Fuel Additive - anyone using??? - Diesel Forum - TheDieselStop.com
Old 07-30-2008, 10:57 AM   #1 (permalink)
Hi All,
Newbie here. Thanks for helping me with this. First a disclaimer that I did search for this topic prior to posting and found little. I hope I'm not opening a can of worms here but.......
My question is anyone using a fuel additive with each tank? If so, what are you using and what results have you seen.
PagosaRob is offline
Old 07-30-2008, 11:16 AM   #2 (permalink)
prosthogod's Avatar
I've used RBP, Lucas oils, and now XPD summer. can't see any difference in any of them and noe difference in mpg, in my opinion a waiste but the manual says you need to.
prosthogod is offline
Old 07-30-2008, 11:33 AM   #3 (permalink)
dieselpwrdude's Avatar
I use diesel kleen,its cheap.Seems to work ok and does increase my mileage a little.Only use it once a month or sometimes twice,it cant hurt.
2003 XLT 250 Ford Super Duty Ext Cab. PSD 7.3 Stock.
dieselpwrdude is offline
Old 07-30-2008, 12:42 PM   #4 (permalink)
slurrr's Avatar
I also use Diesel Kleen since around 3,000miles, every tank since then, seems to be about a .5 mpg increase, currently have 18,000 miles
2008 F250 6.4L 4 X 4 (Job 1) Crew Cab Lariat Shift on the fly, 3.73
White w/ medium stone leather interior
Banks six gun with PDA, ram air intake and 4" Single Monster Exhaust
Billet front and side grilles
Rhino Liner
slurrr is offline
Old 07-30-2008, 12:56 PM   #5 (permalink)
I use a treatment in every tank. I have used fuel teatments since I put in my Baby Swamps which was about 200,000 miles ago. Last fall I took my truck to the strip and ran a 15.6 @93mph in 2wheel drive. I am using Schaffers summer treatment now. 1 gallon treats 4000 gallons of fuel. I have a test of several different fuel treatments that I found last summer. Send me a pm and I will email you a copy of it.
Good Luck
Midwestman
John
95 350 CC SRW 4X4.456K. Amsoil everwhere w/dualbypass filter. Early Centurion model custom paint (white with grey striping) Grey shell, brushguard, Flexsteel leatherseating wood trim and overhead console. BTS hold on tight E4OD tranny. Custom chip by Cale Thompson at BTS. Hypermax DP. Tymar Open element intake. Tru-Cool 28,000 GVW trans cooler plus Super Duty trans cooler. Super Duty Intercooler with GTS pipes. CCV mod. 3 pod A pillar guages with Isspro Pyrometer,Boost and Tranny temp guages. Fumoto oil drain. John Deere coolant eye. Sylvania Ultra Silverstars. Joe Servo IDM. BABY SWAMPS. Magnaflow 4" exhaust. Tymar Coolant Filter. Sirius satellite radio. Kelderman Air Ride on the rear. Autolights clear diamond headlights. Mods as the budget will allow.I think I am almost finished.
midwestman is offline
Old 07-30-2008, 01:19 PM   #6 (permalink)
I use 12 oz of Diesel Kleen in each tank. I get about 0.5 mpg more and have 1/2 the regens when compared to a tank without.
Michael
2008 F350 XLT, SC, LWB, SRW. 6.4 L. 4x4. 6 spd. Job 1. 32,000 miles. GONE
2009 VW Jetta Sedan, 2.0L TDI, 6spd, Silver, Protection Pkg.
2004 Explorer XLT, Silver, 4.0L, 4x4, STOCK
CMB430 is offline
Old 08-02-2008, 11:16 AM   #7 (permalink)
08KINGRANCHF250's Avatar
I have noticed the same thing about less regens when using diesel kleen. I have almost 3000 miles now and have only noticed about 4 regens. I add 8oz to every tank.
08KINGRANCHF250 is offline
Old 08-02-2008, 01:10 PM   #8 (permalink)
I don't think the manual does. It's very specific about what instances you might need to, but a blanket statement like this just simply isn't true.
timid1 is offline
Old 08-02-2008, 08:42 PM   #9 (permalink)
The best fuel additive for lubrication is biodiesel (even B5 helps a lot). 2nd best is two-stroke oil.
2000 F-250 7.3L Powerstroke. Build date 08/99.
snakyjake is offline
Old 08-02-2008, 09:02 PM   #10 (permalink)
BigDogOil's Avatar
I have talked to the Ford service department and they recommend that you use in the 2008 6.4 liter is a Ford Power Stroke Cetane Booster & Performance Improver, you put 4 oz in a 25 gallons of fuel. It is formulated for this particular engine and I realize it is made and sold by Ford but a 20 oz bottle here in Canada is $11 and some change. I can't tell you at this moment if it has helped with mileage of not as I'm really hard on the throttle. Don't know if this helps out anyone, when I'm finished playing with my newly installed tuner i'll start to check mileages.
BigDogOil is offline
Old 08-03-2008, 07:42 AM   #11 (permalink)
I posed this same question to my Service Manager. His response was that the 6.4 was designed around the ULSD and didn't feel there was much to be gained by using an additive. But he also said using the Ford additive every 4th tank would aid keeping it lubricated. The Ford additive treats 4 tanks (120 gal) and is $10. With ULSD at $4.69 what's another $2.50 for piece of mind.
Old 08-03-2008, 03:06 PM   #12 (permalink)
PagosaRob: This is my first diesel engine so I’ll give my 2 cents, In Canada at the Ford dealer, a bottle of cetane boost is $12.50, I was on vacation in the United States and bought 6 bottles of cetane boost (@ $7.00) at a Michigan Ford dealer. Usually I don’t run the tank empty so one bottle will give me 5 tanks. Today where I live a U.S. gallon of diesel fuel would cost me $5.75. So here are my thoughts on using additives, Ford recommends that you use ULSD fuel with a 45 cetane rating which I haven’t found yet and I’ve went through over 20 tanks so far. Also the additive is a cleaner, so it’s doing more then one job for $1.40 a tank or add $.05 to a U.S. gallon of diesel fuel.
So saying that: I do a lot of different driving, so I can’t say if it helps the MPG but I’m sure it doesn’t hurt the MPG. I do know that the engine seems to sound and run better, because I skip a few tanks to see. So looking at the big picture, at a $1.40 worth of additive a tank or $.70 every other tank for an engine that cost me $10,000.00, I am going to keep using the fuel additive, and when I find an additive that is better then Fords (and I’m sure there is!!), I’ll will be using that. Just to add some more math, I have burnt over 500 gallons U.S. at the cost of $2875.00 and the additive cost me less then $35.00. If I drove 5000 miles and got 10mpg without the additive and 10.5mpg with it, I could drive 250 miles more and I would save $101.91 every 5000 miles (250miles/10.5mpg x $5.75 - $35.00 = $101.91), of course this is an old man’s math and I’m sorry about the length, but also since I’m on a roll, if I did get .5mpg more with using additive, it would pay for it’s self in 51.85 miles and that is not counting the other good things it suppose to do . I’m not an employee of Ford, a Mechanic or a math teacher. So if I’m blinded by using this “Snake Oil” please enlighten me. You have a great day.
MPD56
-2008 F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29.
-1972 First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson).
-First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards.
-1982 - My Sister married a GM Sales Manager (He Retired 2007, "Hello" Ford Super Duty, enough said, LOL).
-2003 - ZRX1200 (Some say "Mid Life", LOL).
-2008 - Jayco 313RKS 5th (The kids won't move out of the house).
MPD56 is offline
Old 08-03-2008, 06:27 PM   #13 (permalink)
That's awesome. A Ford service department recommending Ford cetane booster. Why doesn't that surprise me?
You're not going to notice a difference within just a few tanks. And you're certainly not going to know if it had any effect if you use a tuner. In order for you to KNOW what had an effect on your mileage, you'd need to maintain a log of a lot of different things. And you have to minimize your variables. Oh, and gassing up at different gas stations will throw a wrench into your calculations.
timid1 is offline
Old 08-03-2008, 06:39 PM   #14 (permalink)
i have been using stanadyne in every tank on my 01 psd it has close to 180,000 miles and i get a little over 400 miles to a tank. its a 24 gallon tank.
bwoods is offline
Old 08-03-2008, 08:20 PM   #15 (permalink)
jsmichael's Avatar
Originally Posted by PagosaRob View Post
Hi All,
I usually go with the Power Service additives, both in my former '99 Super Duty and now in my '08 truck. I'll use Diesel Kleen in the summer months and the Diesel Fuel Supplement for the winter months. I've also picked up a bottle of the Ford Cetane Booster additive but haven't used it yet.
If you live in a colder climate where temps get in the single digits or colder, then I'd recommend something with the anti-gel additives. Stanadyne has decent additives as well, but they cost more than the Power Service additives which I can pick up at my International dealer.
I've also heard a story where the Stanadyne additive would start gelling before the Power Service additives do, but I think that was at temps below -20 degrees F.
'08 F-350 XLT (Job 3) 4X4 6.4L PSD CC SRW LB, Line-X bedliner, UWS toolbox, Goodyear Wranglers (Silent Armor), Marathon seat covers, Edge Insight
jsmichael is offline
