6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I have a 2008 F350 4x4 with 37 inch tires, it came stock with 3.73 gears. My question is what gear ratios should I be running for optimal performance. We are in the process of getting a 40 ft. 5th wheel toy hauler so the change is a must. I've been told 4.56 is about right but i've heard 4.30 is right any help out there would be great. All the off road shops i've talked to go back and forth between the two.
Thanks for the info..... in your opinion would the 4.56 gears tow the 40 ft trailer load easier than the 4.30 gears, sounds like the 4.30 gears are better for everyday driving as well.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE Try the SEARCH Button Because It's Probably already been asked
hey stymie, my truck is identical to yours 37's 6 inch lift 3.73 gears trying to find the right gears to pull a 40 ft trailer plus every day driver
personally i'd go with the 4.56's, it'll keep you closer to 2000 on the tach, and keep the tranny from shifting as much. I have pulled a trailer that weighed in over 10K and weven with my 3.73's i was never hurting for power.
17x9 Pro Comp 7189
I'd have to go with Stymie. Get the bigger gears. I am a firm believer in the theory that pulling with these trucks at low rpm causes alot of the egr, dpf, and intake coking problems we always hear about. My complaint is- 4.10 gears not available stock on my truck. With my stick and 35" tires, it makes common speed limits hard to maintain. At 25 mph, it screams in 2nd or lugs in 3rd. At 35, screams in 3rd, lugs in 4th. At 50, it teeters between 5th and OD. It's a little inconvenient, but not worth the cost or the surgery required to change gears. If I were to get the 4.10, I'd get a locker in the rear to replace the USELESS limited slip rear. Mine has never worked, and neither did the one on my '05.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
So with the 4.56 gears that would still be ok for an every day driver will it affect the mileage much better or worse? (IT PLAIN SUCKS ANYWAY) I think the trailer we are getting wil be 14 to 15K lbs empty probably 18K loaded. That is why i contemplated the 4.30 gears because of the everyday use and occasionally once a month maybe twice a month hauling the trailer
I may have to reverse my earlier recommendation. My truck has 35's with the 3.73 rear. That puts my actual ratio well below stock, and I pulled a 14K trailer with no sweat. If your pulling will be a rare occurrence, I'd go for the 4.30 to save you from bending over at the pump any more than you have to.
I'd go with the 4.56 gears towing that much weight, especially if you get anywhere near a mountain. 18k pounds loaded will be right at your towing limits.
Yes, you will take a mileage hit with 4.56 gears. How much, I can't say.
I get 12.5 MPG in mainly city driving and 15 MPG on the highway. My overall towing mileage runs around 10. I have stock tires, duals, 4x4 and 4.10 gears and my fiver is around 10,000 lbs loaded. In the mountains, I just pull away from the guys that have 3.73s. They hit the grade and bog down.
2008 6.4L F350 King Ranch, Crew Cab, Long Box, 4X4, Dual Rear Wheels, 4.10 rear-end, Job 1 (built Jan 2007)
