6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I'm curious what the fuel economy on this new motor is going to be. My 6.0L has never gotten better than 15...... what pisses me off is that my dads d-max gets 19-20 all day long!
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
if your dad drives like mine it's no suprize he gets better mileage. they can all get great mileage it all depends on your right foot.
02 F350sd psd, 6spd.4x4 CC lariat, camper pk, off road pk, Blizzard 810 plow
SOLD 92 f250hd xlt 7.3n 5spd 4x4 sc xlt 228k, bone stock(original clutch), western plow
sold 78 f250, 351m400 guzzler black jack headers(dually custom full time 4wd)auto, tow truck pto winch, diamond vee plow
A good frind of mine bought a new 04' D-Max with an allison and he tells me that he has never gotten better than 15mpg
85' F250XL Reg. Cab. 6.9L, C-6, 105K, Stock, 3.55 gears
Planning on new headgaskets, rear main, rust repair and complete paint job, and a hypermax turbo this winter. Want to start in Dec. (Lots of Q's)
I kinda doubt it, from what I know I don't see anything about the new vehicle that would cause it unless the new injector system somehow increases mileage.
The particulate filter has a flow sensor in it that tells the ECM when the filter is getting clogged. The ECM causes the engine to run rich (hot) for a while to burn up the contents of the filter and restore flow.
Plus, to keep NOX down, they need to burn a little cooler.
I'm not saying that with all the new injectors and electronics, they can't squeeze a few more MPGs out of these smogged diesels, but I have to believe that MPGs will go down. I think that I read 10%-15%, but I can't point to a document right now.
I doubt this new engine will get the MPG the 6.0 does. The 6.4 has this barrier filter that will impose a back pressure and make the engine less efficient. Thank you EPA.
'00 F-350, 4x2, 6 Speed AIC 210,000 miles
3.08:1 Gears
Fuel tank mods: MaroonHarpoon, Pre-Pump,
Evans, 203 degree thermostat, Poor Man's Tymar, 4" Single SS Exhaust, Rugged Air Dam
225-75x16E tires in front 235-85x16Es in back, tires aired up to 100 psi, Lowered 4" in front and 6" in back, "Fastback" bed fairing
21.3 MPG before mods
27.0 MPG tested with mods
Didn't I answer this same statement in another thread? If you read up on the DPF technologies, they actually don't add appreciable backpressure. One of the strategies for determining when to regenerate the DPF is to measure backpressure. When it starts to rise, regenerate, and then there's no backpressure again until the next time it's getting full.
So if all goes as designed (admittedly a big if, perhaps even bigger with Ford's track record!!) you shouldn't be paying any MPG penalty for the DPF. You may well pay a MPG penalty for any number of other emissions-related reasons, but not that one.
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
All the new diesels get less mileage then the previous. An theres also 7.3s that get poor mileage also. Traveling the interstate the last few months I find it hard to believe people are interested in fuel mileage the way people drive. I drove 70 MPH an everybody blew by me like I was standing still going 80 plus. If people would drive 10 mph slower an slow accelerate up to speed my bet is they will get better mileage then they get now. What Ive seen people are driving like ambulance drivers rushing a person to the hospital. trouble is theres no emergency. These diesel have great power but they will take fuel. Cant have your cake an eat it too as the saying goes.
Don't count on it. Emissions trim seems to be lowering mpg according to most folks I've talked to/read of.
068467, BINGO!! Driving style has SO much to do with mileage. I won't even pull at 75 on the interstate. I stick at 70 if not 65, where my particular truck hits a breakpoint where mpg goes downhill. Let the hot rodders or the folks with something to prove pass... speed costs REAL MONEY.
Now I *will* take advantage of an occasional romp out of the gate on base with the Dodge, but that's about all the speedy stuff I'll do.
Another case in point... driving my '01 Impala LS as a commuter, I was getting 23-24mpg under normal to moderate acceleration from all stop signs/lights. When I backed off the throttle I saw a CONSISTENT 28mpg in mixed driving with the car. Added DAYS to how often I had to fill up.
Mike
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
Unless it your cake is a 12-valve Cummins. Then you can have big big power and great fuel economy... that's a simple fact.
When the 2003 Ram came out with the new common rail design, it did pretty well on fuel economy - may drivers including myself managed to get 20+ MPG. In 2004.5, they changed the programming and added an extra injection event for emmissions to cool the cylinders slights and this took a big dent out of the Cummins fuel economy.
I'll be very surprised if the 6.4 gets as good as the 6.0.
Alright, I'm 0 for 3ish so far with the Ford rep I talked to at the Lawn and Garden expo, but I asked his about the fuel economy and he said to expect about 2 mpg better than a 6.0. He did admit that with this increase the average that he would expect would still be around 16 or 17, which to me, is low for a diesel. I think I'll stick with spark plugs.
Cory
when i started looking at the 6.0 they told me it should get 2 mpg better than the 7.3 and i never saw that
05 f350 cc sb lariat loaded bullydog powerpup(being replaced with sct) 4" turbo back straight pipe 6" tip outlook monitor two tone blue and silver funtional ram air hood
big tex 10et 18' for my '41 willys americar coupe
now in the garage:
1969 fj40 with 350v8 sm465 np 203/205 doubler sprung over waiting for 4 more inches of lift and some 40 inch boggers
1984 fj60 needs a 6.0 stroke and few other things
2007 Mazdaspeed 6 270hp, turbocharged, 6spd, awd
coming soon:
new f450 darkstone and pueblo gold
I think that some people did with the original factory tune. Of course, that tune did not meet emissions specs.
Later reflashes fixed the emissions, but MPGs suffered.
Those of you who are old enough remember what MPGs did in the mid-70s with the new EPA rules that were imposed at that time. MPGs eventually went back up, but it took a long time.
