6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Just a little info about the particulate traps. Mercedes tried one on their 3.0L turbo engine in 1987. It was a disaster. It was placed directly at the output of the exhaust before the turbo. It plugged a lot and burned up turbos and melted pistons and cracked heads. They came out with a fix that replaced it with an up-pipe and then installed a catalytic converter downstream. I am sure that all the other manf. were watching this and are still keeping it in the back of their plans. BTW, the hotrod boys over in Finland are using this same engine to achieve up to 500hp. Crazy for a 3 liter I would say. And an aluminum head to boot. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Bud
1997(12/97) F250 SC XLT PSD 4x4 150k 4.10LS,5spd, 1998 BMW 323i conv, 1987 Mercedes 300D Turbo 175k, Mods include:Luk SM flywheel kit, Hypermax downpipe, no kitten, gutted ebpv, shimmed regulator, Donaldson open element air filter, add-a-leaf front.
If that is the case though, I have absolutely no respect for engineers. I had very little respect to start with,
I don't either, if they can't engineer a motor that you can drop the oil pan out of without pulling the engine out, how can they engineer the real technical stuff right. I think that FOMOCO is supid for rishing anything on these motors. Oh, and Ford doesn't own Cummins. My two cents. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
__________________ MEMBER OF:
<font color="red">---------------------------------</font>
<font color="red">Southern California Powerstrokes</font>
2001 Black CCD 7.3 LB 2wd, 4" Aero Turbine Turbo Back Exhaust w/5" Tip, S&B Cool Air Intake, Billit T/C, Billit Grill, Tekonsha Brake Controller
You have to pull the engine on the 7.3 to get the oil pan off. My favorite way is to pull the cab, undo the motor motor mounts and lift it up with a cherry picker and service it that way.
Every single Toyota truck chassis ever built requires engine removal to remove the oil pan too.
In fact, why is having to pull the motor to repair/replace the oil pan such an issue? Your either replacing a leaky gasket which doesn't really occur anymore because they use sealer instead of gaskets and much higher quality gaskets on those that do. If you have to remove it for any other reason the engine is going to need be replaced anyway unless you somehow know of a technique to machine the crank with the engine installed in the truck. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
I think the engineers would be stupid if they built the engine to accomodate ease of removal of such an infrequently serviced item.
It makes sense to engineer the chassis as efficient as possible.
Not true. I've pulled the pan twice on my 92 Toyota 4x4 w/o removing the engine. It's a job, but doable. And it's easy on a 4x2.
-john
agreed toyota does not and niether does the 7.3 if you know how to do it it will slip by with mm's of room same as the 6.0l have done many under warranty at the dealership and you always try to figure out a way to beet warranty labour time this is how you make $$ on flate rape
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
Hey now not all engineers are idiots. There are a few down here where I work, but most of them are top notch. Of course the typical outcome is the engineers are ordered to do stupid stuff by stuf mangers, been there fought that. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Couldn't agree more, Normally it is the Managers and the Bottom line that come into effect, no matter what the engineers say, BELIEVE ME, been there done that too! [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
You had to pull it twice because you damaged the gasket reinstalling it because you didn't pull the motor.
I bet you also like doing to the job twice. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Pulling the engine or cab takes what? 1.5 hours? Then everything is right there and you don't have to fight anything......And you can do the job right...the first time.
Nope... I pulled the pan on two separate occaisions for two separate reasons. I never did have a gasket fail and I never had a pan leak. Truck still keeps doing its thing... I actually use it to plow snow. I thought I'd kill it the first year, but this will be the 4th winter I've used it for plowing.
-john
1999 F-350 6-Speed SRW CC LB 3.73
nope i just know how to do it right the first time on time have never had to pull a pan again that leaked from doing it my way but each to their own
p.s can be done in 3 to 4 hrs tops paid 11-14 under warranty depends on man or auto
Cummins, of all, was the first to implement cooled EGR on commercially available diesel engines, aside the fact that the 5.9 in the Dodge Ram, never had it.
__________________ 2003 RED F-250 Lariat FX4
SuperCab, Short Box, 6.0L, Torqueshift
"1991" Sun-Lite Pop/Up Slide-In Camper
DIY-Coolant Filter
137,000 as of 1/26/2012
3/19/11, Converted to (red) Delo ELC, new bottle & cap, all temps reading good, orig EGR & OIL coolers, probably thanks to the coolant filter, and previously frequently flushed Motorcrap Gold.
Actually, some 12-valve 5.9 Dodge Rams did have EGR. I don't remember exactly which model years, but they were CA vehicles - so 1998 and earlier!
-john
I know a guy who knows a guy that talked to some chick at a garage sale who had a sister that had a one night stand with a guy that talked to a guy on the bus that once drove a Ford truck, and it sounds like Ford is going to be bringing back the old 6.9l diesel since it is .5 bigger than the proposed 6.4. They are also going to be using quad turbos since they want to be twice as good as any twin turbo engine out there. This is an indisputable firm source, so we may as well close the 6.4l forum down now [img]/ubbthreads/images/graemlins/smile.gif[/img]
1985 Ford F-250 Lariat extended cab, 4wd auto with Some kind of gears... 3.7whatever I guess, a manual glowplug system, screwed up bed, barely functional wiring, those stupid hubcaps with the seven fake lugs, and lots of rust. Now with an elaborate WVO setup!
