Originally Posted by rmzsuzuki89
Are there any good or bad years for the diesel motors, or anywhere else in the F250's and F350's? I'm looking mainly at the '08's, or higher if it's a good price. But if I can find a nice '06 or '07 for a lot cheaper I may consider going that route. But I'm hearing that there are some bad years. If this is true, which years are good and which are bad?
Well, the 06/07's are the 6.0 motor. 08-10 was 6.4, basically an updated 6.0 which was supposed to fix many of the problems the 6.0 had. That being said, from what I understand the 6.0's had a lot of problems in '03-'04, but by '05 they weren't bad. That is if they were left stock. Chipped and such they would still have headgasket problems.
The 6.4 has had some issues, but for the most part not with the engine itself. Radiators were a big issue with the '08's due to the supplier not making them properly. It seems that issue was fixed late '08. There have been some EGR cooler failures, which can lead to big time engine issues.
I've had 3 '08 trucks. Have had 1 that needed a new radiator, 1 that had a couple coolant hose leaks, and my current one needed new thermostats housings due to cavitation.
I've driven several 6.0 trucks. Will tell you the 6.4 is WAY nicer. Much more power, much nicer truck. Key is maintenance. Change oil/filter every 5k, fuel filters every 10k, and I change the coolant every 20k.
