Fuel Consumption at Idle - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 04-28-2009, 01:35 PM Thread Starter
My Photos: (6)
As the title suggests, does anyone know the fuel consumption of the 6.4 motor while at idle as stated in gallons per hour?
Need to know for a proposal for some work where we will have trucks sitting idle for long periods.
Thanks in advance for your help.
2015 F-150 CC 4x4 Platinum Ecoboost
2016 Explorer Platinum Ecoboost
2017 Fusion Titanium Ecoboost
pstroke is offline
post #2 of 11 (permalink) Old 04-28-2009, 06:19 PM
Sorry I don't have the fuel consumption at "idle", but I'm always curious why someone needs to idle for extended periods.
Diesels do not like to idle. They work best in their power band with little variation, but "idle" isn't it. If they need to sit for long periods used as a PTO, they should be idled up to about 1250 rpms (min) or what the PTO requirement will be. A 6.4 will regen MUCH more frequently at idle than in it's power band. So figure your fuel consumption at something over 1200 rpm.
OMC
OMCUSNR is offline
post #3 of 11 (permalink) Old 04-28-2009, 09:38 PM
Banned
I don't know about "gallons per hour" because there are way too many variables..... temp, rpm, electrical load, probably some I forgot....
Diesels like to work... they like to have hot combustion chambers.... they weren't built as noisemakers... they were built to do stuff.... Does someone buy a mine truck because they like noise? No... they want to move dirt... lot's of it.. lot's of it all at once.
FWIW... there are a lot of BIG diesels that get to idle for long periods of time.... they get to do that because they are friggin' hard to get started.... not because they sound nice sitting outside...
Oops. nearly forgot.... that works out to zero miles per gallon....
GrampyJim is offline
post #4 of 11 (permalink) Old 04-28-2009, 09:55 PM
We figure our 15 liter big truck engines use about 1.5 gallons per hr. I would guess 6.4 at about 1 gallon per hr.
jcason is offline
post #5 of 11 (permalink) Old 04-29-2009, 11:58 AM
Harley350's Avatar
Fill fuel tank, idle for one hour, fill tank. Now you know exactly how much it burns per hour. Simple!
Harley350 is offline
post #6 of 11 (permalink) Old 04-30-2009, 05:20 AM
I bet it's less then 1 gal per hour because I have to sleep in mine lot's of times inbetween jobs while traveling away from home and it doesn't burn much at all after hours of idleing.
2016 F350 Lariat Copperfire Bronze,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Captcaper is offline
post #7 of 11 (permalink) Old 05-03-2009, 04:31 PM
rock_doctor's Avatar
for what it is worth ford says one hour of fast idle (1100rpm) equals approximately 33 miles of driving.
rock_doctor is offline
post #8 of 11 (permalink) Old 05-03-2009, 05:21 PM
I get about 350-400 mpg, so if an hour of idle equals 33 miles, then after 11 hours I would be on empty? Seems like that wouldn't be right. I've slept in mine overnight in the cold - 8 hours of idle - and haven't spent more than a 1/4 tank. I'd like to know a definitive answer though. Not saying you're wrong, I guess Ford would know better than anyone else.
blue cowboy is offline
post #9 of 11 (permalink) Old 05-03-2009, 10:21 PM
compman72's Avatar
My Photos: (9)
2008
F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
Break Pressure switch (cruise control failure) 99,300 miles 3-13-12
New BF Goodrich Rugged Trail T/A tires after 101,400 miles on the original
BF Goodrich Rugged Trail T/A tires 3-27-12
New Batteries after an original boiled over at 105,300 miles 5-13-12
Fuel Pump Replaced (frame rail) 131,534 miles 4-5-13
compman72 is offline
post #10 of 11 (permalink) Old 05-03-2009, 10:29 PM
6.0/6.4 Fuel Economy:
Ford vehicles equiped with the 6.4 PowerStroke diesel are not rated for fuel economy by the EPA. If economy is in question, a boost test should be performed. If boost reaches 22-25 PSI in third gear, wide open throttle under load, then the engine s operating normally and no economy related repairs need to be performed. If not in specs, then the engine will need to be diagnosed--check sensor reading, VGT and EGR operation, fuel pressure and quality, crankcase pressure, intake or exhaust restriction, exhaust or CAC leaks.
Fuel economy will be affected by many factors, including: excessive idle time (one hour equals approximately 33 miles of driving), fuel quality and blend, ambient temperature, driving habits, vehicle use, towing, loads, add-on accessories. Broadcast Message 1271, 4450, 6989
Actually, it does seem high, by their numbers you would burn a gallon and a half of diesel in an hour (assuming you get 20mpg) of idling. I don't know i would bid it at .75 gal per hour and if you are high then you will break even with the more frequent oil changes and regen cycles.
post #11 of 11 (permalink) Old 05-04-2009, 11:38 AM
Originally Posted by compman72 View Post
Spartan
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
