How many miles are on your 6.4 powerstroke? - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-17-2012, 09:14 PM   #16 (permalink)
I have 08 f 350 with 312000. On its 3rr motor and 6 radiators, other than that all original. Thats original trans and even the rotors are original and it weights over 10500 lbs! Work truck. Thank god for extended warrenty to 200k. Last motor at 161k
skippydoo is offline   Reply With Quote
Old 11-18-2012, 04:24 PM   #17 (permalink)
104,000 ony 09 f450 with no problems since I bought new but after reading all the post about motor replacements I don't know of this truck is worth keeping any longer, the problem is I have 3 years of payments left and am not financially to by a new truck right now and I put on 30 k a year in my business, so should I be really scared of this truck or are there lots of 6.4 out there with good track records
2006 F350 King Ranch
4.30 gears auto
BrianLusk is offline   Reply With Quote
Old 11-20-2012, 05:12 PM   #18 (permalink)
118000 mixed towing and just driving. No problems with engine, trans. all original even radiator.
2008 F250 King Ranch 4x4 nav. dvd banks 6 gun tran
2007 Mustang GT
67 GTO 400 4 speed
66 EL Camino 427 4 speed
2012 F250 King Ranch 4x4 nav.
jcason is offline   Reply With Quote
Old 11-21-2012, 03:30 PM   #19 (permalink)
Met a transporter today with a 08 f450, 300,000 miles! He is on his third engine. He said the last one lasted the longest, the first two were in the first 100k miles.
Doubletap is offline   Reply With Quote
Old 11-21-2012, 03:35 PM   #20 (permalink)
senix's Avatar
did he go indepth as to what the issues were? Did you tell you what his maintance intervals were?
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline   Reply With Quote
Old 11-21-2012, 05:10 PM   #21 (permalink)
Unfortunatly it was a quick conversation. My guess is failing fuel injectors, head gasket/bolts or egr coolers kill these 6.4's.
Old 11-21-2012, 07:02 PM   #22 (permalink)
2008 King Ranch Crew Cab-8'bed-4wd. 178,800 miles and have owned since new. I pull 7 different trailers moving our construction equipment average 400 to 600 miles jobsite to jobsite. At 138,000 miles extended warranty covered replacement of both turbos-were not out, just seeping a little. I paid to have both enternal coolers and oil cooler replace with products from Bullet Proof in Phoenix. Lifetime warranty on parts. Transmission serviced every 50,000 miles. Royal Purple 15w-40 in engine since day I brought home in fall of 2008. Delete exhaust-open except for muffler. Never had a major problem. Never added oil between changes. Truck no babied- pull my trailers 75 and 80 on interstate. This is one tough puppie.
69machone is offline   Reply With Quote
Old 11-25-2012, 06:54 PM   #23 (permalink)
powdercoater's Avatar
Just bought my early 08 last month. All stock loaded Lariet, crew cab,longbed. It had radiator replaced in 09. It runs great. I think I have a crack in my down tube becuase it has a whistle ing at low rpm's
I sold my 01 7.3 w/225K for this one. I plan on it lasting me till 225K.
"The harder I work the luckier I get"
powdercoater is offline   Reply With Quote
Old 11-26-2012, 03:33 PM   #24 (permalink)
I love my truck also, not so much now, 118000 miles I'm having to replace the cam shaft and all lifters along with the radiator hoses with 2 o-rings tank, repair estimate is at 7000 they just started working on it today
Bryan F350 is offline   Reply With Quote
Old 11-26-2012, 03:50 PM   #25 (permalink)
senix's Avatar
Why...? This all seems like upper wear issues? How often did you do your oil changes?
08F250 CC 6.4 PSD
Banks 6 gun/ram air
Old 12-01-2012, 01:00 PM   #26 (permalink)
2008 F350 CC, SRW, 4x4, long box, FX4.
12K miles and zero problems
Dick Black is offline   Reply With Quote
Old 12-01-2012, 02:02 PM   #27 (permalink)
12k miles? That's like brand new!
tjmaxx is offline   Reply With Quote
Old 12-01-2012, 04:14 PM   #28 (permalink)
WK57ABF's Avatar
Hi,
Took delivery of our 6.4 in May 07, mileage now reading 18,000 miles. 80% of usage is towing a 10,000lb Airstream.
Fuel filters changed at 10,000 miles. Engine oil & filter changed every 4-5,000 miles.
Only issues - sensor on master cylinder for brake controller and venturi
T fitted.
Great truck.
John in the UK
WK57ABF is offline   Reply With Quote
Old 12-01-2012, 05:44 PM   #29 (permalink)
Yeah, still has new truck smell.
Have a 7.3 with 213K
Old 12-02-2012, 08:05 PM   #30 (permalink)
How often is oil changed and just as important-want brand and weight of oil?
This sounds like a lubrication issue. I had two 7.3's, two 6.0's and the current
6.4. Never had a cam or lifter failure.
