6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Sorry,,don't mean to change topic but new to this,,,have 2008 F350, 6.4L Diesel,,89K miles,,bought extended warranty ,,recently went down,,told by service tech that there was water in fuel,,so Ford warranty will not be honored...tried to turn in to insurance,,adjuster sent 2 samples from fuel system,,reported that insurance will not cover because lab report (which I have) found "no water in fuel",,,,,leaves me holding the bag,any ideas ?
Yea change the fuel filters and try to get your hands on some of that Diesel 911 stuff. Then after a month change your filters again and pray you got it all.
Alright guys, i found the wires and all, I'm puttin new shoes on the old girl here in a couple hours, when i do i'll wire her up. I'll let ya know what happens haha
08' F-350 Lariat Crew Cab Long Bed SRW
35/12.50-20 Nitto Trail Grapplers
2.5" Lift
SEIC Wired to Upfitter Switches
Spartan DashDaq
S&B Cold Air Intake
AFE 4" Exhaust from Turbo back
EGR Delete Kit
Upgraded Intercooler Piping
Does anyone know if this will cancel out the automatic shutdown after 5 mins. on the 08's with high GVW's? I'm sick and tired of having to restart my truck after 5 mins or so trying to defrost the windshield.
My question would be, do you HAVE to use the 1200 RPM setting, or can you add something to drop it down to say...800 - 900 RPM?
Originally Posted by Ford SEIC instructions:
Maximum engine speed is 2400 rpm.
Minimum engine speed – Diesel engine: 1200 rpm
So using the Ford procedures, you can set the high idle RPM for anywhere between1,200 and 2,400 RPM. But not lower.
With the factory option of the auxiliary idle control (AIC) on my '99.5, I had to use the factory mininum of 1,300 RPM as the lowest setting for high idle RPM. But after the AIC took over, I could mash buttons on the AIC that would manually lower the RPM to 1,100 or so. But you don't have those buttons on the SEIC.
Here's my AIC, available on '95 thru '04 PSDs. For 2005 model year, the SEIC replaced the AIC.
The buttons are hard to read in that photo, but they are for
RPM control..........Charge Protect..........Power.........Ford
PTO Control
The power button is simply the on/off switch. The Ford button is sorta like the enter ley on a PC - used for "programming" the AIC.
Quick question, after i wired mine up, it worked great. But now and then after i kick the parking brake on, and flip my switch, the engine tries to idle up, but then stops and i have a wrench flashing on and off on the dash. Any clue what the heck this means?
2.5" Lift
Spartan DashDaq
S&B Cold Air Intake
EGR Delete Kit
Ford calls that light is the malfunction indicator light (MIL), or some folks call it the check engine or "service engine soon" light. It means you or someone with the proper diagnostic tool needs to read the codes stored in the main computer (PCM) and see what your malfunction is.
Thank ya sir, it's odd, only comes on maybe 50% of the time, and only when i flip the switch for the seic. Seic doesn't work when it does this. If i turn the truck off and back on, the wrench goes away, and most of the time "fixes" the issue.
2.5" Lift
Spartan DashDaq
S&B Cold Air Intake
EGR Delete Kit
i did the high idle mod on my 2008 f350 6.4 and is only idiling up to 950 rpms instead of the 1200 that it says on the link any help? nvm on that when my truck warms up it dops the idil down to 950 but idils at 1200 when its colder or needing a battery charge but it still doesnt seem normal to me
Just to help some of those who don't like looking at wiring diagrams...Hook one of the switches (in my case #4 closest to the passenger side - brown wire) and the yellow/green wire together. You'll have to set your parking brake for it to elevate the idle speed. Without the parking brake engaged, it will disable the SEIC.
But wait ... hand up for a question
Doesn't the wiring directions state that you need to choose and add a resistor from the SEIC chart? In your directions, you simply route +12 from your switch/relay to the yellow/green PCM wire.
To my eye, it looks like you also should have had to place a resistor between white/brown and gray/violet to tell the PCM to tell it what RPM to idle at.
