Friend waits 8000 miles to change factory oil!! - Diesel Forum - TheDieselStop.com
Old 06-15-2008, 02:42 PM   #1 (permalink)
dieselmankane's Avatar
Like the title says, my buddy bought a new 08 F250 SD 6.4, and he waited 8000 hard miles to change the oil. He floored it everywhere he went, and was hard on this new engine, but finally changed it today. I told him for months now that he would eventually ruin something if he didn't change it. Finally he bought some Rotella and changed it out, with my help (he does not even know how to check his own oil). I found lots of metal shavings, in the oil filter, and sludgy metallic oil on the magnetic drain plug. The oil was like syrup, just nasty, and even after the new oil was put in, it turned black after only 20 seconds of running the engine, and I mean BLACK! MY 6.0 with 2000 miles on the oil was about 10 shades lighter, and still looked clean-ish. So any thoughts here, I showed him the oil filter all spread out, and it was just covered with little metallic peaces! How much metal is normal on a new engine's first oil change? Any ideas here? Did he screw his engine over already?
2003 F250 Super duty 6.0 PSD, was great in the beginning, but started to have major issues:
Traded, Oct 2 2008 for...
New truck: 2008 F250 Superduty Lariat 6.4 PSD Job 3, black, with ALL the goodies, very impressed so far...
[SIGPIC][/SIGPIC]
dieselmankane is offline
Old 06-15-2008, 03:15 PM   #2 (permalink)
I ran my first oil change to 5k... I know most people will tell you that you should drop the first oil within 500 miles.... I run all my oil changes to 5k.... I didn't notice anything different about the oil when it drained except a fuel smell to it..... oil anaylisis came back fine.
The oil anaylisis did come back and tell me that 5K is the limit for my Delo 400 that I'm running. My last sample only had 3% lubricity left in it at 5340 miles. So, 5k it is!
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 06-15-2008, 04:27 PM   #3 (permalink)
Stymie's Avatar
you know the factory requirement is 10k....
i changed mine around 8ish also, and have had no problems.
As for the color, when you changed it, did you pull the old filter and drain the oil bowl, than drain the oil, or did you put the plug back in before removing the filter? If you did the second, you dumped 1.5 qts of dirty oil into the pan.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 06-15-2008, 10:58 PM   #4 (permalink)
Does anybody think that all the metal in there is a problem? Yes, I did change the filter first and then drained the oil. I know that from my 6.0, very similar setup.
[SIGPIC][/SIGPIC]
Old 06-16-2008, 06:43 AM   #5 (permalink)
George C's Avatar
I change every 3K-4K.
Oil is cheap, and so is the filter.
My 2008 F-350
KEM 345 tuned
2011 Chevy Silverado
2010 Chevy Tahoe
http://community.webshots.com/user/GeorgeC1959
George C is offline
Old 06-16-2008, 08:30 AM   #6 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
I change at 15-18K depending on the oil analysis, but I have bypass filtration installed.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
Old 06-16-2008, 12:21 PM   #7 (permalink)
luke0204's Avatar
I probably wouldn't have waited that long. I went about 4.5K on my Dmax, the Powerstrokes I changed before 3K. I got filings in both my 6.0L's and I'm sure the others too but I didn't cut the filters apart but on the 6.0L and 6.4L it's easy to see.
If it comes out that way in the next 8K miles I'd worry, obviously he doesn't care so I wouldn't lose sleep over it either.
2011 F-250 CC, SB, 4x4, 6.7 Powerstroke, 3.31 E-Locker
Past Toys:
2009 F-250 CC, SB, 4x4, King Ranch, 6.4L,Torqshift, Spartan Tuned
2009 Dodge 2500 QC, SB, 4x4, 6.7L Cummins, 6 spd, Edge Insight
2007 Chevy 2500HD Classic, CC, SB, 4x4, Duramax LBZ, Allison 1000, 4" MBRP Cat Back, Diablosport Predator, Edge Insight
2005 F-250 CC, SB, 4x4, Torqshift, 4" Cat Back w/MBRP Muffler
2004 F-250 CC, SB Fx4, 6spd, Bully Dog Intake, Banks 4" turbo back, Edge Juice w/Attitude
2002 F-250 SC, SB Off-Road, 6spd, AFE Intake, ATS Turbo Back Duals, B&D 60hp chip
luke0204 is offline
Old 06-17-2008, 01:51 PM   #8 (permalink)
I go 5-8k on mine. The manual says 10K. The oil on the new 6.4 will turn black within a few minutes because of the EGR. You can change it every 20 miles and will still look nasty, it doesn't affect the lubrication.
2008 F-250 Lariat 4x4, 6.4L, 4 tires, brakes, windshield, windshield wipers, tailgate, bumpers, blinkers, headlights, spare tire, rear bumper, hood, antenna, driver AND passenger seats, speedometer, radio, steering wheel, & spare set of keys!
Hydro is offline
Old 06-17-2008, 09:48 PM   #9 (permalink)
Ya'know cummins actually emailed us and told us not to change the oil early. They said the metal shavings are actually needed for the engine to properly seat the rings and such. However, your friend should know that during breakin that the pinions and such are sensitive to abusive breakins(If it gets hot during breakin it weakens the drive gearsd greatly) and will probably wear out faster because of the idiotic driving. The engine can probably handle the rough break in but its murder on the tranny and diffs.
"Im voting for Dukakis"
1984 E350 Quadravan, 6.9 IDI, 4x4, E4OD, ext. van : recent acquisition 1984 mitsubishi mighty max 4x4; a work in progress to run on homebrew if all goes well
BigDaddyT is offline
Old 06-18-2008, 12:27 AM   #10 (permalink)
Well Ill tell him that he probably did some damage, and maybe he will slow down. I haven't ever done an oil change on a brand new engine, so I was just a little shocked by all the little metal pieces.
[SIGPIC][/SIGPIC]
Old 06-20-2008, 09:17 PM   #11 (permalink)
ford_doctor's Avatar
If I am not mistaken, the interval for severe duty use is still 5,000 miles. Most people fall under that category by definition. There are reasons for the 10,000 mile interval like the reduced sulfur content of the fuel. But there are other issues that you really need concern yourselves with. We are learning that these engines will make oil even under normal conditions. The regen process greatly increases fuel dilution of the engine oil therefore, depending on several factors your engine oil level may rise significantly and this can fluctuate. I saw quite a few trucks with 6.4L engines over the winter with 3-4 "extra" quarts in the crankcase due to the colder weather. Fuel quality, driving habits and vehicle usage that determine how often your truck regenerates the DPF will also contribute to fuel dilution. The more regenerations that take place, the more likely your oil level will rise and idling is now more detrimental than ever. There is no official statement from Ford on how much is "normal" so don't go looking. Since there are quite a few variables, to narrow it down to X-number of quarts is impossible. Checking your oil regularly is highly recommended.
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is online now
Old 06-21-2008, 04:50 PM   #12 (permalink)
This is for the Doctor. I have about 5K on my new 2008 6.4 and I think I am going to change the factory oil this week before pulling my 23' trailer on vacation. I am curious about the fuel in the oil, once the engine is broken in will that still be an issue?
Thanks, Steve
Blind_Squirl is offline
Old 06-21-2008, 05:31 PM   #13 (permalink)
I'd like to have a copy of that e-mail.
444-4D is online now
Old 06-22-2008, 07:15 AM   #14 (permalink)
Been changing mine at 3500 mile intervals. Yes seeing metal shavings in a new engine is normal as all those new parts get used to each other.
427tunnelport is offline
Old 06-22-2008, 08:34 AM   #15 (permalink)
ckduallie's Avatar
I have been changing my oil on the 21 different new vehicles (all BLACK) that we have had so far, 3 of which were/are diesels at the ~1000 mile mark. Sometimes I have noticed a very small amount of little metal particles but I have never had issues like burning oil or oil levels increasing. My 6.4 has 24K on it now and I have been changing the oil at 3k intervals since the first one. I think and feel great about having fresh clean oil in my engines. The one thing I will never understand is the idea of sending your oil out to be analyzed. It seem wrong to wait for someone to tell you your oil has begun to break down and it is time to change it . Why wait, why not keep good clean well maintained oil in your engine at all times? Oil changes are a lot cheaper than trips to the mechanic and I like how it keeps me in touch with the “underside” of my: 2008 F350 FX4, 6.4, 2008 Infiniti FX35 & 2008 Mazda 3, 5 door.
2008,F350,FX4,Black/Black Leather Captains Chairs,CC,DRW,4:30s,Auto,Tow Boss/Tow Command,NAV,DVD,Sup Htr,Upftrsw,Adj Peds,200A Alt. Edge Evolution, AIRAID Intake, Magnaflow 5" DPF back,Husky mud flaps,Lund vent visors,Reese 20K// Towing 2005 HR Presidential 36 SKQ, Loaded
ckduallie is offline
