Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 07-01-2008, 04:04 PM   #16 (permalink)
Originally Posted by sheepman View Post
I think the Biggest trouble has been Fuel in the oil, due to job 1 High Press Fuel Pump casting and or injectors. Radiators have been trouble some for many Job 1 Trucks too. Other then that just little stuff from what I hear.
Guys are pushing 500 HP now with these trucks in stock form and 700 plus with injectors and some other mods.
Diesel Power mag is going to be doing an article about the 6.4L in the Next couple mouths!
I own 3 of these.1) job 1,1)-job 2 and 1 )job 3.My Job 1 is in the shop now for the second radiator replacement.This truck has a little over 60,000 miles.The dealer told me the second radiator was NOT covered?But they are making it right...NO COST TO ME!.My job 2 has had 1 radiator at 31,000 miles,and my job 3 only has about 4000 miles.
4STAR is offline
Old 07-01-2008, 05:02 PM   #17 (permalink)
RockRidge's Avatar
No problems at all! 21,750 and counting.
'08 F350 FX4 Blue LB SRW 6.4L Auto 3.73 Sirius Tow Pkg (Born 3/20/2007 - Mine 4/13/2007--Friday the 13th!)
'01 28' Aljo Fifth Wheel (About 12K Loaded)
'07 Escape, Blue (Wifes) '03 Escape (sold)
'05 Escape, Green (Sons)
'03 F250 XLT Blue 6.0L Auto SB 3.73 & tow pkg (SOLD)
'90 Jeep Wrangler
RockRidge is offline
Old 07-01-2008, 05:30 PM   #18 (permalink)
Job 3, 2100 miles, just had radiator replaced due to leak at left lower corner. I don't think the radiator problem is solved yet. I guess it's possible that my truck could have gotten one of the earlier faulty ones, who know's?
737tdi
2008 F350 4X4 Supercab
2003 VW TDI
1995 F150
1969 Ford 3/4 ton Camper Special
737tdi is offline
Old 07-01-2008, 08:43 PM   #19 (permalink)
nipperdog's Avatar
Took delivery of my JI F250 05/07 and now have +30K mi. O defects and the best damn truck I've ever owned. Milage is what it is and ya can thank the EPA for that. I got a feeling that they are going to slap more crap on the newer ones so glad I bought the 08.
2008 F250 4X4 Lariat 6.4 Supercab
2004 HD FLHRI
2004 20' center console 115 Yama 4 Stroke
2006 14' Airboat GM 4.3 V6 and a
Toro Lawn Mower
nipperdog is offline
Old 07-04-2008, 12:43 AM   #20 (permalink)
The reason I get so riled up over a transmission is that Chevy has completely done away with manual tranny's behind their diesel engine- seems as though they think it's too powerful to put a clutch behind it. In my opinion- there are not enough Chevy customers buying manual transmission trucks- so it is not worth their money to re-tool the assembly line to make those few that will sell. My friend bought a Chevy gas truck in '02, and the manual tranny was actually a $1500 option! I HATE automatic transmissions, and if Ford goes the same route Chevy has, I'll be driving something else in the future, and the thought of that makes me sick! Don't get offended- every time someone on this forum calls me a dinosaur for driving a stick, it ruffles my feathers- nothing personal.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
torino73 is offline
Old 07-04-2008, 04:09 PM   #21 (permalink)
The only problems I have seen with the 6.4 are:
-Leaking radiators (hopefully fixed with new venturi "t-fitting")
-Chafed or chewed up pressure control valve and volume control valve wiring harnesses
-Cracked fuel injectors
-Sticking fuel injectors
-Exhuast leak at the turbo downpipe gasket
The biggest problem that causes the most damage is the leaking radiator. The low coolant can cause one or both EGR coolers to burn up, dumping coolant in the engine, bending a rod or breaking the crank. Low coolant can also cause extreme cavitation in the front cover wearing a hole in it, dumping coolant in the oil. Also the smallest particle seems to cause a fuel injector to stick which will cause a no start. No more blown head gaskets due to the removal of the rocker box the 6.0 has. The rocker box is a big aluminum washer in between the head bolt. The 6.4 dosen't have this, its iron to iron.
Ford Diesel Technician located in Northern California. I'm a mod friendly technician, contact me if you need warranty work in the Sacramento area.
Gofasterdammit is offline
Old 07-05-2008, 06:27 AM   #22 (permalink)
14k and never been in the shop. But I agree with the guy who posted above about the A/C not being cold enough.
08 F350 Lariet DK.Blue/Silver CC Short Box SRW. Auto transmission, Manual 4x4,Supplemental Cab Heater,3.73 Limited Slip.Gator Guard Bedliner, 6.5 x 12 Sno-Pro,8ft. Fisher.
04 Lance 820.
Light Trucks I've Owned Before
02 SuperDuty Super Cab Lariet Auto 7.3 4x4
01 SuperDuty Super Cab Lariet Auto 5.4 4x4
99 Dodge Ram Extended Cab Larime Auto 5.9 4x4
93 Dodge Ram Regular Cab Larime Auto 5.9 4x4
88 Chev Blazer 5.7 4 Speed 4x4
85 GMC 2500 Regular Cab 5.7 4 speed 4x4
70 Chev 1500 Regular Cab 292 Straight 6 4 speed 4x4
74 Blazer 5.7 4 speed 4x4
Captcaper is offline
Old 07-05-2008, 07:54 AM   #23 (permalink)
Harley350's Avatar
My wifes 2006 GS 430 Lexus.........
Rear back-up sensors, 3 times...
Front sensor 1 time...
New rear end, old one made scary noise...
Wiper motor...
AC BAD smell...
Seat belt would lock up...
Front break rotor cracked...
The tacometer made a ticking noise (no its not a diesel engine) new tac...
In shop for alinement THREE TIMES errrrrrrrr...
Rear view mirror motor stopped working...
Next door neighbor owns a BMW 760i and if you don't was to start crying your heart out you should not listen to his story about the problems he's had with his $84 thousand dollar car.
Ford is not the only company with problems, they all have issues, even a Lexus and BMW. Thank You, and have a nice day!!!!
Harley350 is offline
Old 07-05-2008, 12:47 PM   #24 (permalink)
Jcard's Avatar
Damn ac keeps freezing my feet.
08 550 lariat silver crew
Previous Fords
05 350 lariat silver crew (wrecked)
04 250 lariat silver crew
04 250 lariat silver crew (lemon)
2000 350 xlt silver crew
late 99 350 xlt silver crew
Jcard is offline
