Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 11-22-2007, 07:23 PM   #1 (permalink)
First Oil Change
Did my first oil change. 1000 miles as I like to do with any new vehicle. Quite a bit of metal shaving, I was surprised.
I would expect to see a few, but this truck had more than I expected. And not just the metal powder caught by the drain plug magnet. I'm going to wait to install my Fumoto valve.
Have others experienced the same?
2008 F250 FX4 CC: Job 2
parcours is offline
Old 11-22-2007, 10:21 PM   #2 (permalink)
George C's Avatar
Re: First Oil Change
I think I remember Navistar recommends a 3,000 mile oil change the first time. I think there are special oil additives to insure proper break in.
My 2008 F-350
http://community.webshots.com/user/GeorgeC1959
George C is offline
Old 11-22-2007, 10:26 PM   #3 (permalink)
KINGTUT's Avatar
My Photos: (19)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: George C</div><div class="ubbcode-body">I think I remember Navistar recommends a 3,000 mile oil change the first time. I think there are special oil additives to insure proper break in.
</div></div>
I agree, I think I would have left it in a little longer and I also do not believe that the metal shavings are unusual, unless there is something about the 6.4 engine that is different from most other new engines. I remember an ample amount of shavings on my 6.0 when I changed the oil. Same on my diesel farm tractor. In fact there were a small amount of shaving everytime I changed it. However, I guess I might be a bit off, they were not really "shavings", but very, very minute, very small, much smaller than a grain of salt metal particles. Maybe that is what a "shaving" is. It was almost like metal dust, nothing large.
KINGTUT is offline
Old 11-22-2007, 10:27 PM   #4 (permalink)
Yeh I waited till 3k. Then changed it again at 5k and still alot of shavings.
2008 F-350 Dually Superduty 6.4, 4.30 rear end, 4x4 King Lariat package and one heck of a truck payment.
yougotme is offline
Old 11-23-2007, 09:03 AM   #5 (permalink)
My oil was so black at 2500 and 6500 miles I could not see if there were shavings in it or not. I know the filter on the first change had some metal in it, and the second one almost nothing.
Michael B.
2008 F350 XLT, SC, LWB, SRW. 6.4 L. 4x4. 6 spd. Job 1. As of 17OCT08, 29,342 miles.
Traded: 2008 Nissan Frontier King Cab NISMO, 4.0 V6, 6spd, Majestic Blue, Cargo Mgt System.
2009 VW Jetta Sedan, 2.0L TDI, 6spd, Silver, Protection Pkg. Bought 23OCT08
CMB430 is offline
Old 11-23-2007, 09:25 AM   #6 (permalink)
George C's Avatar
Metal shavings are completely normal, and none of that stuff will get past your filter. Don't let that stuff be a barometer of your particular engine.
Black oil in a diesel is also very normal. Look at a big rig's oil after a couple thousand miles. It gives a new meaning to the word Black.
My 2008 F-350
George C is offline
Old 11-23-2007, 10:45 AM   #7 (permalink)
What additive would be added from Navistar and to do what?
Isn't Ford the ones that add the factory fill?
I'm going to send the oil in for a sample and see.
parcours is offline
Old 11-23-2007, 01:16 PM   #8 (permalink)
George C's Avatar
There is an additive in the original oil.
I wouldn't worry too much about that either. Fresh, clean oil can never hurt, just don't let metal shavings spook you. It's normal and expected.
There is also a "color" additive which glows under a special light to make oil leaks easier to trace.
My 2008 F-350
George C is offline
Old 11-23-2007, 01:39 PM   #9 (permalink)
KINGTUT's Avatar
My Photos: (19)
I think how "black" the oil is, is related to the particular engine design. I remember that my 6.0 did not get "black" for thousands of miles, yet my VW Jetta was "black" after you rode around the block. The 6.4 must be one of the types that gets black quick, either way it has no affect whatsoever as to the effectiveness of the oil to do it's job, that is as long as it is changed at the proper intervals.
KINGTUT is offline
Old 11-23-2007, 02:07 PM   #10 (permalink)
I think the general consensus of opinion on the 6.0s when they were new, was that the so-called "break-in" oil was simply 10-30 oil with a dye in it to help the dealers find reported leaks.
I am a big fan of getting the new engine oil out soon, like a thousand miles or sooner. I don't want crap in my oil pan. I know there are baffles in it, but just what does happen when you corner or accelerate or decelerate hard? I don't want anything but clean oil getting slapped around by the crankshaft.
As others said, the color is determined by the type and brand of oil and the driving habits of the operator. Some friction modifiers are natively dark colored.
The metal was probably the remnants of the factory machining that did not get cleaned out properly.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 231,000 miles. Uses no oil between changes.
montanafan is offline
Old 11-23-2007, 10:18 PM   #11 (permalink)
I did notice how black the oil was for only 1000 miles...
And we're supposed to be able to go 10K miles of normal driving or 5K of severe driving between oil changes, wow...
Does any one know if the 6.4 shears the oil the same as the 6.0?
parcours is offline
Old 11-23-2007, 11:08 PM   #12 (permalink)
Puzzled's Avatar
My Photos: (12)
You guys are making me feel unworthy of owning this 08. I went 9300 miles before pulling the plug the first time. No metal in the oil. I was actually surprised as I thought I would have seen more.
On that note I switched to full SYN for the first time in my life in a four wheeled vehicle. The cost hurt but the truck feels different, a tad quieter, a little smoother in the morning. Than again it could be the lighter wallet syndrome.
2008 F350 Super Duty XLT, 6.4, Auto, Crew Cab, Long Bed, 4x4, Silver!
XD Monster Black 20x9, LT275/65SR-20 Goodyear Wrangler AT/S E, 2 1/2" front leveleling kit, Arnott Industries rear air bags w/ Air Lift on board compressor,
Puzzled is offline
Old 11-24-2007, 12:58 PM   #13 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Does any one know if the 6.4 shears the oil the same as the 6.0? </div></div>
Since the 6.4 uses a different injection system and has no HPOP, I'd say no, it doesn't.
OMCUSNR is online now
Old 11-24-2007, 06:57 PM   #14 (permalink)
Super Duty John's Avatar
My Photos: (55)
Back in the old days, pre-'03.25 6.0L...the so called 7.3L days, we asked an Engineer at one of the Diesel Stop Rallies we had what the official stance of Ford and Navistar was on the first oil change. This guy was actually from Navistar and he said leave the oil in till at least 3,000 miles. The florescent green oil is 10w 30 with dye. The reason he said to leave the oil in was to properly break in the engine, they had calculated the shear and metal pollutants in the oil and said they wanted to have the first oil go at least 3,000 miles. Will this be the same for the 6.4, I don't know but I think the manual should be your guide.
I just checked mine and I'm at about 2,200 miles it's still full and plan on going to 3,000 this time. I have changed oil at 1,000 in the past but in retrospect, I think it was a total waste. My big quandary this time is...should I too move over to full synthetic oil? I've done so with my 2007 3.0L Sprinter and that little thing takes 14 quarts too!!! BTW, my 2,200 mile oil is black as coal as is the oil in my Sprinter (Mercedes B) engine in about the same mileage.
John
2008 Job 2 F-350 4x4 Crew Cab SWB dually
Lariat with the chrome package.
Super Duty John is offline
Old 11-24-2007, 11:09 PM   #15 (permalink)
Brad777's Avatar
My Photos: (16)
Had mine changed today for the first time with 3014 miles on the odometer. I have an outstanding local dealer that I'm really comfortable with. Cost was $68 for the oil change and another $13 for a bottle of Motorcraft Cetane. With a $50k truck, peace of mind is everything.
2008 Ford F350 Long Bed
White/Pueblo Gold Accent
Lariet, Automatic
Loaded, w/exc. to Navigation
Skyjacker 6" Lift and Steering Stabilizer
Toyo 37"x13.5-20 MTs
Eagle Alloy Chrome 114s
Amp Research Electric Steps
Brad777 is offline
