Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 03-01-2008, 12:48 AM   #1 (permalink)
Fuel Line Material
I've got a 2008 F250 anyone have info the the fuel line material and any seals in the fuel system?
racecartow is offline
Old 03-01-2008, 08:16 AM   #2 (permalink)
Harley350's Avatar
Typically, brake, Fuel and Transmission Lines are manufactured in O.E. steel and/or stainless steel. Most of the seals are flare fittings. I gotta know, why you ask?
Harley350 is offline
Old 03-01-2008, 10:41 AM   #3 (permalink)
I've got access to some high quality bio-diesel and I didn't know if any of the fuel lines still used rubber seals. I'm not really excited about going through everything and switching to viton.
Old 03-01-2008, 01:16 PM   #4 (permalink)
You're about 12 yrs to new to worry about it. They made that switch in 96.
Fresh, high quality bio-diesel should run just fine all the way up to B-100 if the temps permit. Rapeseed or soy based methyl esters are good to about 40 before they start to gel. If you are considering home made, be anal about your QC
Remember, though, Ford is sticking with the injector manufacturer's published stance of no more than 5% bio-diesel, so if you have a problem with the fuel system , they may not cover the repair. But they won't cover bad #2, or if you put ATF, 2cycle oil or anything else in the tank either.
OMC
OMCUSNR is offline
Old 03-01-2008, 06:48 PM   #5 (permalink)
Good to know. By temps permitting, I'm assuming you mean so that it doesn't gel when cold?
Old 03-02-2008, 12:05 AM   #6 (permalink)
titaniumfan's Avatar
don't forget that any use of biodiesel in the 6.4L automatically puts you into the severe service maintenance category which may skew your decision dollar-wise depending on how much you drive.
2008 F-450 Lariat Job 1 w/ 4.88, 98 gal. Transfer Flow tank in bed, Tekonsha P3 brake controller, TrailerSaver TS3 air hitch, all for a 2007 Glendale Titanium 36E41MPRV toyhauler (fulltiming about half the year, lots of driving in the Rocky Mountains)
SOLD 2006 Silverado 2500HD LT3 (LBZ Duramax)
titaniumfan is offline
Old 03-02-2008, 12:07 AM   #7 (permalink)
how would using bio-diesel put me in the severe service category?
Old 03-02-2008, 12:00 PM   #8 (permalink)
That's Ford's published way of covering their butts.
Biodiesel is to easy to make at home, and if the QC isn't held really high or if the fuel gets really old, (1yr or so - as it IS biodegradable), it can cause problems, and they want to minimize their exposure to warranty repair.
If you use good quality commercial fuel or make your own to a high standard, then the only limiting factor is the temp it will gel at. One thing that you have to be careful of is water content. Any water at the injectors will flash into high pressure steam, and that will tear injectors apart quickly.
If you make your own, and need to store it, store it in a container that has a dessicant in the breather line, so that as you dispense fuel you draw in dry air.
OMC
OMCUSNR is offline
