6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Hi guys, first post here. I am lookin at a 2010 KR F450 with 120 K miles on it. It is all complete and original, no mods yet. Is there anything I should be concerned about on a truck with this mileage? I have owned lots of 7.3's and 1 6L and dont know much about these 6.4's, so just trying to make a good informed decision. This truck has all southern highway mileage on it and was not used for heavy towing.
OK, sounds good. This truck is 2000 miles from me so I cant just go for a look. I am gonna have to finance it and then once its paid for then go get it. I was thinking after reading of all the major failures on here, that I should take it over to the nearest Ford dealer and have em go right over it, changing all the fluids asap. The carfax report looks good, regular oil changes every 5 or 6K with a couple at 10K. Am I completely nuts for even considering somethin like this, or should I take a chance? Rock bottom price is 30 G's...
This is from a used dealer, but they did seem to have a little knowledge about the truck. They told me that it was a local one owner and that it had been serviced at the same dealer all the time...but I guess a carfax will tell that also. This truck has been extensively detailed and so the engine bay is spotless and the tailpipe looks clean inside, no soot to speak of. Sorry I cant seem to get pics to load here so thsi is why Im trying to describe all this. They did tell me that the truck is completely stock, no mods as far as EGR DPF delete and no visible sign of a tuner previously on the dash...
It helps that it's clean, however cleaning everything spot-less removes other tell-tales that might reveal other problems. Like replacing the tires so that a messed-up front end problem "disappears".
I agree with the idea of, if at all possible, having a local Ford mechanic evaluate it. They should be able to quickly assure you that the truck *probably* never had a tuner on it.
Good luck,
- Don
2010 F350 SRW 6.4L 3.55 CrewCab FX4 SB KingRanch - built Jan 2010 - bought new Dec 2010 "You can set my truck on fire, roll it down the hill, and I still wouldn't trade it for a Coupe d'Ville."
Rant: Do you know what you actually pumped into your tank on last fill-up? (cetane level, fuel quality, water, etc) Notice: Anything that I or anyone else writes about my vehicle on this, or any other, website pertaining to modifications or alterations, is only for discussion purposes and/or to gain acceptance from my peers, and may not actually represent anything existing on my truck, and thus, can not and should not be held against me in any issues, i.e. warranty claims, whatsoever that may arise for any cause.
That was one of my concerns, that any leaks etc have been all cleaned up with the detailing. I guess what I can do is cross my fingers, take it to the nearest Ford dealer there, maybe the same one who did all the servicing on it, have em drain everything and go right over it, and then hope like hell that it makes it back here 2000 miles. If I have any trouble on the way or I get a bad feeling then I can put it up for sale when I get home with it...
Definitely go back to *that* dealer that did the maintenance.
Make sure you drain the water separator (see threads here about that), checking for good flow, little water, no waxey stuff etc -or- have that servcing Ford dealer replace the fuel filters with a good internal inspection of the old filters (especially lower) and the lower filter compartment and drain.
Most Ford stores give you a "free 999-point inspection" with an oil change. Tell them that you expect them to do it *completely*. I'd do my best to hang around the service bay (yeah, I know, insurance doesn't allow it - but I do it anyways) and ask the tech to walk thru what he's seeing with you.
Pay attention to the drivers side lower corner of the radiator, that's where many of the problems show up. Also, read up here about checking the Degas bottle cap area for white residue. If you can, change out the cap with a Ford part, just to be safe.
There are other threads here on checking 6.4Ls specifically. Look for them, there's a wealth of info here built-up over the years, but you have to look hard sometimes to find it. It's worth the effort.
Good luck, and enjoy the drive back home in your new 6.4!
- Don
Its kinda to bad in a way that it has come to all this checking this and that to see if it 'might' be any good. I have owned a few 7.3 IDI's over the years and the best way to know if they were gonna be good was if they started, then you knew you were good for 10K miles easy...without even having to check anything...
My 08 F450 has near 150k
Complete motor at 30k
Several injectors
Starter
Radiator
Fuel cooler
Degas Bottle
High pressure fuel pump
Oil cooler
Head Gaskets at 135k
and a bunch of stuff I'm forgetting.
That's near $30k in repairs to go 150k miles!
My V10 went 230k with not a single engine repair.
My 7.3 was the same way. I'd stay away from a 6.4 unless it is under warranty.
I known mine will be gone before the 7/200k expires.
Most of the bugs were all worked by the '09 models. '10 models were pretty much trouble free
48K on mine now, no major issues other than a steering box leak and replacing both blend doors. I got some other fixes such as a TSB for a clunking noise under the driver side cabin and a new CAC that didn't fix anything, but fortunately, all of this was under my 3/36 B2B warranty.
The DPF at 120K miles is something to keep in mind. I think they are designed to last a minimum of 150K without any maintenance by law. Sooner or later it'll have to be pulled and cleaned out of ash. Frequent regens might be a symptom since the thing is full of ash instead of capacity for soot. I have a while to go, so I wouldn't have any credibility to say anything about that yet
Well I think if I buy this truck, which I am gettin ready to pull the trigger on over the weekend here, then one of the first things to be done with it would be to pull the DPF right away. My brother had an '08 that he bought a 5" turbo back exhaust for but never installed so that will go on. Will I need a tuner if I am going to remove the DPF?
Also, how complicated is it to completely remove the EGR system on one of these? I was told that the cab needs to come off...
Yes you would need a tuner. Don't do the exhaust without the tuner being on the truck. I would go into eternal regen.
EGR stuff can be worked on or removed cab on. In fact everything can be done that you would ever want to do with the cab. There are procedures for both.
Cab off is the preferred method as it is so much easier for the techs.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
