HELP 6.4L won't start - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 02-11-2013, 07:15 AM Thread Starter
Hi Guys
2008 F250 6.4
Wont start
Few issues
1. No earth to starter relay in under bonnet fuse box, if i put an earth in engine will turn over.
2. Engine will not fire, low pressure pump is running, following codes are showing
P2455
P1335
P179A
Any Ideas as to the cause ????????
garethssm is offline
post #2 of 20 (permalink) Old 02-11-2013, 07:59 PM
guardrail22's Avatar
P2455 Diesel Particulate Filter Pressure Sensor A Circuit High
P1335 EGR or reprogram TSB
P179A Controller Area Network (CAN) Engine Control Module (ECM)/Turbocharger Boost Control A Actuator Circuit Malfunction
http://www.***************.com/forum...read.php?t=259
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2013
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline
post #3 of 20 (permalink) Old 02-12-2013, 04:04 AM Thread Starter
Thanks for that now i need an idea of what to check first.
post #4 of 20 (permalink) Old 02-12-2013, 08:21 AM
senix's Avatar
Check the sensor in front of the DPF to see if it is bad. Does not cost much.
EGR...valve is probably stuck or electronics to it are bad.
Clear the codes and see what you get.
the P179A I would ignore.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #5 of 20 (permalink) Old 02-12-2013, 09:54 AM Thread Starter
Thanks Senix
Is there anyway to test sensor in fornt of DPF ?
post #6 of 20 (permalink) Old 02-12-2013, 10:01 AM
senix's Avatar
Not really but they are fairly inexpensive to just replace it.
Only thing you can do is check all the electrical connections to ensure they are good.
Can you clear your codes?
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #7 of 20 (permalink) Old 02-12-2013, 10:28 AM Thread Starter
Ok ive checked the connections seem fine. unplugged and replugged them hasnt made a difference and no i cannot clear the codes.
post #8 of 20 (permalink) Old 02-12-2013, 10:44 AM
senix's Avatar
Take the cables off the batteries...step on the brakes or turn on the headlights for a few miniutes. See if that will potential reset any of the codes.
then try again.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #9 of 20 (permalink) Old 02-13-2013, 06:21 AM Thread Starter
Tryed that hasnt made a difference codes are still showing and still wont crank.
when i put an earth into starter relay it will crank but wont fire
post #10 of 20 (permalink) Old 02-13-2013, 07:11 AM
senix's Avatar
Look at this one last item...otherwise I am afraid a tow is in order.
Check your fuel cutoff switch. It is located on the passenger side of the dash.
If you open the passenger door, right on the side there is an access door.
The switch is orange I believe. See if that is tripped.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #11 of 20 (permalink) Old 02-13-2013, 08:28 AM Thread Starter
No defiantly isnt the cut off one of first things i check.
I would love to have it towed but im not in USA so not possible.
Thanks for your help ill keep looking.
post #12 of 20 (permalink) Old 02-13-2013, 08:38 AM
senix's Avatar
I think you need a code reader capable of clearing the codes. That would help greatly.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #13 of 20 (permalink) Old 02-13-2013, 01:06 PM Thread Starter
Im going to borrow a snap on solus and go from there.
post #14 of 20 (permalink) Old 02-13-2013, 02:05 PM
senix's Avatar
Just thought of this...on the passenger side battery there is a jumper. If you put that to the battery it may start that way.
If it does then it is a DPF sensor issue.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #15 of 20 (permalink) Old 02-13-2013, 04:01 PM
senix's Avatar
1. Vehicle in PARK
2. Parking brake SET
3. Key in the ON position
4. Open hood
5. Near the RH battery, there is a single wire disconnect. It is attached to the battery box. Remove it from the battery box and disconnect it.
6. Touch the end headed towards the starter to the POSITIVE terminal of the battery.
The truck should start. Reconnect the wire, close the hood, and check for codes. You will likely have a code for EGT-13 open circuit, over temp, out of range.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
