6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I am currently experiencing quite a bit of play in the front end of my truck. I have taken it two places (4 Wheel Parts and the Ford Dealership). I received two completley different diagnosis. Who do I believe????
It started all this after I hit a t-post with the front end of my truck. It seems like from the 11o'clock postion to the 2o'clock position I have no steering controll (just free play).
Ford Dealership:
Replace Steering Arm
Tighten Pitman Connection
Replace Dual Steering Stabalizer
Cost: 600.00
4 Wheel Parts:
Replace Tie Rods
Rod Assembly
Joint Assembly
Idler Arm
Pitman Arm
Ball Joints
Steering box
Price:3,000
**They are crazy my truck only has 24,000 MILES.
__________________ 2011 Ford F-250 King Ranch 4x4
Tri-Coat Platinum White with Adobe. Sunroof, Navigation, 4x4, 6.7L, LineX, 8" Pro Comp Double XX Coil Over Kit, Amp Research Steps, 22"x11" KMC Badlands, 37"x13.50"R22 Nitto Trail Grapplers, H&S Tuner DEF/DPF Delete, FloPro 5" Exhaust, AFE Intake.
2008 Ford F-250 King Ranch 4x4
(6" Stage II Pro Comp Suspension Lift with Dual Steering Stabalizers, 37x13.50x22 Toyo Open Country M/T's, 22x9.5 Helo HE837 Wheels, FloPro 4" exhaust w/ 7" tip, JL Audio sound system, Alpine Navigation, Power Programmer SPARTAN TUNE!!!) It is slow I promise!!! - SOLD
2006 Ford F-150 King Ranch 4x4 (8.5" Suspension Lift, 35" Nitto Mud Grapplers) - SOLD
Ford Dealership:
Cost: 600.00
4 Wheel Parts:
Replace Tie Rods
Rod Assembly
Joint Assembly
Idler Arm
Pitman Arm
Ball Joints
Steering box
Price:3,000
I don't believe that for a second. At around 36K miles, I replaced (on my penny - not warranty) the steering gear box. Total cost just under $1800 because for the 08+ there are no rebuilt boxes available (yet). The cost for the box alone was around $1200.
But, my issues were similar. In essence I ended up with about 10+ degrees of "no action play" at the steering wheel. Not much fun driving down a road with truck grooves in it.
After replacing the box and re-aligning my front-end, the steering is just fine. There were no other problems with it. Meanwhile, I added a dual steering damper from Kelderman. Highly recommendable. It will hopefully preserve and extend the live of the steering gear box aside from adding a lot of confidence in your vehicle behavior when driving down a bad road or crossing rail-road tracks and the like.
Thanks guys. That sounds about right. I did notice that my steering box is leaking fluid. Unfortunatley this will be out of my pocket since I have an after market suspension lift. I will get with dealership and try to track down the cost for this. Well I guess I know what I will be getting for Christmas.
