.
To learn more about coolant analysis, diesel fuel testing, and other services provided by Titan Laboratories, visit us at http://www.titanlab.com or call our customer service department at 800-848-4826.
Titan Laboratories
Predictive Maintenance & Fluids Analysis Solutions
1380 Zuni Street, Denver Colorado 80204
800-848-4826 303-893-5273 Fax 303-607-9025
http://www.titanlab.com http://www.titancheckup.com
Stealth03TDI is offline
Old 09-04-2007, 01:41 PM   #2 (permalink)
Re: First Oil Analysis results
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">FUEL DILUTION IS &gt;4% (FLASHPOINT 290 F). CHECK INJECTORS, LINES OR FUEL PUMP. CHANGE OIL AND/OR FILTER IF NOT ALREADY DONE. RESAMPLE 1/2 NORMAL INTERVAL TO MONITOR SYSTEM. </div></div>
How many miles was on this sample? It seems like you have a problem somewhere with fuel greater than 4%. I'd take this OA in to the dealer with the truck to have it looked at.
OMCUSNR is online now
Old 09-04-2007, 01:50 PM   #3 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
I think many of those numbers are quite high for a broken in engine. However your engine is still breaking in. Keep sampling and it should come down to a stable baseline of values. For instance, if this were a 7.3 with 100K miles on it, I would say that the air box was leaking or the filtration was inadequate as the silicon is quite high. In your case that is probably due to sealants that can be detected in the oil. They should come down with each oil analysis and would not indicate a problem with air filtration (doesn't hurt to check however). Copper would indicate a failing turbo bearing but in your case it is probably break in. Similarly iron etc.
haul_n_horses2 is offline
Old 09-04-2007, 01:53 PM   #4 (permalink)
That's quite a bit of fuel in the oil. The high Al count is also a bit odd.
- Jay
Diesel Jay is offline
Old 09-04-2007, 01:57 PM   #5 (permalink)
My Photos: (17)
FMTRVT used to maintain an anonymous database of oil analysis data. He still has the database data available for download here. While not directly applicable to the 6.4, some of the reports will show serial results from new and give you an idea how quickly values will settle down.
Old 09-04-2007, 02:01 PM   #6 (permalink)
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Diesel Jay</div><div class="ubbcode-body">That's quite a bit of fuel in the oil. The high Al count is also a bit odd.
- Jay </div></div>I agree on the aluminum ppm. Piston break in?? Also on the 6.0 Jack (FMTRVT) noted increased fuel in oil when he idled the truck to warm up the oil before pulling the sample. Perhaps that was the case here????
Old 09-04-2007, 05:30 PM   #7 (permalink)
How many miles were on the oil sample? Was this the first oil change?
I'm not sure that I buy that fuel dilution is high. Fuel dilution is very difficult to measure properly. I have seen up to 5% variation from one lab to another.
If this was the first oil change, then this is 10w30 oil. 10 cSt viscocity is normal for 10w30. 1% of fuel dilution will lower viscocity by 1 cst. If it is 15w40, then I would say that fuel dilution is high.
Fuel dilution comes from regens on the 6.4L. On the 6.0L, it came from the injectors.
Regarding the high Al: Notice that copper is also relatively high. With the high Si, I would guess that a piece of dirt got in one of the bearings. If you pulled the engine apart, you would find a nice line through it. Nothing to worry about, though. They are designed to take some debris. However, I would make sure that there are no oil leaks or leaks downstream of the air filter.
rlchv70 is offline
Old 09-05-2007, 10:42 AM   #8 (permalink)
This is the first change with 9,500 on the factory fill, engine hot just off the road. I think the high AL and SI is due to oil washing a newly assembled engine. I've seen the exact same first change results on two new VW TDI engines. On the next oil change, the values were down to expected levels. Fuel dilution question evades me. I'm sure it's related to regen washing the cylinder walls, but until the user fleet gets more miles, what is normal?
I'd like to see more data from others
Old 09-05-2007, 12:05 PM   #9 (permalink)
9500 miles? That seems high to me.
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
2007 Keystone Raptor 3712TS PICTURES
newbie_101 is offline
Old 09-05-2007, 12:10 PM   #10 (permalink)
I'm no fan of wasting oil, and many manufacturers are recommending the factory fill go to the published interval, but I guess if it were me, I'd have drained the factory fill between 3k & 5k, put in the recommended 15W40 CI-4 and then taken my 1st sample at 5k on that oil. If things looked good, I'd carry on to the recommended interval form then on.
Old 09-05-2007, 09:12 PM   #11 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Stealth03TDI</div><div class="ubbcode-body">This is the first change with 9,500 on the factory fill, engine hot just off the road. I think the high AL and SI is due to oil washing a newly assembled engine. I've seen the exact same first change results on two new VW TDI engines. On the next oil change, the values were down to expected levels. Fuel dilution question evades me. I'm sure it's related to regen washing the cylinder walls, but until the user fleet gets more miles, what is normal?
I'd like to see more data from others </div></div>
Today I received a report on my second oil change. 5316 miles on oil, 9837 on engine. Without going into great detail, Al was 20, Si 22. The Al was same as prior but true to form the Si dropped from 51. So it's washing out as expected.
I am waiting on a second report from Holt Caterpillar. They run our oil analysis and mine as well and I want to compare the fuel dilution in their report as well as Blackstone. Mine was at 5% according to Blackstone. I know that sounds high but keep in mind this is a new technology with the regens and it may be par for the course. I also will check with some of my contacts to determine if this is out of line for the 6.4.
2008 F-250 4x4 King Ranch Crew Cab Loaded.
Pure stock and staying that way!
2007 Kawasaki 3010 4x4 Mule - For Fun
NRA Benefactor Life Member - NSCA Life Member
krieghoff is offline
Old 09-05-2007, 09:17 PM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: OMCUSNR_RET</div><div class="ubbcode-body">I'm no fan of wasting oil, and many manufacturers are recommending the factory fill go to the published interval, but I guess if it were me, I'd have drained the factory fill between 3k & 5k, put in the recommended 15W40 CI-4 and then taken my 1st sample at 5k on that oil. If things looked good, I'd carry on to the recommended interval form then on. </div></div>
Just for the record, the 6.4 requires CJ-4 not CI-4.
Old 09-05-2007, 10:11 PM   #13 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: K80</div><div class="ubbcode-body"> Mine was at 5% according to Blackstone. I know that sounds high but keep in mind this is a new technology with the regens and it may be par for the course. I also will check with some of my contacts to determine if this is out of line for the 6.4.</div></div>
What is your viscosity?
rlchv70 is offline
Old 09-05-2007, 11:07 PM   #14 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: rlchv70</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: K80</div><div class="ubbcode-body"> Mine was at 5% according to Blackstone. I know that sounds high but keep in mind this is a new technology with the regens and it may be par for the course. I also will check with some of my contacts to determine if this is out of line for the 6.4.</div></div>
What is your viscosity? </div></div>
15-40. In the morning I am calling to find out what they (ITE) consider to be out of line. I will post what I find out.
Old 09-06-2007, 01:16 AM   #15 (permalink)
Dang that alphabet thing will get me every time. So used to typing CI....
