6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I'm guessing that the low sulphur is for canada. I don't think we have low sulphur diesel (yet) I was actually wondering what they were going to do up here.
Actually most of the diesel available in Canada is Ultra low sulphur.
I am interested in using high sulphur from our construction site, as we pay only 70 cents/L. Not to mention higher performance from higher sulpher content.
Ultra low sulphur diesel has been available in Canada since October 2006. I believe you will find that it is the law that all pumps selling diesel for highway vehicles must sell the new ULSD grade of fuel. The following link may help and I am sure a search will find others. http://www.cantruck.com/news/news/20...oadSulphur.pdf
08 F-350,DRW 6.4L auto SD Lariat Crew Cab, Short box, 4wd 4.30 TowBoss
Ryan
Higher sulfur does not = higher performance. Sulfur is just in the fuel and it's expensive to get it out. Back when nobody cared, they didn't bother. Now that it will mess up emissions controls, they are getting almost all of it out. (I believe the interim step of removing some of the sulfur was for other pollution reasons such as reducing acid rain?)
So sulfur itself is a complete don't-care as far as the engine is concerned. It has some bad effects so they're getting rid of it. (The *process* they use to get rid of it can also reduce the fuel's lubricity, not the lack of sulfur itself, so they will be adding lubricity enhancers back in of course.)
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
I thought running higher sulpher diesel in an 08 would clog up the DPF etc, causing the need for regen more often leading to other problems and so on ........
Bare with me, this whole diesel thing is 1 week old to me.
Ryan
thats illegal in the US i dont know about anywhere else.
2000 Ford F-350 4 door dually. Straight piped, autometer (trans temp, pyro, and boost) ultralight gauges, AFE stage 2 intake,5 in exhaust (straight piped), and DP.
6.9L 1984 F-250 4 spd flatbed
6.0L 2006 F-250
international 7400 straight truck DT-466
12x7x4 Hawke dump trailer
Actually, the Cetane number of ULSD is higher than the higher Sulfur stuff. You may lose a miniscule amount of mileage, but should not lose any performance. Your engine should run cleaner and maybe even longer.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 231,000 miles. Uses no oil between changes.
I realize running dyed fuel is illeagal, not what I intend to do. I want to configure my truck to run high sulphur for the sole purpose of saving 30 cents a liter (over 30$ a tank).
Thanks for all the replies
[/ QUOTE ]Buy a 6.0 or 7.3 L PSD.
Too late, already got an 08 SWB supercab. Its not a dumb question. The manual states that the motor can be configured to run higher sulpher diesel, I just wanted to know if anyone knew how.
I might be interested in that too. Here in N. Minnesota, more than half our gas stations don't have ULSD yet. The big refinery in Superior, WI (where most of our fuel comes from) got an exemption from having to produce ULSD until 2010. So, the only ULSD we are getting here is coming via pipeline...this sucks. I guess I am glad I haven't pulled the trigger yet. That is unless, I can burn the higher sulphur stuff...
I am going to make a few phone calls tomorrow and get to the bottom of this.... I will be sure to post what I dig up. If you look in the 6.4 diesel manual, it says you can do it, just not how.
FWIW, the sulphur isn't the problem... the soot that it produces is and it isn't a problem for the way the motor is "configured"... it is a problem for the exhaust treatments. The DPF is going to get the hardest hit (and you can bet the warranty nazis are going to be looking at those) followed by the EGR and VGT and, somewhere in there, probably the EDOC and the DOC.
All of these devices are going to depend on fuel with reduced particulate emissions to start with.
AFAIK, "high" sulphur content is diesel fuel hasn't been around for quite some time. Low sulphur fuel has but, in Canada anyway, is not permitted for production at this time.... LSD fuel is regulated at 500PPM sulphur maximum. ULSD fuel is regulated at 15 PPM max.... After that, we depend on vendors having at least a vestige of integrity.
The US is actually the north American leader in emissions reduction and many Canadian provinces lack even "anti-tampering" laws let alone any real clean air testing. I'm not a tree-hugger though I believe in moderation and responsibility.
