hesitation on rapid acceleration - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 08-01-2007, 01:24 PM Thread Starter
cannondale275's Avatar
I don't really know if this is a problem but I wonder if I am alone. When I get on the throttle hard I notice what I think is a hesitation or stumble. It kind of feels like one turbo is spooling then a brief lag until the 2nd turbo spools. At that point it hauls the mail. This condition is very noticeable too.
At part throttle the power is smooth and this condition does not occur.
I have about 3000 miles on it so far so and I have noticed this since new. (I mention this because I am running 37" tires.)
Mike
Experience is something you get... right after you need it.
2008 F350 long bed Lariat 4x4 crew cab 6.4 oil burner. 8" Fabtech and 37" Toyo MTs.
cannondale275 is offline
post #2 of 17 (permalink) Old 08-01-2007, 02:15 PM
Re: hesitation on rapid acceleration
Don't worry I have a bit of turbo lag also. A car was stopping in front of me to pull into a driveway and I went around them but saw traffic coming pretty quick on me so I stabbed it and .....ummm waiting, waiting, boost gauge swings to 20psi then it's rocket time. It was a little scary because I'm used to a gasser and acceleration is instant. You almost have to give yourself an extra second if you plan on a aggresive lane change or stop light launch.
2008 F-250 Lariat 4x4, 6.4L, 4 tires, brakes, windshield, windshield wipers, tailgate, bumpers, blinkers, headlights, spare tire, rear bumper, hood, antenna, driver AND passenger seats, speedometer, radio, steering wheel, & spare set of keys!
Hydro is offline
post #3 of 17 (permalink) Old 08-01-2007, 04:22 PM
nascarj's Avatar
Mine does the same thing. It even seems like lifting off to 1/2 throttle gets it to spool up faster... It's taking some getting used to.. I can't jump on it and expect to get out of someones way or be able to pass when it's close.
My old 02 7.3 did this until I chipped it.. Then all the lag was gone and it launched VERY hard... It also made A LOT of smoke until the engine spun up over 2500 rpms..
The big delay when I tromp on it is about the only time I wish I still had my old truck.
j
02 F250 XLT CC/SB/2WD 7.3 PSD- DP Tuner 6 Position Chip, MBRP 4 in exhaust, AFE Stage II, A-pillar ISS Pro Gauges- Died
08 F250 XLT CC/SB/2WD 6.4 PSD- Bone Stock... For now- Gone
11 F350 Lariat Dually/CC/LB/4WD 6.7 PSD
11 48ft CargoMate enclosed race trailer
04 Crossroads Cruiser 28BH 5er
Fox body Mustang GT- NASA American Iron-Central #76 AND
S197 (2005+) Mustang GT- NASA American Iron-Central #75
nascarj is offline
post #4 of 17 (permalink) Old 08-01-2007, 04:27 PM
mountie's Avatar
My Photos: (6)
I encountered the same thing so it's basically learning how to drive the new truck. I find that as long as you have even a little rpm going over idle it will respond immediately. I tried it once by stopping at a light and spooling up the turbo slightly. When the light changed I stepped it down a bit and the truck shot through the intersection like a bullet. Couldn't believe the power. [img]/ubbthreads/images/graemlins/grin.gif[/img]
2007 F350 crewcab Lariat shortbox Diesel 4X4, Retrax Roll Top Cover, Newer tailgate with camera and step, Airaid Intake, Magnaflow exhaust, Cortex tuner on mileage setting, Edge Insight CTS Monitor, Upfitter Switch Kit, Sinister Diesel Coolant Filter. Warn 12000lb Winch with Stainless Transformer setup and a pair of 150 Watt Stainless KC Daylighters. Ford Blue Spring Fuel Pressure Regulator Upgrade Kit. 200 Amp Alternator.
mountie is offline
post #5 of 17 (permalink) Old 08-01-2007, 05:05 PM
nascarj's Avatar
mountie,
I'm wondering if mine is being a dog... Even if I am above idle, there is still a huge delay.. It seems if I'm going 10-15 mph and floor it, the wait is even longer since the trans has to decide what gear it wants to down shift into before the rpm's come up and then the boost. I've even nailed it going 65 on the highway and nothing much happens until it downshifts and then no real thrust until the boost comes up (another second or two).
I need to quit typing about this. I'm starting to really want my old 02 back. [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
I haven't tried brake torqueing it to see how much it helps. As bad as it is until the boost comes up, I didn't figure it would do the tranny any good torqueing it hard enough to get the boost up for a decent launch.
j
nascarj is offline
post #6 of 17 (permalink) Old 08-01-2007, 05:57 PM
You can have it checked out but I think what you're experiencing is normal. Matting the throttle seems to create a lot of lag. My 03' did it and my 08' does as well. I've found the quickest acceleration is achieved by depressing the throttle smoothly.
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black
2007 Keystone Raptor 3712TS
newbie_101 is offline
post #7 of 17 (permalink) Old 08-01-2007, 06:43 PM
nascarj,
I've complained about the same thing on the forum before. My big problem is at 65 mph and needing to pass someone. Part throttle acceleration is very poor - truck stumbles and curses before even starting to move. I didn't experience this on my other trucks before or after they were chipped.
I am having hard time believing it is turbo lag because sometimes the truck runs fine. I stopped for lunch --turned the truck off-- got back in 20 mintues later and it ran fine.
I wonder albeit without much knowledge if it is associated with the regen cycle not turning completely off????? I know it wasn't supposed to be in regen for 200 miles!
Rjeffj
Goldspot 2008 F350 4x4 LWB KR SRW 3.73 auto bone stock now. Like my Fords- '07 Shelby GT 500, Original '67 Shelby GT 500 w/Stroked 427, etc
RjeffJ is offline
post #8 of 17 (permalink) Old 08-01-2007, 06:59 PM
Along with the posible turbo lag, fly by wire throttle systems do not like to be "matted". Also it is very posible that both the engine and transmission have torque management settings programed into the ECM and TCM.
Visit my website
2002 Corvette/2008 F250 6.4L KR
blazeone is offline
post #9 of 17 (permalink) Old 08-01-2007, 07:53 PM
nascarj's Avatar
I agree with you... That's the unfortunate thing.
I suspect it has a lot to do with controlling emissions... With the amount of black smoke my old truck put out when launched hard, this new 6.4 would be regen'ing every 2 or 3 stop lights if it had the same throttle response. [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img].
j
nascarj is offline
post #10 of 17 (permalink) Old 08-01-2007, 07:57 PM
nascarj's Avatar
nascarj,
I wonder ... if it is associated with the regen cycle not turning completely off????? I know it wasn't supposed to be in regen for 200 miles!
Rjeffj
It will definitely be low on power during a regen. Mine won't make over 20 psi of boost and feels like it is only making 100 lb/ft of torque. My old 80 HP Suzuki Sidekick felt like it accelerated better than my truck during a regen.
j
nascarj is offline
post #11 of 17 (permalink) Old 08-02-2007, 01:16 AM
mountie's Avatar
My Photos: (6)
This is what I've found also.
I've never actually floored mine. I haven't had to. I passed a guy on the highway last Friday. I was doing about 65 then stepped it down to over 80 and the truck just took off. No stumble or lag whatsoever. If anyone is experiencing stumble when passing it should be looked at if it is a repeating problem.
mountie is offline
post #12 of 17 (permalink) Old 08-02-2007, 04:05 AM
I'm pretty sure what you guys are experiencing is kind of a turbo lag, but its not totally all turbo lag thats causing this. I read awhile ago that when you put your foot to your floor off the line with no boost, the computer in your truck will increase the amount of fuel it injects as the boost comes in. So off the line when theres no boost your computer wont allow the injectors to put in as much fuel as they can, but less until you get some boost, and then it will add more fuel so you get more boost, then it will add more fuel, so on and so forth until you have enough boost so that your computer will allow the injectors to put in there max fuel flow rating. So its half turbo lag, half computer not allowing 100% of fuel flow at low boost levels.
1985 Ford F-250 4x4 Regular cab
6.9 IDI diesel N/A with T-19 4speed
Blazing Fire red paint, all new chrome exterior pieces, Eagle alloys series 186 16x8 wheels with BFG T/A KO 285/75/16 E tires.
ATS wastegated turbo on the way.
JustinWhaley is offline
post #13 of 17 (permalink) Old 08-02-2007, 10:06 AM Thread Starter
Computers, sheesh! who needs 'em? Lol [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Like I stated in my original post at part throttle the motor sings without any lag or hesitation but damn that can lag can get you into trouble in a sticky situation...
post #14 of 17 (permalink) Old 08-02-2007, 10:32 AM
I guess the turbo lag it why I was able to out run my neighbor, in his 6.4 with my 7.3 which has a chip. I thought he would blow my doors off. The look on his face was priceless.
2000 4x4 crew cab short bed auto x springs air ride diamond b frnt & rear bumpers 120 hp pac chip 4'jardine exhast
bmiker is offline
post #15 of 17 (permalink) Old 08-02-2007, 10:33 AM
I agree with you there. It does take some time to get used to it's characteristics. Coming from a gasser makes the situation worse. Instinct tells you to hammer it. On a quick left hand turn that can get you into trouble. At least it doesn't experience the 6.0L's dead peddle. Now that was scary.
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
