6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Tom in Manssas
Have: '08 F350 6.4L CC 4x4 King Ranch
had: '03 F350 6.0L SC 4X2 Lariat
had: '99 F250 7.3 SC 4X2 XLT
Have '04 32 ft Newmar Amreican Star
Had: '00 27 ft Coachman 279SA 5er
The auxillary cooling system is an entirely separate system from the primary (engine} cooling system.
Consists of the OTA heat exchanger, the electric coolant pump, the fuel cooler and the VGT actuator cooler. The coolant pump can run anywhere up to 10 minutes after the truck is shut off.... that ought to please the folks that didn't like the post cycle injector buzz though I must admit I haven't heard the pump run yet to see what noise level it emits.
Neither the diesel owners supplement nor the WSM differentiates between the two cooling systems and only states "coolant exchange interval". We are left to assume that the service interval for both is the same (until we see a TSB, SSM, or broadcast message stating otherwise).
For anyone that is going to perform their own cooling system service, there is a special procedure for purging air from the auxillary cooler.
I am asking this because the magnitude of the importance is directly proportional to the likelihood of having a problem…
Tom in Manssas
It ain't exactly one of those repairs you'd want to perform on the side of the road:
Fuel and Turbocharger Cooling System Draining, Filling and Bleeding
Draining
WARNING: Always allow the engine to cool before opening the cooling system. Do not unscrew the coolant pressure relief cap when the engine is operating or the cooling system is hot. The cooling system is under pressure; steam and hot liquid can come out forcefully when the cap is loosened slightly. Failure to follow these instructions may result in serious personal injury.
1. Allow the fuel cooling system to cool and remove the pressure relief cap.
2. Disconnect the coolant hoses at the fuel cooling system radiator and drain the coolant into an appropriate container.
1. Connect the coolant hoses at the fuel cooling system radiator.
2. NOTE: The side bolt does not have to be removed to remove the fuel cooling system radiator.
Remove the fuel cooling system radiator top bolt.
3. Slide the fuel and turbocharger cooling system radiator up off the side bolt and position the radiator horizontally.
4. Remove the plug from the turbocharger actuator cooler.
5. Fill the fuel and turbocharger cooling system through the expansion tank until the coolant reaches the top of the turbocharger actuator plug hole.
6. Install the turbocharger cooler plug. Tighten to 33 Nm (24 lb-ft).
7. NOTE: If the coolant pump does not operate when the ignition switch is turned to the RUN position, disconnect the coolant pump-to-fuel cooler hose from the fuel cooler, place the end of the hose in a clear container and run the engine until the coolant pump turns on and coolant starts to fill the container. Shut the engine off, connect the coolant pump-to-fuel cooler hose to the fuel cooler and proceed with the bleed procedure.
Turn the ignition switch to the RUN position to activate the coolant pump. Allow the coolant pump to run for one minute.
8. Turn the ignition switch to the OFF position.
9. Remove the plug from the turbocharger actuator cooler.
10. Fill the fuel and turbocharger cooling system through the expansion tank until the coolant reaches the top of the turbocharger actuator plug hole.
11. Install the turbocharger actuator cooler plug. Tighten to 33 Nm (24 lb-ft).
12. Fill the coolant expansion tank until the coolant in the coolant expansion tank is visible through the site glass.
13. Position the fuel and turbocharger cooling system radiator and install the bolt. Tighten to 12 Nm (9 lb-ft).
14. Install the pressure relief cap.
15. Clean any coolant that may have spilled on the engine components.
Hmmmmmmmm, seems like a simple enough procedure to me! [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
Dave
Yeah, what's the big deal Jay? Sheesh. My Ipod is more complicated than that.
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Fuel cooler? Why exactly does the 6.4 need a fuel cooler? WTH is a fuel cooler?? [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/depressed.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
[/ QUOTE ]I second that! Since when do we have to keep our Diesel cool? [img]/ubbthreads/images/graemlins/shrug.gif[/img] It would probably be cheaper just to dump some dry ice in the tank. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
__________________ 2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Consider how hot the pump would run pumping 28,000 psi. Excess fuel is diverted to the cooler and returned to the pump for cooling the pump and to be sent to the injectors.
[/ QUOTE ]Ok I guess I will ask a stupid question,based on that theory does the 6.0L have a fuel cooler? I think the 6.0L puts out around 21,000 psi,just wondering. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
[ QUOTE ] The 6.0 is an apple... the 6.4 is an orange. I dare anyone to compare them.....
Some people may think you have chosen the wrong fruit for an analogy of the 6.0 motor. Some would say the lemon is more appropriate. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
PS: I love my 6.0 [img]/ubbthreads/images/graemlins/grin.gif[/img]
[/ QUOTE ]You may have just jinxed yourself there gearjammer. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
That's OK. It's still under warranty and my new 08 is sitting at the rail yard in Tampa waiting to load for a trip to the dealer.[img]/ubbthreads/images/graemlins/biggrin.gif[/img]
