6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I know it's kind of a dumb question, but with all the electronics on this beast I was wondering if fueling while the engine is running causes the check engine light to come on. I know some vehicles that don't have their fuel caps on properly will throw a code, so I wasn't sure if the same applies to these trucks. Yeah, yeah I know that it's a "safety risk" but it's getting colder here and I'd sure like to keep the heat going when it gets really cold.
-Jason
2008 F250 Lariat, 4X4 Off Road, Snowplow Package, Nav System, Tow Command
1995 F150 5spd 4x4
I always fuel mine while its running. Haven't had a Check Engine light yet.
99 F350 4x4 CC Long Bed 6 Speed- SOLD IT FOR MY 08 6.4
71 Ford Single Cab Short Bed 4x4 - Transplanted 96 7.3, Rockwells, 18" Coil overs
08 6.4 F250 4x4 Ext Cab - Silver, B&W Turnover, Moto Metal 951 Black wheels, Nitto 295/17, Spray in liner, and more comingShe runs like a striped a** ape!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jss304</div><div class="ubbcode-body">I know it's kind of a dumb question, but with all the electronics on this beast I was wondering if fueling while the engine is running causes the check engine light to come on. I know some vehicles that don't have their fuel caps on properly will throw a code, so I wasn't sure if the same applies to these trucks. Yeah, yeah I know that it's a "safety risk" but it's getting colder here and I'd sure like to keep the heat going when it gets really cold.
-Jason </div></div>Only Gas vehicles will throw a code if the Gas cap is not on Properly,it does not apply to Diesels,so It should not be a problem.
__________________ 2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
The only issue you might run into is that the gauge may take awhile to come up to "FULL" (it is called Anti-Slosh mode and may take up to 55 mins for the needle to rise). I experienced this once when I first purchased my truck (thought my gauge wasn't working), then as I drove down the road for about 30 mins, the gauge slowly started to come up. I checked at work and found that this is normal. From then on I filled the truck up with key in the off position so the gauge will respond instantly when I start the truck up.
Licensed Service Tech - PineWood Ford Ltd.
Certified Ford Diesel Tech
Owner of a 2003 F250 4x4 Lariat SC SB 6.0 5sp,True Blue, Flint Leather Interior. 70000km's on her and she RUNS LIKE A TOP!!!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JeffEzack</div><div class="ubbcode-body">The only issue you might run into is that the gauge may take awhile to come up to "FULL" (it is called Anti-Slosh mode and may take up to 55 mins for the needle to rise).
</div></div>
Heck in 55 minutes you could be down half a tank!! [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
2008 SD Short bed crew cab 4X4 diesel
Did it a few times on my 01. Fuel gauge would read low until the next key off/on sequence. One time the truck went into limp mode so I pulled over, turned the truck off, restarted, and truck ran fine. Haven't tried it on the new 08.
F-350 08 PSD CC Long Bed. Auto, 3.73, Dark Shadow Grey, Line-X, LT275/65R20 BFG Goodyear Wranglers, Leer Canopy. 2 German Shorthaired Pointers riding shotgun.
I believe it is a state law to turn cars off when refueling. I have seem numerous signs posted at the pumps that state that. Dont let a smokie see you doing that when they make their run in the store for the daily donuts and coffee.
Y2K excursion XLT 2wd, ordered july '99, built august '99, delivered september 9 '99, 4R100 fried & replaced at 900 miles still running like a champ
This applies more to gasoline burners than diesels. Having said that, though, there are several states that have enacted legislation to limit idling for pollution reasons.
